Question about Canon Office Equipment & Supplies
Reset drum ir2530
How to reset drum for canon ir2530
I have Canon Ir2530,i take off the memory chip from the board than I put it back to the slot,when I turn on the machine is showing power light only without lighting on the LCD.help please
Ensure the memory stick was not damaged by static when removing and replacing it by grounding the board and yourself before touching it as it is a non buffered CMOS type and easily damaged. Check it is installed correctly.
Dec 19, 2016 | Canon Office Equipment & Supplies
ERREUR copieur canon ir2530 E000020
it is related to toner supply.
follow rhis process..
Additional funciton 2+8
go in clear
after that engine
and in this prss ok in tnrinstall.
May 02, 2011 | Canon ImageRunner 3025 Black and White...
Machine show an error E000002 Model iR2530 Canon Imagerunner
these means the reading of the main thermistor is less than 115 deg C
continuously for 400 msec 1.3 sec after it has indicated 100
deg C.
2.The reading of the main thermistor is less than 150 deg C
continuously for 400 msec 1.3 sec after it has indicated 140
deg C.
Go through the following to clear the error: CLEAR >
ENGIN > ERRCLR; and then turn OFF and then ON the
power.
TO ENTER SERVICE MODE:
press *
press 2
press 8
press *
If you cant clear the error code these means that you need to replace fixing heater.
Hope that helps!
Aug 19, 2010 | Canon Office Equipment & Supplies
Error Code E00002-01c0
you probably mean E000020-01c0 bad yellow drum codes in order 01Y 02C 03M 04B
Apr 10, 2009 | Canon imageRUNNER C3200 Copier
Reseting xerox drum chip xerox 5834/vivace 340
you should change drum chip then fix your problem
Apr 01, 2009 | Xerox Office Equipment & Supplies
Canon 8180C laser Multi Function printer Error Code 078
did you reset the drum unit on maintanance counter of the machine?
Apr 18, 2008 | Canon MF8180C Color Copier
Canon Image Runner C3200 GPR 11 Drum Units
error code eo-20 on canon pc740 without replacing drum/toner unit
Nov 05, 2007 | Office Equipment & Supplies
old marine
old marine
