Rinnai convector 400
Recntly pulled out old heater... alarm always sounds untill it gets warm. soon as the cover is on, alarm sounds and shuts down.
Therinnaiguy
  • 1420 Answers
SOURCE: Child lock
Press and hold down on the lock button and wait for a beep.
Posted on Aug 07, 2008
SOURCE: rinnai convector 516TR
Hi This is happening to us and I called Rinnai... they suggested that if anyone either in our apartment or an ajoining one has painted walls or varnished a floor that the convection heater picks up the smell and the only way to get rid of it is to burn it off by running the heater for several hours in a well ventalated room...
I am going to try it tomorrow.
will let you know
Posted on Aug 19, 2008
SOURCE: Rinnai Convector 404 Natural Gas
I have a natural gas unit. do you want to swap? 0407284314
Posted on Dec 26, 2009
  • 82 Answers
SOURCE: RINNAI CONVECTOR 417 Natural gas heater 17.5 MJ Wanting to know if this is a decent model. Anything that may cause you to avoid buying this model? And about how old would this model be?
The 417 service manual is dated 2003, so they're no more than 7 years old.  You can download the operation & service manuals here:
www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/161.pdf
www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/161.pdf
Posted on Mar 29, 2010
SOURCE: Dimplex Convector Heater EPX1000 turns off by itself
I have the same problem with 3 of the 5 EPX1000s I have fitted in my flat, although mine don't even warm up. They just immediately turn themselves off. My only conclusion is that they are rubbish. Specifically, the so-called overheat protection doesn't work. Avoid.
Posted on Dec 08, 2010
Now the alarm won't switch off after the battery died
Disconnect the battery and fully recharge it. Reconnect the battery.
you could also try holding the Lock button or holding the Open button. Each alarm system have slightly different ways to reset.
Aug 22, 2015 | 2001 Chrysler Voyager
Jamdy RS Shuts off heater too soon
when using the aqualink make sure heater is in tstat mode if not for your heater then turn heater all the way up make sure the wires are connected to pool and com then make sure the wires 5and 6 are connected to the heater then the aqualink will command heat if the red light is lit on controller
Feb 10, 2014 | Jandy 7953 AquaLink RS One Touch Control...
An alarm or sound continues to run even after i turn car off running my battery down
First you have to determine what the sound/alarm is coming from. If you have no clue, you can always pull one fuse at a time until the sound/alarm stops. Then look up what that fuse controls and you have a place to start troubleshooting what is wrong.
Oct 01, 2011 | 1994 Jeep Grand Cherokee
Car warms up then will not start again until the car cools down. It has a new starter, new battery. but it has this aftermarket alarm & remote start that was a problem, wondering if I should rip out...
I'm not sure. But I know some remote starter only run for awhile the shut down.. It also could be the distributor module. When it gets warm it shuts down your engine.. I hoped this helped a little.
Mar 11, 2010 | 2004 Nissan Sentra
Reddy heater
Sounds like you need to adjust the airflow so that it is getting enough air to burn.
Jan 10, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
1989sunbird starts cold then shuts down electricly when warmed up
i would recheck the ignition module, sound bad to me. make sure that you test the module when hot
Apr 20, 2009 | 1989 Pontiac Sunbird
Pontiac Grand Prix 2003 heater problems
Sounds like coolant system is starting to clog. Have system flushed and thermostat replaced.
Apr 02, 2009 | 2003 Pontiac Grand Prix
Fahrenheat fuh 54 b does not run long enough to get garage warm
have you checked what the operating amps are vs. the amps provided by the outlet. Sounds like you are trying to pull to much load and the machine probably has a saftey to where it shuts down bofore it buns itself up. Hope this helps. You have to be real careful about overloading circuts.
Dec 19, 2008 | Fahrenheat Ceiling-Mount Industrial Heater...
Heater shuts itself totaly off as soon as the room is warm
Difficult to guess what the problem might be due to the amount of electronics the unit has that could cause inconsistent or illogical functioning.
I noted one product review that said "if the room is too large the auto shutdown will engage".
I suggest you revisit the instruction manual and specifications before deciding whether to call a service engineer....
Sep 24, 2017 | Bionaire BCH-4138 Ceramic Compact Heater
Heating & Cooling Logo
264 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
