Question about Motorola Mobility V555 Cellular Phone
Blue tooth problem
I have 2 motorolla v555's and i cannot connect via bluetooth?  why?
0 characters
1 Points
I dont have data cable of nokia 1209 then, how i connect my mobile to my pc ?
you could connect using your bluetooth, just turn on your bluetooth and connect.
Jul 15, 2011 | Cell Phones
I am unable to my i phone to another phone is that true that i phone only connect to other i phone via blue tooth?
Its true that you cannot connect your iPhone to other mobile phones. Ive even heard you cant connect the iphone to a macbook via bluetooth. You can connect your iPhone to headsets, handfrees, speakers etc via Bluetooth.
Jan 20, 2011 | Apple iPhone Smartphone
My speaker have water damage, i can hear but they cant hear me, can i use blue tooth
Hi, a blue tooth device would allow you to hear and speak through it so it should solve your problem.
the only problem you may have is if the water damage has causes damage to bluetooth inside the phone, try choosing bluetooth on your phone and see if you can still do a search and connect with another phone, if you can still connect to another phone to say send music or picture via bluetooth then this would suggest your bluetooth is fine and using a bluetooth head set will solve your problem and allow you to use your phone again.
if you cant connect to another phone via bluetooth then the chances are it wont pick up the bluetooth head set and you would be no better off
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Dec 13, 2010 | LG enV3 VX9200 Cell Phone
I wanne play my music via bleutooth but i dont find how i need to do dhat
Bluetooth technology makes possible sound transmittion to devices without the wired connections from the device out puting the sound out put gagdget. The bluetooth technology would only perform with devices that have that functionality. For example, once the device acquired on retail has indication of being developed to handle blue tooth technology also known as wireless connectivity, simply use the device settings to enable bluetooth functions. keep in mind that, blue tooth technology workswith only blue tooth gadgets. for example, a blue tooth phone requires a bluetooth ear piecees before functionanlity can be assumed with the settings. Once decided that each devices wanting to perform a blue tooth connectivity are designed for that function, use the settings function either on the menu area to set the wireless connectivity like also known. Remember, wireless cannot access another device that does not provide signals. in other words, once each devices setting are enabled, a signal should appear maybe blue light indicating blue tooth signal has been detected.The functions of thead set requires attempting to listen to any sound during the set up process. The entire process of setting bluetoothh should not be tasking.
checks to perform 1. make sure each device is designed to handle wireless signal recognistion also known as blue tooth technology 2. the devices may need to be set to allow access from the particular devices, a function that was design so that not all signals could be received by your heard piece. In the sitaution of which absence could be noice generation interfering the receiver and possibly preventign setthings
Dec 04, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Problem in transfering file via bluetooth
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Jun 17, 2010 | Sony Ericsson K750
I just got a new iphone 3gs, having bluetooth
Hi, I have an iPhone also, you don't connect to other phones anymore, like if you did with normal mobile, if say you searched in a full room of people with the iPhone you would just find the printer in the corner!?!?, bizarre i know, but thats Apple for you, (2 steps forward, 5 backwards) you just connect to Bluetooth appliances like, your car, printer, pc/mac.. Thanks Mark
May 04, 2010 | Apple iPhone 3G
I forgot my blue tooth password
Delete the device from the phone bluetooth menu and Reconnect the device you are connecting via bluetooth and assign new password to it
If you like the solution do vote for me
Jan 06, 2009 | Nokia N70 Cellular Phone
I do not have data cable I want to connect to PC via blue tooth
Nov 12, 2008 | Nokia 6233 Cellular Phone
I recently had to get another Motorola V3a through alltel and on my new phone I am not able to use ringtones that I recieved via Bluetooth. On my old one, I was able to. The ringtones do download, but the...
download motorolla conection program then P2K commander connect your phone to the motorolla program then start the auto start on the P2K then open the P2K commander select the p2k phone system and re read find audio and change the attributes on the blue toothed sounds so that they mach the factory sounds then they will work you can also use this to delete unwanted animations and sounds to free up space on your phone and fyi Altell did this to force you to buy ringtones there sales rep confirmed this
Apr 28, 2008 | Cell Phones
Connecting a Bluetooth handsfree with the W880i
Hi, (1) Press & hold the switch of the Bluetooth handfree. (2) Now search throw ur handset via blue tooth.
Aug 26, 2007 | Sony Ericsson Walkman® W880i Cellular...
Motorola Mobility V555 Cellular Phone Logo
21 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
