Question about Peachtree Software Sage Peachtree Premium Accounting 2012
F4BF-7684-01F6-E71A-6AC0 ACTIVATION KEY
What does activation key mean?
I am assuming by the category title that you are asking about an activation key for an Operating System. An Activation Key is something like a serial number. The OS manufacturer provides the activation key to provide copyright protection and prevent software piracy. Each key can only be used one (or as often as the OS manufacturer allows). Until you enter the key, the software is not considered activated. This may, depending upon the software, have restrictions. For example, Windows gives you 30 days to activate Windows OS. After that, it essentially shuts down, restricting use to very limited activities until the activation key is obtained and entered.
Mar 12, 2015 | Computers & Internet
Windows 8.1 pro activation key required
If you have a legal copy, then get in touch with the maker.
Mar 06, 2014 | WinZip 12.0 - Windows for PC
Regsvr32 jscript.dll is deleted
Method 1: Reregister Jscript.dll
  1. Click Start, and then click Run.
  2. In the Open box, type regsvr32 jscript.dll, and then click OK.
  3. Click OK.
If the file does not register as expected, or if you receive an error message, the system file may be missing or damaged. To extract the missing file in Windows XP, follow these steps:
  2. In the Open box, type msconfig, and then click OK.
  3. Click Expand File.
  4. In the File to restore box, type the name of the file that you want to restore.
  5. In the Restore from box, type the path of the Windows XP .cab file where you want to restore the file, or click Browse From to locate the Windows XP .cab file.
    Note The Windows XP .cab files are stored in the I386 folder on the Windows XP CD.
  6. In the Save file in box, type the path where you want to extract the new file, or click Browse To to locate the folder that you want.
  7. Click Expand.
  8. In the System Configuration Utility dialog box, click OK. If you are prompted to restart the computer, click Restart.
Open a dialog box that previously experienced the issue that is described in the "Symptoms" section of this article. If the issue recurs, go to the next method. uparrow.gifBack to the top Method 2: Edit the registryTo do this, follow these steps.
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
  2. In the Open box, type regedit, and then click OK.
  3. Locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\CLASSES\CLSID\{f414c260-6ac0-11cf-b6d1-00aa00bbbb58}\InprocServer32 The (Default) value data should contain the following value: C:\WINDOWS\SYSTEM32\JSCRIPT.DLL If it does not, double-click Default, type C:\WINDOWS\SYSTEM32\JSCRIPT.DLL in the Value data box, and then click OK.
  4. The ThreadingModel value data should contain the following value: Both If it does not, double-click ThreadingModel, and then type Both in the Value data box.
  5. Locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\CLASSES\CLSID\{f414c261-6ac0-11cf-b6d1-00aa00bbbb58}\InprocServer32
  6. Repeat steps 3 and 4 to edit this key, and then go to step 7.
  7. Locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\CLASSES\CLSID\{f414c262-6ac0-11cf-b6d1-00aa00bbbb58}\InprocServer32
  8. Repeat steps 3 and 4 to edit this key, and then go to step 9.
  9. Exit Registry Editor.
Dec 05, 2010 | Yahoo Messenger
Activation key
Which activation key?
The operating system activation key should be on a sticker on the case of the PC once the system is installed you have to go to the Microsoft website to authenticate it within 30 days.
Software activation keys are normally on the disk cover.
Which activation key are you looking for?
Sep 13, 2010 | Computers & Internet
I NEED serial number and activation code
nstallation code- XD7YIXV9RN29PWGYKM47
Key code- DR14N4V-76PD3E9-5X7JSFL-YF6AMS4-9YG3J
Activation code - F4BF-7684-01F6-E71A-6AC0
urchase serial number: DR14N22-JKPLHYP-LP8FA8Z-BDZGFKZ-CNS56
Activation Code:B4B2-6C89-6673-E411-CC50
Serial number: DR14B98-NMPMSL9-MM7WT66-8D884F8-TBVHS
Installation code: XRRX-IXV9-RN55-7M6Y-8WC7
Activation code: 702D-92F5-40A2-1F65-E2B2
Plz try this activation code :
6E67-5CCB-B6A9-8B8F-938Bs
serial no. : DR14T22-FKTH7SJ-KN3CTHP-5BED2VW
installation code: XRP4-IXV9-RN55-QTQU-P4K7
installation code: XRRF-IXV9-RN55-3MJ4-3Y47
serial number: DR14T22-FKTH7SJ-KN3CTHP-5BED2VW
instalation code: XRPE-IXV9-RN55-JBJD-QGU8
DR14NU8-9ZLA4A8-NBD74YQ-BPC82XN-F7NVE OR DR14T22-FKTH7SJ-KN3CTHP-5BED2VW OR DR14B57HCPUL7RBXGAS2ZJH4ART388452 OR Purchase serial number: DR14N22-JKPLHYP-LP8FA8Z-BDZGFKZ-CNS56
DR14T22-FKTH7SJ-KN3CTHP-5BED2VW OR instllation Code:XQUJIXV9RN5WUNW9DFU7 Serial number:DR14N22-JKPLHYP-LP8FA8Z-BDZGFKZ-CNS56 Activation COde:0DC8-72D8-B0D8-99DB-66BF OR Purchase serial number: DR14N22-JKPLHYP-LP8FA8Z-BDZGFKZ-CNS56 Activation Code:DEFA-94A8-7270-FD9C-FFB4
Codes that worked for me,
Installation Code: XQTJIXV9RN5WKP26D8K7 (It
Sep 10, 2010 | CorelDRAW Graphics Suite X4 for PC...
Please tell me Norton 2009 Activation Key
you can download the activation key for norton 2009 here ---> www.mininova.com (search for norton activation key in mininova's search engine).
but you have to have torrent downloader before u can download anything from torrent sites like mininova. you can download the torrent downloader for free here ---> www.bittorrent.com
Good Luck!
Thank You
Jul 08, 2009 | Symantec Norton AntiVirus 2009 : Windows...
Cd activation key, faded on the bottom of laptop.
i dont know but u can use mine power dvd 6 key dv22636500118872  DXUNB-LH8HF-DAZHF-HDUR5-K9FPR-7E23E
May 18, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Activation code for kaspersky mobile antivirus
activation key: aaaaaaaaaaaaaaaaaaa3 or ppppppppppppppppppp3
Jan 20, 2009 | HTC P3300 Smartphone
Activation key
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step 1
Obtain the serial number for your security appliance by entering the following command:
hostname# show activation-key
Step 2
Access one of the following URLs.
Use the following website if you are a registered user of Cisco.com:
http://www.cisco.com/go/license
Use the following website if you are not a registered user of Cisco.com:
http://www.cisco.com/go/license/public
Step 3
Enter the following information, when prompted:
Product Authorization Key (if you have multiple keys, enter one of the keys first. You have to enter
each key as a separate process.)
The serial number of your security appliance
Your email address
An activation key is automatically generated and sent to the email address that you provide. This key
includes all features you have registered so far for permanent licenses. For VPN Flex licenses, each
license has a separate activation key.
Step 4
If you have additional Product Authorization Keys, repeat Step 3 for each Product Authorization Key.
After you enter all of the Product Authorization Keys, the final activation key provided includes all of
the permanent features you registered
Nov 12, 2008 | Cisco ASA 5510 Firewall
Peachtree Software Sage Peachtree Premium Accounting 2012 Logo
148 people viewed this question
Top Peachtree Software Computers & Internet Experts
Gene Jakominich
Gene Jakominich
Level 1 Expert
Don A
Don A
cashofy
cashofy
Are you a Peachtree Software Computer and Internet Expert? Answer questions, earn points and help others
