Question about Things Needed Blue 3.5mm Stereo Fashion Earphone Headsets with Microphone for Micromax A26 Bolt
How to connect samsung bluetooth headset(mic) BHM1100 to micromax a26 bolt
How to connect by step by step procedure
Hi....I AM using micromax A093 android phone.how can i listen to music on samsung hm1100 mono headset
Hi
Your Micromax has an audio player built in, so if your headset is working with the phone for calls then when you have music (say mp3) files in the memory, or an SD card then when you tap the music player icon the player will start and you can listen to the files that are on your phone.
The full spec for your phone can be found here:
Micromax Canvas Fire A093
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 07, 2015 | Samsung HM1100 Earset - Mono - Black -...
Samsung c3050 mobile not connecting to bluetooth handsfree device
There probably is a special procedure for connecting the second device. Consult your user manual for the headset and be sure to follow the steps precisely.
Dec 17, 2011 | Samsung C3050 Cell Phone
Hot to connect samsung wep300 bluetooth device to laptop
Firstly download PC Suite and install it on your PC then please follow these steps..
1.open to PC Suite and make sure Bluetooth must be open of both Mobile and PC
2. Select setting >Add more Phone
when detecting process will be complete then click on mobile then select next
after that follow all steps and you can connect your pc via Bluetooth with mobile...TRY IT..
Jul 10, 2011 | Samsung WEP 300 Bluetooth Headset
While i connect my wire less headset it ask passcode
1 Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200 headset. 2 Select Samsung WEP200. 3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK. 4 Enter the headset passkey or PIN, 0000.
Regards MaTi_FleSh
Jul 03, 2011 | Samsung WEP200 Wireless Headset
How to connect it to samsung seek cell phone
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
Mar 31, 2011 | Plantronics Explorer 320 Wireless Headset
How do I setup wep301 headset to a simple at&t phone
Follow the steps to connect your WEP 301 bluetooth headset to phone.
1.When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone’s guide. Typically, the
steps involve going to a ‘Setting’, ‘Connection’,
or ‘Bluetooth’ menu on your phone and then
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
Thank You
Aug 14, 2010 | Samsung Cell Phones
Samsung wep 200
Headset microphone may be off. Just press the volume up buttom and keep it pressed for 4 seconds or so, the pcs will beep twice to turn the mic on.
Aug 24, 2007 | Samsung WEP200 Headset
Things Needed Blue 3.5mm Stereo Fashion Earphone Headsets with Microphone for Micromax A26 Bolt Logo
15 people viewed this question
Top Things Needed Radio Communications Experts
eradiostore
eradiostore
Are you a Things Needed Radio Communication Expert? Answer questions, earn points and help others
