Question about Electrolux Ovens
Microwave has power but will not heat
Turntable turns etc, but no heating of product
  • 400 Answers
Several possibilities come to mind. A problem in the power supply (Careful when checking, these are very high voltage). It might be as simple as a blown fuse. The second most common thing is a bad magnetron. These are available on E-bay, and (for more money) at an appliance parts house. There are other possibilities, but they are more rare. I hope this is helpful to you.
Posted on Mar 28, 2014
bigg t
  • 640 Answers
SOURCE: Turntable not turning and microwave not working
the switches are on the left or right side or both (there may be two).locate them and theres 2 wires on the switch.jump them out.if there bad replace them as it would be a hazard issue for radiation not to.
Posted on Aug 28, 2007
ginko
  • 19396 Answers
SOURCE: Frigidaire Gallery Microwave oven
Hi there , if there was a loud bang, the problem is most likely a faulty diode.
The diode is not an expensive part, when it blows it can be seen at a glance, or tested using a multimeter.
Try entering model number here to get schematics and part price.
Posted on Apr 12, 2009
ginko
  • 19396 Answers
SOURCE: Microwave will turn on but not heat
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
  • 8 Answers
I fixed the problem with my microwave turntable motor without having to replace it. I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate. Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ?bumps? on the underside of the gear on top and washer on the bottom. Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place. If this worked for you please let me know ? karlet@bellsouth.net
Posted on Aug 21, 2009
heatman101
  • 43501 Answers
SOURCE: Model KEMS308sss microwave not heating
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 25, 2011
Scb2000 GE Advantium 240 microwave not heating
It s the magnetron tube, thats what makes the microwaves. Not a hard fix, you can order one from sundberg.com or marcone .com with your model number
Jul 19, 2012 | GE Monogram 30" 240 Volt Black Built In...
Microwave is not make food hot
Hi.
The wave emitting part inside the microwave oven is called the magnetron. The waves emitted by the magnetron generate heat in food. When the microwave is running, turntable turns and light comes on but there is no heat it means that either the magnetron is faulty or the magnetron is not getting power. When the magnetron is not getting power parts such as the high voltage diode or capacitor must be tested or replaced. Testing and repair must be carried by a technician. Here some general troubleshooting: http://www.fixya.com/support/r2096491-microwave_works_normally_but_not_heat
Regards.
Ginko
Sep 05, 2011 | Whirlpool Ovens
Do you take the turn table out when using both the microwave and the oven (combie)
No; if you're using the microwave you need to leave the turntable in to ensure the food heats evenly.
If you use just the oven or grill you can still leave the turntable in; there's no need to remove it. But you could remove it if you wanted.
Jul 25, 2011 | Ovens
Microwave will not heat. Turntable does not move. Lights come on and fan is working. Ideas?
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Apr 14, 2011 | Ovens
Model KEMS308sss microwave not heating - light comes on, turntable works but no heating. Unit is 4 months old.
heatman101
Nov 13, 2010 | KitchenAid Architect II KEMS308SSS...
The Microwave equipment does not heat any thing when placed on the turntable. The turntable rotates, all the functions appears to be in place , but food does not get heated / cooked Model CE 945G (...
first check the HT fuse enlosed in a black or gray case or the micro switches at the door is faulty, if ok then the magnetron is dead and need replacement.
Aug 06, 2010 | Ovens
Sharp MW won't shut off
Sounds like it needs a new electronic board or PCB. Although I would consider a new microwave as your microwave is getting on in age and can be a danger to health or dangerous if something blows up.
Jun 14, 2009 | Ovens
Sep 11, 2007 | GE JTP85 Electric Double Oven
Aug 28, 2007 | GE JKP85 Electric Double Oven
No heat or rotate
did you check the door switches?
Aug 18, 2007 | GE JKP85 Electric Double Oven
Ovens Logo
47 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
