Question about Logitech Webcam
Remote stuck--can't change channel or turn off TV
I must have accidently clicked something & my remote says "The remote has now set up your system for this activity." I cannot change it, change a channel or even turn off the TV. I've tried to click on help but nothing happens. I've tried to click on stop, exit and am now so frustrated. I was watching TV & wanted to change the channel. Now it's just stuck on one channel (not what I wanted) & I can't even turn the TV off! What can I do?? Please help!!!
  • 1,555 Answers
Pull out the power plug of your TV and don't use it for few minutes. Remove batteries from your remote and keep it without batteries for few minutes. After about 15 minutes your TV and remove both will work fine.
Posted on Jun 15, 2009
I bought an RCA smart tv and it was working fine until I picked up the RCA remote to change channels and now I get "no signal" on my TV screen. How do I fix this?
What was going on before you picked up the remote? Did the remote work OK to initially turn on the TV? Where you able to change channels prior to this issue? If yes, then maybe you accidently changed the source mode of the TV via the remote?
The source mode button chooses what signal you want to use for getting a signal transmitted to your TV (E.g., antenna, HDMI, etc.) If the source button is clicked to something that is not supported (E.g., Line1, or Line2, or Line3, or a particular source like the antenna option is not set-up properly to receive a signal, then you will receive a, "no signal" message".
I
Dec 14, 2016 | RCA Televison & Video
Uncontrolled tv
Can you please check the CH+ CH- keys if any of them stuck.
Feb 18, 2008 | Televison & Video
Why is my remote control not working despite changing the batteries.
Not sure if this will help but, I recently put an antenna on the roof of my house. I don't watch TV much but wanted to enjoy some TV, but my remote locked up and the side buttons on the TV wouldn't work either. I tried changing the battery, but no luck. There's a broadcast station 64.2 that is locking up TV's & remotes. Here's the fix that a TV repair co. gave me which did break the lock of the station 64.2.
1) unplug antenna (not roof but connection from TV to wall)
2) unplug and plug back in TV
3) find a way via remote or side buttons to scan channels
4) Go to Menu
5) EZ Setup
6) Channel Set Up-Scan Channels
7) Channel Memory
8) Digital Set Up
9) Turn Skip On for 64.2 (Delete this Channel)
10) Turn off TB
11) Hook Antenna back
You may have to play with the order to acheive the end result or figure out a way to delete 64.2, but during the process you will at least unlock from being stuck on 64.2.
Good Luck if this was the same issue!
Jul 14, 2014 | Audio Players & Recorders
TV IS TURNING CHANNELS ON IT'S OWN WHAT SHOULD i DO???
Check the channel buttons on the set and make sure one of them is not stuck down. Also put the remote where it can't possibly send a signal to the tv. If it is still changing channels something internal to the set (main board...IR receiver, etc.) is the problem and you'll need to take it to a shop.
Aug 11, 2010 | Proview PA-32JK1A 32 in. LCD Television
TV setting to LINE
Look out for AV symbol in your remote if there is no indication of the LINE input. All you have to do is carefully explore and switch over. Please act with patience.. good luck
Jul 01, 2010 | Televison & Video
Will not change channels, but volume works.
try numeric keypad, if unsuccessful then try reloading TV code in remote
Mar 19, 2010 | Philips Magnavox Learning Universal Remote
My tv randomly turns on, and changes the channel... i have tried everything to get it to stop and cant, and now it just goes between channel 3 and 44 randomly
Hi my name is Roety,
I can help you with your issue ,
You either have a stuck button or a bad main board.
Running the autoscan / autoprogram with a good signal sometimes locks the TV processor to the received channels only.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Dec 01, 2009 | Televison & Video
Channel keeps changing on its own
things to try:
1 look for a remote stuck in a couch(or other near place) that is barely peaking out enough to change the channel.
2. Check that the channel up or down button is not stuck on the tv and or any remote that is set up for it.
3. Find the tv's infrared sensor and cover it with your hand or tape. If the channel changing stops then something is emitting infrared that is causing it to channel hop (occasionally security systems can cause this to happen) also some kids toys. Anything that emits infrared light basically.
once you have found the source (neighbor with the same brand tv for example) or a remote with the cushion pressing the button for you. then you will should be good.
Sep 14, 2009 | Astar LTV-2701 27 in. HD-Ready LCD...
TV keeps changing channels
Out of 30 years in the repair field, I have seen this problem maybe 4 times. Once was a stuck button on the keypad of the tv. The other time was a second remote control with a book sitting on it and it would turn the tv on and off when someone would move something on the coffee table, another time was a bad solder connections on the microprocessor on the keypad circuit board and the last time was from a humorous neighbor in an apartment complex who thought he was funny who had an all in one remote control programmed for his neighbor's tv set.
Oct 03, 2008 | RCA P52921 52" Rear Projection Television
Freak accident, won't show 75% of channels now!
I lost the manual to this set, but last night I found the Menu button on the remote. I pressed it and then clicked SetUp. There was an option for Quick SetUp of Cable/Satellite. I clicked that and it was then able to find all my cable channels again. I still do not know how we messed it up by bumping the remote -- especially when it was turned 90 degrees away from the screen -- but this has restored it. Thanks.
Jun 22, 2008 | Sharp 27K-S100 TV
Logitech Webcam Logo
100 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
