Question about Toshiba 37X3030D 37 in. LCD TV/HD Combo
Toshiba 37X3030D TV. Screen fails to light, sound OK.
Screen fails to light, Sound OK.
    Problem Solver:
  • 11 Answers
That'll be the inverter board. It might be the 6632L-0490A made by LG Philips. If it is, you'll find the 2 capacitors have leaked and a bit has blown out of the chip. The inverter board is hidden behind the main board on the 505 model.
Posted on Jun 08, 2014
pazman
  • 81 Answers
SOURCE: Toshiba 37X3030D 37" HD Full 1080P Freeview LCD TV Faulty FAULTY
alot, not worth fixing.
Posted on Apr 08, 2008
SOURCE: Toshiba 50HP66 Plasma TV
Found that video 1 and video 2 switching does not work. The switching IC was HOT!. Then found a third video input works but no sound. Hooked -up sound output of DVD player to amplified loudspkr and it works, I hate to throw away a 2 year-old plasma TV when TV and cable still works.
Thanks for the offer anyway.
Mike
Posted on Oct 14, 2008
SOURCE: Toshiba 37X3030D LCD TV
no, the tv has a setting that auto changes the screen ratio. you can turn the auto screen ratio off in the settings section. Once you have turned it off put ratio to 16:9 and it will solve the problem.
Posted on Dec 18, 2008
  • 50 Answers
SOURCE: Toshiba 42" plasma tv 42HP66. All of a sudden, no picture.
Hello, You may have a bad power supply! Its hard to say! I need more info! please feel free to call or message me if you would like more help with your TV!
Thank you!
Dave
1-503-432-9904
pleasefixitdave@yahoo.com
Posted on Aug 26, 2009
VinayT
  • 1884 Answers
SOURCE: Toshiba 50HP16 Plasma tv has
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Posted on Oct 07, 2009
Toshiba no picture
Check and replace damaged component/s at its back-light inverter stage circuit, or replace the back-light inverter board. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 27, 2014 | Toshiba 37X3030D 37 in. LCD TV/HD Combo
Sound but no picture
This could be a problem in the vertical sweep circuit, as when the vertical circuit fails, The video or screen will blank out so the picture tubes do not get damaged. In this chassis, I have seen the convergence IC's cause this, or the capacitor in the sweep power supply that feeds the voltage to the vertical IC has failed and blew out the vertical output IC. If you have no solid state repair experience, play it safe and call in a trained tech to assist you in this repair. Good Luck.
Aug 11, 2007 | Toshiba 43AX60 43" Rear Projection...
No pic no sound, but power on
Apparently power is getting to your TV but the internal power supply has failed
May 18, 2013 | Toshiba 55G300U TV
Toshiba 3030
Connect TV to a different input device. If it works it is a problem with the set top box or cable. Look for any loose contacts in the RC Cable or RF Cable. Show a torch light on the screen when the program is on and if you can see the picture, the backlight is not getting on. This may need attention by a qualified service technician.
Jul 21, 2012 | Toshiba 37X3030D 37 in. LCD TV/HD Combo
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Toshiba 50HP16 Plasma tv has sound, no picture. Screen is flashing like a camera flash....on-off at random. Volume works with remote. No menu. Screen flickers/flashes. Power light in front is green. TV is...
Oct 07, 2009 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Jun 17, 2008 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Sound Problem
hi there, i turned the bass boost down by '5' and also put bolts in the rear support holes to stop the case vibrating. Pain the the a** I know but it works.
Feb 09, 2008 | Televison & Video
Toshiba 37X3030D 37 in. LCD TV/HD Combo Logo
101 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
