Question about Panasonic DMW-MCTZ5 Marine Housing for Lumix Cameras
Panasonic DMW-MCTZ5 Manual - Panasonic DMW-MCTZ5 Marine Housing for Lumix Cameras
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
Need manual for Panasonic DMW-SDP1 photo player
You may download a copy of the manual here.
Apr 28, 2012 | Panasonic Cameras
Need a manual for a Panasonic DMW-SDP1
I have a FZ100 with aDMW-LA5 adaptor can the DMW-LW55 be fitted onto this camera using this adaptor?
I have a DMC-FZ100, DMW-LA5 adapter and an Olympus B-300 HQ 1.7x Tele Converter (instead of a DMW-LT55 - but that's another story). I also bought a DMW-LW55, thinking that I could fit it to DMW-LA5. However, looking at the LA5 Instructions, it says "(As of July 2010)The following types of lenses cannot be attached and used. Vignetting etc. may occur when taking pictures in wide)- Wide conversion lens DMW-LW55- ND filter DMW-LND55- MC protector DMW-LMC55"
This is very annoying considering that the LA5 is sold as THE adaptor for DMC-FZ100, DMC-FZ45, DMC-FZ40.
So what's the solution? A 52mm to 55mm step up filter ring? Will the wide angle lens be too close? Then there's the Panasonic DMW-LA2(E) It looks shorter than the LA5, but will there still be a vignetting problem? I am still seeking answers.
Mar 25, 2011 | Panasonic DMW-LW55 0.7x (DMWLW55) Lens...
I want to use PL filter with DMW-LW 55. Can I
No, there's always going to be a compromise.
In this case you'll find that having the wide-angle converter further from the lens will affect the angle of view a little, but the main effect will be vignetting. All you can do is try it and experiment with different aperture settings to minimise the effect. In any case, you'd be better off in every respect by mounting the DMW-LW55 directly to the adapter, and then mounting the adapter onto the filter. To do otherwise will lead to dreadful colour fringing as the adapter and wide angle converter lenses are optically matched and designed to be a particular distance apart.
Feb 26, 2010 | Panasonic DMW-LW55 0.7x (DMWLW55) Lens...
Panasonic DMW-MCTZ5 Marine Housing for Lumix Cameras Logo
65 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
