Question about GE Wall Oven Plus Microwave - Model Jtp86-30"
Jtp86 not heating - GE Wall Oven Plus Microwave - Model Jtp86-30"
MICROWAVE PLATE SPORADICALLY TURNS
Sounds like the little motor that turns the plate is about to die. Just go on line and order a new one and put it in, there not that hard to do.
Oct 14, 2014 | GE Wall Oven Plus Microwave - Model...
JTP86-30 Oven is not heating. Neither element in the oven heats. I can hear the 'click' I'd expect when it starts to heat. The fan starts up and the readout shows 100 degrees. It never changes and the...
Many GE oven control boards have a relay for the common of the broil and bake elements. This relay is notorious for being the culprit. the electronic control board will need to be replaced. You could check with corecentricsolutions.com to see if the control can be rebuilt. It is much cheaper but you will have to send the board to them for repair.
Mar 28, 2014 | GE Wall Oven Plus Microwave - Model...
GE j TP 86 oven wont heat
sounds like the hi-limit switch
Mar 02, 2013 | GE JTP86 Electric Double Oven
The oven does not heat up. the microwave work and everything in terms of the display on the oven works, but no heat.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 ][
May 08, 2011 | GE JTP86 Electric Double Oven
Hi, I have a JTP86 and microwave's plate doesn't turn. I am wondering if there is a setting that turns it off
there's a motor that turns the plate,part number WB26X172 and it's around 30 dollars.you have to pull out the microwave and remove the bottom,the stirrer motor is in the center,on some models there's an access panel that pops out and you can get at the motor that way,very easy to do.
Feb 04, 2011 | GE JTP86 Electric Double Oven
Microwave not heating food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Nov 08, 2010 | GE JTP86 Electric Double Oven
GE JTP86 30" double wall oven: microwave will not heat and turntable does not rotate. Internal light works and electronic display functioning properly. 20 amp fuse is OK. What is likely cause?
This confirms that either the thermostat or magnetron tube is shot.The tube could be more than an old microwave is worth.
The cost of the magnetron would be around $125 and the thermostat is around $25.
Here is a good repair service if you choose that route!
To schedule service or for customer service issues please call 1-800-905-9505.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 20, 2010 | GE JTP86 Electric Double Oven
Microwave doesn't heat everything else working fine...just replace capacitor and diode and still not working what else is wrong? Please help. thanks
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 14, 2010 | GE JTP86 Electric Double Oven
Oven will not heat on bake.
does the ignitor glow? if it does and the burner does not fire within 30-60 sec. replace it it is weak .if the ignitor does not come on at all youll need to check for voltage at the ignitor when the bake circut is on.
Sep 16, 2009 | GE JTP86 Electric Double Oven
GE Wall Oven Plus Microwave - Model Jtp86-30" Logo
29 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
