Question about Philips HTS3011/05 Theater System
How to connect phillips HTS3011 with pc?
Please guide me
How i connect it to my pc i have VGA and HDMI?
HDMI to DVI converter or S-Link component or coaxial to analog converter
Aug 29, 2014 | Philips HTS3011/05 Theater System
Hello, I have jusy bought a HTS3011 home theatre system, but I had try to play a lot of dvd s, and I had an error related to the disc regionin the most part of the discs I tried. Can someone help me? As I...
Hello Patricia -
Please follow the instructions below for unlocking your Philips HTS3011
1. Switch on the DVD player
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the DVD player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Regards,
BElectric
May 01, 2011 | Televison & Video
Not all dvd's can be played by my Philips home theater HTS3011
Disc maybe dirty. Rinse under hot tap water, then block off water droplets, before running the disc again.
Jan 03, 2011 | Philips HTS3011/05 Theater System
I need the code for a sharp tv with the phillips universal remote
The codes are specific to the model, and Phillips makes several different models. Phillips codes are available here:
http://www.urc.philips.com/
Once you find your remote control in their list, if there is no obvious list of codes, try the Quick Start Guide or the User Manual.
If the guide for your specific remote doesn't have Sharp televisions in the list, try codes 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 2550, and 0813.
If none of these work, please reply with your specific television and remote control models.
May 31, 2010 | Philips Universal PH301S Remote Control
How do I install my Phillips USB phone on my Vista PC?
You would have got a Drivers CD with your Phillips USB phone. Place the drivers CD in your CD/DVD rom drive and when the CD window opens you will get a drivers folder or else install or setup file. double click on it the driver will start installing on your PC. In each window click next tab and atlast click at the finish tab. your usb driver phone will be installed with the normal settings. Atlast, if the installation wizard asks you to start the computer please restart it so as to ensure that your USB phone works accordingly. Then whenever you like to connect your USB phone to the PC just connect the USB cable of the phone to the USB port and then in your phone if it prompts any connectivity options select the connect PC option.
Sep 12, 2009 | Computers & Internet
Trying to reset a PCto factory defaults
There is a neat site:
http://www.user-guides.co.uk/asp/search.asp?keywords=User+Guides+Phillips+MT2400&recor=1
They have everything you need. Look at the Bios jumper ad reset it.
Hope this helps.
Jan 27, 2009 | Computers & Internet
I am tryin to connect my Phillips HTS3011/05 home cinema system to my Technika LCD32-207 tv. It works fine if i watch a dvd, but it doesnt work when i play my Xbox 360 through its HD cable, or watch normal...
My TV has a Output port, It is only output for sound, IF you TV has this, then you need to use those, But i dono if it would have them, If it dosent the you will not be able to use the surround for everything without Plugging it in as you use it,
Nov 25, 2008 | Televison & Video
Device manager
Go to the phillips website and go to the support page. From here you can download the software from the disc by searching your specific model
Jul 29, 2008 | Philips GoGear HDD075/17 MP3 Player
Mp3 player
please help my player to work again
Jun 05, 2008 | Philips GoGear HDD6330 MP3 Player
Philips HTS3011/05 Theater System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
