Question about Kitchen Appliances - Others
Repair braun toaster 4104
Dismantle
Braun new zealand
If it is not in the user manual, you should not dismantle the Brown razors. I know they are very difficult to open and a pain to reassemble. They can easily be damaged when you try to " repair" these shavers. Just send it back to Braun, or your shop. In Europe we have 2 years of warranty. If the warranty is over, please buy a new one.
Jun 29, 2014 | Braun Pulsonic Rechargeable Cordless Men's...
INSTRUCTION to dismantle toaster
Hi benbecula. I cannot find a repair manual for you. The normal way top dismantle a toaster is to remove the screws beneath the toaster. They are usually self tapping screws that hold the polished stainless steel cover to the base. The knobs on the front of the toaster have to be prised off so the cover comes off. Make sure the toaster is removed from the power before attempting and examination or repair.
Hope this helps,
Michael
Jun 04, 2014 | Russell Hobbs 13767 4Slice Toaster
Free instruction manual for bissell 4104
I've found step by step video demonstrations for cleaning, belt replacement, basically maintenance of different appliances on "YOUTUBE" you might want to check it out. Just type in Bissell 4104 beater bar replacement. Hopefully there will be a video showing you exactly how to replace it properly.
Jan 04, 2012 | Bissell 4104 Bagless Upright Cyclonic...
Tthe lever on my Braun HT 600 toaster won't stay down. 3 years old, but very moderate use. Ideas?
Be sure to unplug toaster first. While inverting your toaster, depress the toaster lever(s) and shake toaster to clear all bread crumbs. It can take up to several minutes of shaking to clear them completely, however, the key is to depress the toaster levers down at the same time. Also, remember to remove bread crumb trays and empty regularly, as the trays are too shallow and allow crumbs to build up quickly, thereby blocking the "locking mechanism" of the lever(s).
If after cleaning your toaster out thoroughly, the levers still won't remain depressed, try various outlets throughout your kitchen. Oftentimes, when one GFI (Ground Fault Indicator) trips, several outlets along the same circuit will also trip.
Also, there is a website called Manuals.com, which has a very good database of many manuals for various manufacturers and models of toasters, should all of the above efforts fail.
I did all of the above and fixed my toaster within five minutes. :- )
Good luck to you.
Yvonne
Jul 28, 2011 | Braun HT600 2-Slice Toaster
Hi - we have a problem with our TC100 toaster.
buy a new toaster or dismantle it and make sure nuthings loose their not that dear but u should complain realls
Aug 20, 2009 | Kitchen Appliances - Others
Morphy Richards coolstyle Model 44880 4 slice toster
I have the 44280 2-slice version and had similar problems. To dismantle, unscrew the two star-shaped screw heads which hold the retaining slides in place. I don't have a star socket (female), only the usual male, so I used a pair of pliers. Pull out the two chrome slides. Pull off the two knobs also using pliers. Remove the outer casing with care as there are two fine wires attached. Now you can see the problem - probably a broken or lost nylon retaining catch on the electromagnet, and probably unobtainable by an individual. At this stage I decided to buy a new toaster!
Alec
Sep 29, 2008 | Morphy Richards 44778 4-Slice Toaster
Braun 550 Toaster
Return it to vendor for replacement.
Small electricals such as Toasters, Kettles, Computer parts, Audio & Cameras and the like do not get repaired - they get replaced and the seller is the place to go.
Jan 24, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
