Question about Samsung Cell Phones
S:es.r330 gh09 prepend
How do I find a users manual for a Samsung R330 cell phone?
You can do a search for "Samsung R330 manual". Here it is. http://www.samsung.com/us/support/owners/product/SCH-R330ZRAUSC
Jun 29, 2014 | Cameras
JVC KD-R330 Won't turn off Demo mode - tried instructions. Every time I follow the instructions (Turn on, Hold Menu, push "vol" button, change to Demo off...etc) It doesn't work. In fact, as soon as I...
Do you have a Bluetooth adapter plugged into the KD-R330?
A compatible Bluetooth adapter (like the KS-BTA100) usually plugs into the rear auxiliary port of the receiver. It then needs to be "paired" with your Bluetooth device, for example, a Bluetooth phone headset.
What you're describing sounds like what can when no Bluetooth device has been "paired" yet.
If you don't HAVE a Bluetooth adapter connected to your KD-R330....is it possible you accidentally plugged something into its rear auxiliary jack? Or the front auxiliary? In other words, is it possible your KD-R330 receiver is mistaking some other device for a Bluetooth adapter?
Don't know if that helps at all...if there's no adapter issue, and nothing connected to the AUX jacks, probably your next step should be a call to JVC, or whatever number you were given for tech support.
On the bright side, since the receiver turns on, and responds to some commands, you probably didn't mess up anything major in the wiring. And, there's also the possibility the receiver is defective....certainly if this continues, and JVC can't help you, trying a replacement might be worth a try.
BTW, feel free to post a reply...I'm going to look further to see if there's any other documented issue besides an adapter that might cause the problem you're having.
Oct 29, 2013 | JVC Car Audio & Video
I have a panasonic electric typewriter R330 and it only types about in inch then stops how can i fix it?
The right margin is probably set. Hit margin release( MR) and see if it types, if so reset your right margin. Also something could me binding or caught in the path. maybe a correction ribbon or something is blocking it.
May 30, 2012 | Panasonic Refurbished Kx-r330 Typewriter...
My Technics SA-R330 receiver audio problem
hello,
this problem can be solve by opening the receiver and check for dry soldering on the audio section of the printed circuit board, resolder if found any.
Also check for electrolyte capacitor if they are faulty by using an ohmmeter to read the faulty.
Good luck.....
May 25, 2010 | Audio Players & Recorders
Cocoon Child Carrier: Where to find a user manual for Samsung SCH-R330. ...
http://downloadcenter.samsung.com/content/UM/201004/20100424031418203/us_cellular_r330_Stride_eng_ug.pdf
May 16, 2010 | Bell Cocoon Child Carrier
I am looking for a user manual for Technics SA-R330 Stereo Receiver
http://diversesolutions.org/files/SAR330.pdf
Here is the manual for the Technics SA-R330
Jan 13, 2010 | Audio Players & Recorders
What does the "prepend" category on the options-erase button mean?
Here is the user manual, hope it will help you with everything you would like to know about your phone.
http://www.embarq.com/embarq/refDocs/user_guides/Wireless/UTStarcom_7025.pdf
Aug 24, 2009 | UTStarcom CDM7025 Cellular Phone
OPTIARC DVE RW AD-7561A GH09 157 INSTALLED AND RECOGNIZED IN LAPTOP. ROXIO EXPRESS LABELER. DID LABEL. INSERTED TDK DVD R 1-16X IN DRIVE TO BURN LABEL. DRIVE SAYS NO LIGHTSCRIBE IS IN THE DRIVE.
I dont hawe solution but i hawe problem with writing DVD-s.
Using Nero, burn some files on DVD, burning proces takes too much time, after that it seems that everything is OK but when I try to see files I can not see anything!
I can not find driver on manufacturer home page!
Apr 28, 2008 | Computers & Internet
Cell Phones Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
