Question about RC Helicopter Select Sanhuan SH 6030 C7 3.5CH Helicopter with Gyroscopes System and Video C
Rc helicopter controller not working
I turn the controller and helicopter on but nothing happens when I move the throttle up and down. The LEDs on the helicopter are on but it doesn't fly. I have tried syncing it many times to the correct band but it still doesn't work.
    New Friend:
I having same problems i can let it sit for a hour and it wont sync. And motor wires are connected
Posted on Jan 30, 2015
    New Friend:
I'm having the same problem. ... find any solutions yet???
Posted on Nov 09, 2014
  • champ0 Dec 21, 2014
    If the LED is flashing..you ain't synced yet...turn controller OFF.then ON..wait for it to beep & LED steady
  • RC Helicopte... Master
  • 17,162 Answers
Check the motor wire connections.
Posted on Mar 28, 2014
Skygiant rchelicopter when i sync it and then give it throttle all the lights on the helicopter syart flashing red and it dosent do anything
I bought 2 off brand ,of the same remote controlled Helicopters which cost about $30.00 each. The controller has A_B_C setting helicopter has none, You can set them up any way, either all on one or separate channels per controller which is channel A.
1st turn off Helicopter switch to off and controller off .
Set controller -1 to channel C , , then (controller-1 ) throttle knob to max, turn power on to controller -1 , throttle down and up 3 cycles and left and right 3 cycles
Turn on Helicopter 1 with controller -1 still on, it should work on channel C
Jun 11, 2014 | Team International Hawk Talon V3 RC Indoor...
On my rc volitaion remote on the top the gauge what dose it mean when it flashs
It's in a safety start up mode so there is no accidental start up of the helicopter
while holding model in your hands to turn it on or plug battery in. When ready to fly move throttle
gimble to full up then back down to stop. Light should then stop blinking and the
next time you move throttle gimble up the helicopter rotors should begin to turn.
Oct 06, 2011 | xheli 9053 Outdoor Volitation Metal...
Fully charged the choppers battery,the controller has all new batteries,turned on the chopper power switch,turn on te controller power switch and wait till light stops flashing.push on the power controll...
The light will keep flashing unless you are on the correct channel A B or C and you hit the "Light" button on the front of the unit.
As far as the high speed take offs I suggest identifying which A B or C setting is correct for your copter. In order to do this turn off the RC controller. Set the Selector switch to "A" move the left joystick "throttle" half way up and then turn on the power. Assuming that the copter is still ON it will either fire up or do nothing. If it does nothing try the same sequence with the selector switch set to "B" and try again. If nothing try "C".
Now, as far as the rapid accelleration, I read one online comment that indicated that there is some type of "programming" sequence that the unit learns by pushing the left joystick throttle all the way forward and then back to zero when you start to fly it. So after the first "blast off" set the copter back down or even hold it in you hand by grasping the the landing runners and move the throttle forward until the rotor spin up and it lifts off. In your hand it is easier to keep it from going up too quickly.
Aug 21, 2011 | JCPenney Gyropter RC Helicopter
Hello, just been given a syma s006 for xmas, charged it up for max 110 mins as indicated in manual, though LED never came on to indicate full charge. LEDs do come on flashing when switched on at model. New...
try this,switch the helicopter on,then make sure the left controller stick is fully down then turn the controller on,move left stick fully on then fully off should be ready to fly,have fun
Dec 27, 2010 | xheli 3 Ch Syma S006 Alloy Shark RC Remote...
Right out of the box yiboo uj 381 r/c helicopter. Copter charged and new batteries in the controller. Lights flash on the copter and flashing light on the controller but nothing happens. what's wrong
did you turn the radio on first. It must be powered up with the throttle stick at minimum. Turn power on and then move stick to maximum and back to minimum. The remote lite should stop flashing and then power on helicopter.
Dec 25, 2010 | Toys
The helicopter will not synchronize and I can't get it to communicate with the remote.
Press the throttle up and and back down and hold down a few times, sometimes it help to move left right knobs also. Try on each channel to get it synced
Dec 25, 2010 | Team International Hawk Talon V3 RC Indoor...
I dont know what band my helicopter is on
I'd use band A and it always works, except that it makes my ihome turn on, switch modes and radio stations, so I use band c. To connect to the heli, turn the helicopter on, wait for a red light to blink inside, then throttle up and down on your remote. Then, your all set. Just do some preflight checks and have fun!
Throttle goes wide open
Its is probably a faulty potentiometer in the transmitter's throttle channel. Take it back to the store if possible otherwise see if you can get another transmitter and bind it to your helicopter. The binding process will be in your instruction book.
Feb 28, 2009 | Esky Flight Simulator R/c Helicopter Kit
RC Helicopter Select Sanhuan SH 6030 C7 3.5CH Helicopter with Gyroscopes System and Video C Logo
424 people viewed this question
Top RC Helicopter Select Video Cameras Experts
Are you a RC Helicopter Select Video Camera Expert? Answer questions, earn points and help others
