Question about Garden
Wiring schematic lt1046 cub cadet
Blade will not engage. Battery charged. Blinking light on dash.
    Problem Solver:
  • 29 Answers
You have a sensor that is stopping the clutch that starts the blades
One may be the seat you sit on ---check with a 12volt light sensor
or foot clutch/brake sensor also is not completing the circuit or alignment of nuetrel shift mechanism
Posted on May 01, 2014
  • 109 Answers
SOURCE: cub cadet 1024 wont turn over
try taking an insulated screw driver and jumping across both terminals on the solenoid, if the engine turns over, the solenoid is bad and will need to be replaced
Posted on May 03, 2009
pippall
  • 1486 Answers
SOURCE: my rzt 50 series cub cadet zero turn mower slows
The saftey wires wont cause it to slow down.Thats more of a fuel problem.Check the carb remove and clean the float chamber.Also check advance and ****** springs are still in good working order on carb.
Posted on Jul 06, 2009
  • 202 Answers
SOURCE: Cub Cadet-Blades won't stay engaged
sounds like either a saftey switch problem or a bad drive clutch on the pto. usuallly the mower shuts down,not the blades, they may have changed this though. my best guess would be a safety sensor try calling your local cub dealer and talking to the repair person he can shed light on the problem.
Posted on Jul 24, 2009
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
  • 10865 Answers
SOURCE: cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
Posted on May 28, 2010
Cub cadet lt1046 pto will not engage . When I pull the switch it does nothing suggestions??
check under mower were it plugs into the clutch and be sure it is connected good. check fuse. test switch. test clutch. some times if you wiggle the wires going into the clutch it will engage if it does you may be able to take the clutch off and solder the wires where they are frayed.
Jun 08, 2017 | Cub Cadet Garden
LT1046 cub cadet blown clutch..what caused this with new Pto switchpto switch froze..replaced it still will not engage blades.what could blow the new clutch
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
Jun 16, 2016 | Cub Cadet Garden
My PTO on my cub cadet LT1046 wont engage.
then either the fuse is blown or you have a broken wire . LOOK for it
Aug 02, 2015 | Cub Cadet Garden
Cub cadet lt1050
Is the red light on before you engage the blade?
There may be a blown diode in the charging circuit.
Battery- If this light illuminates while the engine is
running, it indicates that the battery is in
need of a charge OR that the engine's
charging system is not generating sufficient
amperage. Refer to Battery on page 26 of
this manual for the properbattery charging
procedure or have theengine's charging
system checked by a Cub Cadet dealer.
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf
Aug 27, 2014 | Garden
Cub cadet LT-1042 blades spin when motor is turned on, pto lever does not turn on or off blades
sound like you have some wires shorted out follow the wires from the clutch back to the switch
Apr 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
No power to our Cub Cadet LT1046
pinched/shorted wires, poss a wire is rubbing the frame of the mower, check the output of the alternator and check the charging system, make all ground wires are clean and tight, check all fuses and check the fuse holder for arching, replace as nessesary......good luck
Nov 23, 2009 | Garden
Garden Logo
121 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
