Question about Fujitsu Siemens PRIMERGY TX200 Server
Tx200 boot error scan adapter
When I startup the server, there is an error saying "Scan Adapter" / press F2 for Bios...does anyone know what should I do to turn it up and running?
2 Suggested Answers
macquazi
  • 7 Answers
SOURCE: I cannot enter the BIOS
Are you sure that it is F2 to get into the BIOS? Try plugging an external USB keyboard to see if the key press is detected
Posted on Dec 16, 2015
All i keep seeing is disk error occurred press ctrl+alt+del to restart then press f2 for set up
On Booting Try Enter Bios Setup F10, F2 or Delete for Old PC or Google how to enter Bios if u cant.. Look for disk scan or disk Diagnostic. After full scan if error still showing then replace the DISK.
Mar 25, 2016 | Gateway LT Series LT4010U Intel Atom N2600...
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
Will not turn on
Welcome to the Community. Press the F2 key at the Dell Logo on startup to load into the Bios, and check what does it say next to AC adapter, if it says unknown, try another working adapter. If the working adapter works then its an issue with your ac adapter, if it says unknown in the BIOS then its a motherboard failure. Still having Problem Then follow Us For
Brother Printer Support
Mar 23, 2014 | Brother PT-1750 Personal P-Touch Labeling...
Bios setting probleme
you can not press the F12 or F2 Key at startup ....You need to hold the key down abd bios will open of boot order if F12 is pressed.
So hold the key down(F2,F12) then press the power key...keeping the F key pressed down.
Good Luck
Jun 19, 2013 | 10 10 Computer Network adapter Cable...
When I turn on my Dell Inspiron 910 mini, it says tht media test failure, check cable. Operating system not found. Can somebody help me? I dnt know what to do
check the Boot order in the BIOS and make sure that is isn't set to Boot from LAN or Network first as the error "PXE *** Media Test Failure" ( where *** refers to the NIC card ID )
does in fact refer to a pc that is trying to Boot from the LAN or Network first.
If your boot order is set to boot from your Hard Drive first then I would suspect a bad Hard Drive.
Reboot your computer.
This is necessary, as entering the BIOS utility requires that you be outside of your normal operating system.
Press the key indicated during the startup messages to enter the BIOS.
This is traditionally either the "Esc / Delete" or of the "F2" key, but it can be anything, so pay attention to the screen as your computer loads up.
Navigate through the BIOS menu screens, using the arrow keys navigate to advanced bios features press enter to which device has been set to boot from.
using the arrow keys load failsafe defaults or load optimized defaults this will change the boot order press escape then press f10 to save to cmos to restart
hope this helps
Oct 02, 2012 | Dell Inspiron Mini 910 Laptop AC Adapter...
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
***IF THE NOTEBOOK HAS POWER BUT WONT BOOT INTO OPERATING SYSTEM-
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
I have an Acer Aspire One notebook. I cant seem to start it. I turn it on and this displays : Check cable connection..! PXE-E63 : Error while initializing the NIC PXE-M0F : Exiting Intel PXE ROM. No...
It happens when no boot device is selected, the default is network boot first, you must select CDROM/DVDROM or HD as your first startup device. boot up machine and enter bios setup think its F2 key to enter bios generally it del or f1 or f2 it may say onscreen at start if f2 doesnt work
in the bios set boot order to HD as firstboot option then save and exit
hope this helps
dont know if all acers do this but also if you press f12 on boot up it gives you current boot options select HD that way is current boot and would have to be done everytime
Nov 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Dell Inspiron 1545 AC Adapter error message
-check the system battery information and charger information of the computer; restart the computer, while the computer is booting up, press F2 repeatedly; check "battery info"
-if it stated ac adapter = unknown device ; update the BIOS (-visit support.dell.com
NOTE:other computers may have different BIOS, if it is not the same you may have to consult manufacturer
-click on drivers and downloads
-click or choose by service tag
-download the BIOS and install it on the computer)
-check information after updating; if same message AC adapter = unknown device; call manufaturer for a replacement AC adapter, if status has changed it is a battery problem or motherboard, contact manufacturer to test battery
Sep 29, 2009 | Dell Inspiron 1545 Notebook
What else?
You need to go into BIOS by pressing F2 at startup and then choose the option saying restore defaults.
Once this is done. Visit the manufacturer's website and the download the latest BIOS. Once this is done the AC adapter will be recognized. It has nothing to do with the Hardware itself
Sep 12, 2009 | HP Pavilion dv6628us notebook
Setting boot sequence
press Del or F2 or Esc while booting ..
Feb 17, 2009 | Systemax ™ Mission Xeon™...
Fujitsu Siemens PRIMERGY TX200 Server Logo
52 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
