Question about Polaroid FLM-3734B 37 in. LCD HDTV
My Polaroid HDTV, no pic, no sound, cracking noises
When I change my tv's input to HDTV, there's no picture nor sound anymore; just this loud crackling noise that comes from the speakers. The noise gets louder the more I switch the input to HDTV. my other inputs are fine.
james klgr
  • 362 Answers
SOURCE: polaroid lcd hdtv 27" buzzzz
thre are several components that can make a buzzing sound, especially a bad power component or capacitor. check the capacitors to make sure they are installed in the board correctly. the stripe on the cap must line up with the white mark on the board under it. remove the back panel lay the tv down on a blanket turn it on and see if you can isolate the noise component by ear up close. and visually check for swollen capacitors the top will be pushed up round if bad if good it will be flat on top. warning if tv is less than a year old make the place you bought it replace it. so you dont void the warranty.
Posted on Feb 25, 2008
  • 15 Answers
SOURCE: Polaroid FLM-3232 Blue Screen 'No Signal'
yeah stay away from polaroid! In the meantime check this out.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Jul 22, 2008
dsacco86
  • 1077 Answers
SOURCE: Polaroid tv problem
The most likely the TV has a power supply related problem.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
  • 44 Answers
SOURCE: When we turned on the tv it says no signal vga
This might sound like a silly question but is the VGA input the one you wish to use?
If you are trying to use the VGA input what do you have it connected too?
A) Laptop 2nd VGA output.
B) Desktop VGA output.
NOTE: If you trying to connect it to a laptop you may have to engage your 2nd VGA output by depressing the 'Function Key' and either F4 or Some times it's the F8 key at the same time.
Blessings,
A/V Media Tech Guy
Posted on Nov 24, 2009
budmrtn
  • 11361 Answers
SOURCE: polaroid tv made loud noise and died, changed fuse
You can get service manual here: http://www.polaroidsupport.com/polaroid/en_us-sm.html
Look for standby 5vdc power supply, you must have this first before looking for anything else.
http://en.wikipedia.org/wiki/Capacitor_plague
You may need new poer supply module.
Posted on Dec 06, 2009
My polaroid fxm-1911c picture is distorted, sound distorted with loud buzzing when I try to utilize the tv signal input jack, also the dvd player doesn't work
Looks like there are some partial defects in the TV and might need attention of a qualified service technician. Anyhow, make sure that the input cable, RC jacks and sockets all do not have any loose contacts. Go through settings and ensure that every set up is as it should be.
Aug 02, 2012 | Polaroid FXM-1911C 19 in. LCD Television
TV will not come on. Tries to start, no pic, then shuts itself off. Humming sound like fan runs for a while and then stops.
This tv have a colors wheel is dead,require a new colors wheel replacement.Tv humming,loud squiling or motor noises and picture flashes black&white within the picture.The problems is the colors wheel are worn out or warp and it not spinning correctly in it motor joints anymore,it is the tv causes.Call the tv repair shop for a tech. to repair and replacement of the colors wheel.This job,it not simple,must take out alots of machanicals parts,even come to the colors wheel itself to replace it.
Nov 26, 2010 | Samsung HL-S4266W 42" HDTV
Polaroid hdtv flm 3732 37''
the noise is probably due to bad caps-stiv0 has tips on how to change capacitors. I had the same noise and tv would come on after plugging and unplugging but eventually stopped coming on. I just changed the caps and now it works perfect and took approx. an 1hour and supplies cost approx. $10.00. Good Luck
Mar 11, 2009 | Polaroid FLM-3732 Television
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Tv screen has turned blue and I can't watch tv
i think by accident you have changed the input when you went to change the volume. look for a button labeled " input" or "video" select on the remote and scroll through the various choices. you should get your picture back.
Jan 21, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Have a polaroid tv, model 3700 seriel F0600181940001053. WATCHING THE OTHER NITE AND A LOUD SQUEAL CAME ON AND THE PICTURE WENT OUT, TURN IT BACK ON TODAY AND THE SQUEAL IS STILL THERE WITH NO PICTURE..NO...
I have a flat screen polaroid lcd hdtv model 3700, first the sound started to get really loud with a beeeeeeeeep when we turned on and after a while was gone, now it doesnt! we had to put mute and connect the tv to a sorround system to hear it without that crazy noise, and now the colors of the tv are gone too its just black and white when we try to see the dish satelite but if we put a movie on the dvd player colors are perfect we try to conect the ps3 player too but its black and white too. Help what can it be!!!!????
Nov 14, 2008 | Televison & Video
Polaroid flm373b
Try several different inputs.
Sep 08, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Hitachi 65 in rear projection tv
can you identify the flashing item because it sounds like the flyback or the high voltage splitter can you send me a picture of the part thats flashing white please?
May 09, 2008 | Hitachi 65F59 65" HDTV
Polaroid FLM-3734B 37 in. LCD HDTV Logo
343 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
