Question about Spectre 2008 Ford Econoline - E350, 6.8L V10 - Air Filter
Ford engine losing lots of oil no leaks
Oil is disappeaing, no leks no smoke
My Oreck XL Air Purifier Tower constantly turns itself on and off while in use. Been cleaned once a month x 3 months I've had it, all instructions followed. How do I fix this?
I'd give oreck a call...
To speak with an Oreck representative call:
USA: 1•800•989•3535
Canada: 1•888•676•7325
Mar 16, 2018 | Oreck Air Purifiers
Engine cranks very slow on starting and will not start
refill the battery with electrolyt and charge it fully, then try to start the vehicle
If it cranks/turns over no faster have the starter motor checked.
Ensure that the timing belt is intact before you do anything, and that it is in the correct position.
Ensure that the oil is clear of water and is clean and is topped up to the top mark on the dipstick
Assuming you have checked the above and the belt and oil/coolant is all as they should be, and you have a fully charged battery and the starter is ok .......attempt to start the vehicle. Turn it over/ crank it over a few times if it does not start immediately.
Should it not start perform a compression check to find out the
engine's state of health.
Then come back with the results and we can go feom there.
Add the detail of your work and the make and model of the vehicle, along with the engine option, and repost the query
Jul 18, 2015 | Spectre 2003 Dodge Stratus - 2.4L 4-cyl....
Rapping noise from engine after running low of oil
That's a bad sign.You probally damaged the engine.Have a shop check it out.
Feb 03, 2015 | EBC Brakes 2004 Ford Focus - Wagon, 2.0L...
Would a bad intake gasket cause a check engine light or for the insufficeint flow to EGR code come up?
Yes it can be. Here is a simple way to check for a intake leak. Get a can of crab cleaner. Start the motor, let the motor idle if it will. Spray the crab cleaner around the intake where it bolts.to the cyl heads. If the intake is leaking you will hear the motor idle change. You can check vac lines the same way. Hope this helps you find the problem.
Jun 12, 2014 | aFe 2001 Chevy Impala - 3.4L V6 - Air...
Why is my Toyota LC not accelrating beyond RPM 3.
try to reconnect the check engine sign (make the OBD system operative), it looks like the fuel injetion calculator is not working properly
May 11, 2014 | aFe 2005 Toyota Land Cruiser - 4.7L V8 -...
Engine indicator "ON"
You probably need to reset the indicator. You should be able to find instruction on line how to do this.
Feb 08, 2014 | aFe 2004 Honda Accord - 3.0L V6 - Air...
How can i wash the engine from inside?
CRC makes a product available at your local store call "Fast Motor Flush". Just follow the instructions and the product will clean your engine fairly well. Really old and dirty engines may need 2 times.
Sep 24, 2013 | Hyundai Hynda Tiburon 2005othrYrs/Mds...
My Honeywell Enviracaire Hepa Air Filter machine has a squeak when it runs. I am unable to find a place to oil it. Can you help?
is no place to oil it.They have closed type motors. You can just use a lubrificant typeWD40 to spray the mouving parts
Feb 21, 2011 | Honeywell Enviracaire 13520 Air Purifier
It is making a lot of noise. I believe it is the fan and I have oiled significantly with silicone spray on both sides of the fan motor and it resulted oin only a small improvement.
you will need to remove and clean but as a last try use a good deggreaser to wash off , try and use WD40, the use light oil-SAE40 to the fan spindle points and check out.
It will improve a lot but repeat the process a few times ,then switch on and repeat.
If sucessful, dont forget to vote
Sep 02, 2010 | Ecoquest Fresh Air Air Purifier
Hi my old Honeywell 13520 has acquired a periodic squeal. I am sure it is a motor issue. Any way to tune up these little motors? (Brushes, etc..)
Usually if the motor is squealing, the bearings are dry no lubrication and worn. If you have oil ports you can oil it and quiet it down for a while. Most motors now have self lubricated or oil impregnated bearings, which you can't lubricate. It costs as much for somebody to replace the bearings, as it does for a new motor. Most people replace the motor.
Nov 17, 2009 | Honeywell Enviracaire 13520 Air Purifier
Spectre 2008 Ford Econoline - E350, 6.8L V10 - Air Filter Logo
23 people viewed this question
Top Spectre Air Purifiers Experts
Lawrence Oravetz
Jesse Walters
Jesse Walters
Are you a Spectre Air Purifier Expert? Answer questions, earn points and help others
