Question about Health Concerns BioStrong 90t
Does biostrong affect ringing in the ears?
I am having a problem with ringing in my ears. I have been taking biostrong. could this make it worse?
Why is there blue smoke coming from the exhaust, worse when accelerating and also very sluggish on hills
Usually this is oil burning. The oil rings on the pistons are often at fault if performance is affected. If the oil seals on the valves were the problem, you would get blue smoke with little or no affect on performance until the sparkplugs fouled.
There are some newer additives on the market which claim to chemically replate the cylinder surfaces. Be sure to have clean oil and filter at the start of treatment for these products. The more expensive products may work.
Jul 27, 2014 | Ford Focus Cars & Trucks
When I fly abroad I get a weird pain in my ears and they feel all blocked. Is there anything I can do about it?
when a plane ascends and descends, it affects the pressure in your ears and this can make them feel blocked and sometimes very painful. You should try yawning and swallowing. Some people find that chewing gum is really helpful to use when the plane is taking off or landing.
If you have a cold or cough, you should take a decongestant before you fly to try and minimize the discomfort.
Feb 20, 2013 | Health & Beauty
If I use the headphones from my iPod when I cut my lawn, will it protect my ears.
Nope - headphones do nothing to protect ears from loud noise. Actually they can make it worse as listening to loud music directly in the ears can be quite dangerous.
Gassy on my left side under my ribs and below for 4days and a mix of constipation and diarrhea.
Common ibuprofen side effects may include:
  • upset stomach, mild heartburn, nausea, vomiting;
  • bloating, gas, diarrhea, constipation;
  • dizziness, headache, nervousness;
  • mild itching or rash; or.
  • ringing in your ears.
Ibuprofen Uses, Dosage & Side Effects - Drugs.com
https://www.drugs.com/ibuprofen.html
ibuprofen 800 mg side effects Google Search
Dec 09, 2017 | Dk Multimedia AMA Family Medical Guide...
Bold 9000 only rings through the ear piece when it is connect. Does ring when disconnected to ear piece. When ear piece is not in my ear, I can not hear the phone ring.
Hi, what makes it when disconnected to ear piece. When ear piece is not in my ear, you can not hear the phone ring is because the ringer of the phone that makes you know when there is an incoming call on your cell phone or a message alert tone on your cell phone is damaged and does not work and makes sound to notify you .
The ringer is a tiny speaker inside the cell phone that allows you to hear incoming call from your cell phone You will need to replace the ringer inside the cell phone ....
When you replace with another ringer (speaker inside the cell phone),phone will be Ok again.
Would advice that you contact an expert in phone repairs for asistance,that will do you good to prevent more damaged on the phone...
Take care.....
Feb 09, 2011 | RIM BlackBerry Bold 9000 Smartphone
One of my headphones only makes noise when pressed on with force
Sounds like the conductive cable is about to go bye-bye.
My previous in-ear started to behave like this after about a year and a half of use.At first,if I pressed or moved its body around may solved it.But about a week later,the right ear went completely silent regardless how I fussed on it.
If the symptom gets worse and worse as time goes by,you'd better look for the new earphones.
Jul 24, 2010 | Skull Candy Smokin' Buds Headphones
Unbearably loud motor-- refrigerator runs almost constantly. All vents have been cleaned (vacuumed) and cleared but doesn't help.
The compressor in your refrigerator is probably worn out, the compressor is just like a small piston engine and the piston and rings could be worn out, allowing refrigerant to pass the rings.
The valves could also be worn out allowing the same as above, the long running time is down to the unit trying to cool to the set point, you will find it will get worse as time goes on.
Time to buy a new one.... it is not cost affective to have someone install a new compressor in the old unit.
Aug 23, 2009 | Hotpoint Refrigerators
How do I remove the burr grinder for cleaning? Saeco Royal Exclusive
This is not a hard procedure, but you have to feel comfortable with DIY projects.
First empty the bean container. Vacuum out any remaining beans. Remove the philips screws from the hopper. Lift the hopper off. Vacuum any loose beans out. Remove the rubber gasket. You may clean this with a mild soap solution. Remove the grind adjustment lever- lift straight up with index fingers under the flange. Turn the outer ring with the holes counterclockwise, lift the center ring with the ears straight up when the outer ring is loose enough. The ring with the ears is the upper burr. Clean with a brush. Don't use water or other solutions. Vacuum the beans chamber and brush clean. Replace the upper burr ring matching the ears with the grooves. Turn the outer ring clockwise until it stops. Pull the inner ring to be sure it is locked. Now turn the outer ring back 13 clicks. Replace the rubber gasket. Replace the grinder adjustment lever- drop the lever flange inside on the outer ring with the lever grip loop over the top at #4. Press the flange with two fingers while supporting the outer ring from below. This seems tricky, but be patient. Replace the hopper and screws. Do any grinder adjustments while grinder is running with beans, it may take a few shots to be back at your preference grind! Good luck!
Dec 09, 2008 | Saeco Royal Exclusive 30153 Espresso...
Cannot Hear the call..on ear piece
yes those things like that will affect the ear piece or maybe you accedentally press the volume of your cell phone because of the holster first to remove the holster before you do something to your phone
Apr 07, 2008 | Motorola Mobility RAZR V3
Health Concerns BioStrong 90t Logo
74 people viewed this question
Top Health Concerns Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health Concerns Health and Beauty Expert? Answer questions, earn points and help others
