Question about U-Line Icemaker
Ice maker calls for water before the last water makes ice.
  • Denny Hagood
    Denny Hagood Apr 01, 2014
    The ice maker model # is ULN-B195BTP-03 I have already put a new solenoid and a new ice maker the freezer is at 10 degrees It calls for water then about 5 minutes later calls for water again and runs out is bucket. any suggestions can only help.
  • U-Line Master
  • 842 Answers
I recently ran into this issue at our shop, I called the factory and they suggested to replace the thermostats and temp control to the ice maker. This was not the case, apparently there are two different ice makers that look identical but they are different in how they run. Verify you have installed the correct one for this unit, or this issue can happen.
Good Luck
Posted on Apr 02, 2014
3 Suggested Answers
jonniewalker
  • 1031 Answers
SOURCE: water runs over ice maker but, ice doesn't form
The majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3). 3193_1.gif
1-Begin the repair by unplugging the refrigerator and shutting off the water flow to the icemaker. 3193_3.gif
2-The icemaker's water valve is attached to the refrigerator cabinet by means of a bracket. Remove the bracket screws. To test the solenoid valve, use a multimeter (also called a volt-ohm meter). Set the meter to the RX-100 scale. Touch the probes to each terminal on the solenoid coil (Fig. 4). The meter should read in the range of 200 to 500 ohms. If the meter needle does not move, the coil is bad. You may be able to purchase the coil separately from the valve. If not, you will need to replace the entire valve. An icemaker valve costs about $30 to $50 from the manufacturer or an appliance parts distributor. If the coil tests okay, the inlet filter is probably clogged. To clean the filter, first remove the large brass nut on the inlet side of the valve. Then gently pry the screen out with a small screwdriver. Clean the screen using an old toothbrush (Fig. 5). Rinse the filter clean, reassemble the valve and install it. Before installing the back panel on the refrigerator cabinet, test run the icemaker. Look for leaks, and tighten any leaky connections. If necessary, use Teflon tape or a similar product to ensure tight connections. Discard the first ice cubes that are produced because they are likely to have sediment in them. 3193_4.gif
3-Two wires supply power to the valve. Gently disconnect the wires to test the solenoid coil's resistance. 3193_5.gif
4-The multimeter will read 200 to 500 ohms if the coil is good. If the meter's needle does not move, the coil is open. 3193_6.gif
5-If the solenoid coil is not malfunctioning, disassemble the valve and gently clean its inlet screen using an old toothbrush.
Posted on May 25, 2008
heatman101
  • 43501 Answers
SOURCE: Ice Maker not making ice
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Jun 09, 2010
Frigidaire side by side won't make ice but water comes from the dispenser
you either have a bad water valve,bad ice maker,also when was the last time you changed the filter?if it has a whirlpool ice maker you can pop off the cover on the ice maker,jump out the ice maker by sticking a jumper wire into the t and h,let it run for 15 to 20 seconds and pull the wire out,the ice maker should keep spinning,if it does go all the way around the water should come in when the white arms are at 11 oclock,if the water doesn't fill into the ice maker you can jump out the water valve from the ice maker,it says to jump it out from v to n but i jump it from v to L,if it fills with water the ice maker is bad,no water the valve is bad.you have a double valve,one for the dispenser and one for the ice maker but if one fails you have to change out the valve and it comes with both.next time send the full model number off of the machine and i can look it up and see what valve and ice maker is on your machine,when you find out what the problem is,call your parts store,give them the model number and they'll sell you the correct part.http://fixitnow.com/wp/2010/09/05/whirlpool-built-modular-icemaker-wiring-diagram-and-test-points/ copy and paste and it will show you how to jump out the ice maker.
Nov 14, 2011 | Refrigerators
Water from ice tray is leaking onto ice and making ice cubes become melted together.
Most of the times the solenoid is leaking (electric valve that lets water to the ice maker when it calls for it) and when the ice maker calls for water it' ll overflood.To make sure this is the problem , shut of the ice maker and next day look inside of it , if is water , the solenoid is leaking and has to be replaced , if not the problem is with the ice maker and has to be repair or replaced.
Sep 30, 2009 | LG Refrigerators
GE ice maker, solid ice in ice maker
Many ice makers have an adjustment screw behind the front cover that shows plus or minus. Try the minus turn of the screw that should shorten the amount of time the ice maker fills. If electronic please call the company you purchased it from and explain the problem. Sea Breeze
Jul 23, 2009 | GE Refrigerators
My icemaker is not working. Water not filling tray
Probably the valve that feeds water to the ice maker leaks and this water freezes up at the filling tube to the ice maker and the water doesn't go through, but if the filling tube is not frozen and the ice maker doesn't call for water the problem is in the ice maker inside board ,if so you should replace the ice maker.
Jul 14, 2009 | Refrigerators
Water leaks from ice maker in ice tray.
When the ice maker calls for water it'll be filling for about 7 seconds if is more the ice maker inside control board is bad , but if there's water in the ice maker all the timeeven after or before it calls for water it means that the water valve (solenoid) that supplies water to the ice maker is leaking and you have to replace it.
Apr 27, 2009 | GALAXY Microsystems 25.4 cu. ft....
Ice maker works but no water comes out from the ice maker coil
The solenoid valve that supplies water to the ice maker is leaking,so the water get frozen and when the ice maker call for water it doesnt get through,you need to replace that solenid valve.
Apr 07, 2009 | Whirlpool ED5VHGXM Side by Side...
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 04, 2008 | Frigidaire PLRS267ZAB Side by Side...
Ice maker fails to make ice intermittantly
Jul 02, 2008 | Whirlpool Refrigerators
Ice maker doesn't work
I have the same problem. I've had the freezer for 2 years & ice maker just stopped making ice this week. Freezer works O.K.
Jan 11, 2008 | Frigidaire 20.6 cu. ft. Top Freezer...
U-Line Icemaker Logo
51 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
