Question about First Alert 2092df Waterproof 1 Hour Fire Safe with Digital Lock
First alert safe not accepting my code, won't open
Try to open it with code but the red light continues to light up. my code is correct opened it about a month ago now I'm having this problem
2 Suggested Answers
SOURCE: I have a First Alert
I wouldn't wonder if the internal back-up batteries aren't bad, check those and see if they are all OK, as if you haven't used it for 10 years this may just be a problem?
Posted on Sep 10, 2011
I have just change the batterys on my sandleford electronic safe ES23. now I can not put my same code back in. can u help me please. it has a key n a key pad as well.
Open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code, then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Jun 27, 2016 | Locks & Locksmithing
What does it mean if the red and green light flash together???
Do you have a key ??? try your combination and A or B
Open with key insert new batteries and reset combination.
Feb 14, 2015 | Honeywell Safes Top Opening Drawer Safe...
How to change code N15115
Input the new code (1-8 digits then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again Emergency Key - store in secure place NOT inside the safe. To ensure the batteries have been installed correctly test before closing the door. 2 bolt locking mechanism, opens with a digital code or emergency key. Floor or wall mountable, immediately locks out after 3 invalid code attempts. Durable steel construction, model Name 24/7 Digital Safe, material, galvanised steel. Opening the safe a. Pre-set factory code 159 b. Input 159 (the yellow light will flash and the buzzer will beep then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened Closing the safe: close the door, input the code (the green light.
Feb 01, 2015 | Home Security
How do i change my code on my safe? it is a S-25E i have keys but want 2 change the code
Try this,
NOTE: The safe needs to be upright and right side up or the locking mechanism
won't work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad -159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter "B" on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
Good luck
Thanks
Apr 29, 2011 | Office Equipment & Supplies
Have an electronic safe, am putting the correct code in but the safe is not opening and the red and yellow lights are coming on and safe is beeping. I put new batteries in but still no use.
Red light means low batteries. the only thing that worked for me was heating the safe to help the batteries recover a bit and it opened!
Feb 19, 2011 | Locks & Locksmithing
Tstat calls for heat, inducer motor comes on, ignitior glows red, gas valve opens, burners light for 5 or so seconds then go out, main blower will come on after first failure and continue to run, unit...
You are on the right track. I would suggest you change the sensor though as if it has failed it would be one of the reasons why it is shutting down the way it is as it cannot detect the flame and is closing the solenoid.
Hope this helps,
Best regards,
Dave
Nov 26, 2010 | Goodman GMS90703BXA Heater
Can't restart pool pump.
try resetting or cancel or put on manual and prime
Jul 26, 2017 | Pentair IntelliFlo VS-3050 Pump -
Cant open Sandleford Garrison Safe N15115
I have a new N15115,ES20 electronic safe,it will not accept a change of password.when new password entered it only beeps once ???
Jul 18, 2010 | Check Point Network Adapter
First Alert 2092df Waterproof 1 Hour Fire Safe with Digital Lock Logo
805 people viewed this question
Top First Alert Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a First Alert Office Equipment and Supply Expert? Answer questions, earn points and help others
