Question about GE Adora 3.9 cu. ft. Top Load Washer in White GHWN5250DWS
GE Adora GHWN5250D0WS beeps twice, wont start
Washer has power,i can select the load type, once i press start, it beeps twice and nothing happens
    Master:
  • GE Adora Master
  • 676 Answers
Sounds like the lid switch is broken if you need more help please let me know
Posted on Mar 30, 2014
I think I need to reset my front loader (adora GE) How do I do that?
Unplug unit, Plug back in.Rotate control knob to correct Model number.Press and hold start key till beep is heard,press power key to reset
Oct 22, 2009 | GE WSXH208A Front Load Washer
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
Drum won't Tumble or spin
check motor winding resistance. new motor comes with motor control unit. main controls are not common on ge
Mar 08, 2009 | GE WBVH6240F Front Load Washer
Kenmore Elite Oasis Washer 110.2709
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
WCVH6260HWW GE front load washer won't start - press the On button, then press Start/Pasue button and it goes beep beep, and keeps blinking, and washer does not start; the washer pump strainer has been...
no power to control panel checked outlet with another appliance it worked drained water from pump filter still nothing door locked and nothing on control panel
Feb 23, 2009 | GE WSXH208A Front Load Washer
My GE Washer Door Won't Lock
Try this, press the pause/cancel button twice. Open the door, ensure there is nothing blocking the door and close the door fully. Open the detergent drawer fully and re-close the drawer. Select Quick wash and press start.
If this does not correct the problem, call for service under warranty.
clarkco
Feb 19, 2009 | GE WBVH6240F Front Load Washer
Whirlpool Washer won't start door locked
Likely the ECU is failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Washing Machines
My washer will not start!!
Does the start/pause button flash and then the door unlocks? I had that problem too. This is what I did. I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
Oct 19, 2008 | GE WSXH208A Front Load Washer
Wont spin
Sep 17, 2008 | GE WSXH208A Front Load Washer
GE Adora 3.9 cu. ft. Top Load Washer in White GHWN5250DWS Logo
280 people viewed this question
Top GE Adora Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a GE Adora Washing Machine Expert? Answer questions, earn points and help others
