Question about Health & Beauty
Life brand MD 14780
Different readings when used
Can you repaire sr-70?
To be honest it probably is not cost effictive to repair any but the most expensive MD decks.
I'd suggest you look for a working twin to yours on ebay and buy it.
I spent $350 to get a high end MD deck repaired and the repair only lasted six months. This is even more true with portables.
Watch out for any portable with odd rechargable batteries, there are several legendary protables which cannot be used as the batteries have not been made in years. Replacements if found are overly expensive and probably old, used replacements have little life left in them.
Mar 09, 2014 | Sharp Md-sr60 Md Portable Recorder...
SONY MDS JE 530. (C14) Toc error.
You may well be right. Try a different brand of disc.
Apr 01, 2013 | Sony MDS-JE330 Mini Disc Player
I have an Ativa MD 460 shredder, it is misaligned with paper. Can you help?
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
Just purchased ativa MD 460C and it will not work. misaligned
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
Jun 07, 2011 | Office Depot Office Equipment & Supplies
Kenwood MD plays ok but recordings fail to play; U TOC error?
Without a decent Table Of Contents, your MiniDisc will NOT work, as you've found out. Does it matter what brand of MD you use? I would record it at "1X" and NOT 4x speed too. Try erasing a blank minidisc first and then shut off the unit and then turn it back on and see if the TOC works. Try adding a title, then turn it off and back on. Then try the CD to MD.
Jan 16, 2010 | Audio Players & Recorders
My family got angry with me always why?
Try reading " Change your Brain , Change your life.
By DR.Daniel G. Amen MD
Nov 06, 2009 | Family Care HM1555 Humidifier
I have a sony mini disc recorder walkman mz-n505, and it is skipping out in ten to twenty second intervals when traveling on my bike. It has never done this in the past, do you think it needs cleaned? It...
Unfortunately this is usually the sign of a failing read/record head unit.
MD players don't work like CD players in that the disc is not constantly spinning and the head is not constantly reading. Instead, the disc spins up and the head reads enough information into memory to play; if there is an error in reading the info the head will make multiple attempts to retrieve the data until it's complete. normally this is highly successful and is why MD players are usually regarded as the best electro-mechanical music delivery system for runners, cyclists and any other moving application.
When the head mechanism wears out the errors increase and the head has to oversample frequently to get the data. Eventually it's doing this so often that it can't also cope with the additional requirements of being in a moving environment and runs out of data, causing skipping and black outs. At the moment your player is fine when stationary but you'll soon find that it will begin to skip even under those conditions.
MD head cleaners are available, but I stopped using them years ago as they are a waste of money. MD's themselves have protective covers which prevent the disc from getting dirty, this also means that they do not transfer dirt to the heads. MD units also do not open all the way like most CD units, so there is no opportunity to accidentally touch the heads. In practice, you'll only find an MD cleaner to be of potential use if you live in a very dusty environment. In most cases if the MD head has actually got dirty enough to need cleaning then an MD cleaner simply isn't man enough for the job.
Replacement heads are rarely available these days and even when they are they're a 'mare to replace. I'd suggest looking out for a free/cheap replacement player. FreeCycle often has free examples which I've sometimes found to be boxed and unused as MD wasn't everyone's cup of tea. This is great for the likes of us as it also means that there are plenty of cheap MD units around as well and also lots of free/cheap used discs (although not all can be erased and re-recorded on).
Oct 01, 2009 | Tascam Dp-02cf Digital 8-track Recorder
Where to purchase Minolta MD/MC lens to Sony A700 adapter in Australia
the best way to get lens to go the nearest outlet of the brand choice, this is to ensure you're getting the right and secure product and avoid getting you're camera malfunction.
Sep 15, 2009 | Cameras
Sony minidisc MDS-JE530 c13 rec error
This could be a solution for your problem, if you get a C13 error it's because of dust on the lens causing TOC read errors. Try blowing out dust using clean compressed air (the kind in the can used for computer maintenance).
Aug 02, 2009 | Sony MDS-JE330 Mini Disc Player
RECYCLING of ALPS MD-1000 Color Printer
You can buy OKI MD 5000 Cartridges or Citizen Printiva Cartridges. Are the same.
There are also resellers that sells only ribbons to exchange in cartridges. http://www.refillx.com/
Dec 16, 2007 | Alps MD 1000 Thermal Printer
Health & Beauty Logo
48 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
