Question about Toshiba Satellite A105-S4004 Notebook
Turn on I was watching a dvd and it quit and went through the procees of saving my settings like I turned it off and it won,t turn back on the batery indicator light flashes 7 times when it all happened it was plugged in t oac power so it did not go dead. I already put a new battery in it
    Scholar:
  • 90 Answers
Have you checked your power adapter with a digital multimeter? Maybe run it by your local radioshack or computer super store if you dont have a DMM and see if someone can check the voltage on it. Maybe your adapter died, then the laptop was running on battery until it went dead.
Another quick check, remove the battery all together. Plug in the ac adapter... does it turn on? does it show any lit led's indicating it is plugged into the wall? try wiggling the connector at the jack on the laptop, does that light any led's or cause power to be restored?
Posted on Oct 31, 2007
Tv turning off and on
depending on where you ended up..most of the power in other countries is 220..it is not as stable as ours is here.. this causes surges constantly..in order to avoid these surges, you need a stabalizing transformer to help keep the system more leveled out..
Mar 06, 2014 | Samsung UN65F7100AFXZA F7100 Series 3d...
Menu settings won't save
once you change settings you have to save the settings it will ask you do you want to save these settings push yes
Dec 27, 2012 | Humminbird Fishfinder 570
Why won't my TV turn back on even manually??
total dead usually means the fuse---unplug the set for safety and remove back cover---follow power cord just inside and you will find the fuse in a snap in holder--check to see if bad.............if good let me know and I will try to assist you.
Apr 03, 2012 | Televison & Video
My slendertone wont turn on. it did and i turned it off!! and when i went to turn it back on it wouldnt turn back on and i have changed the baterys!!!
I've had the exact same problem! I turned it on, and the lights went on then I looked at the next step in the manual and thirty seconds later max when I looked at the belt it had turned off! And now it won't turn on again! I've changed tha batteries and it still won't work! Please let me know if you find a solution!
Aug 13, 2011 | Slendertone Fortex
Gateway MX-7515 laptop Power button would not shut off cumputer went to hibernate and now power button will not turn on computer
first you will do ..
open the laptop cover at the back..
then look for the c-mos batery.. then remove the batery bout 30 seconds then put it back..
then turn on..
reply if it not work..
Nov 05, 2010 | Gateway MX7515 Notebook
ASpire one Acer wont turn on.
Pretty new system, so try on just AC power (remove battery) failing that, get in touch with Acer for repair under warranty
Jun 29, 2009 | Acer Aspire 5100 Notebook
TV will turn on, but not respond
Good Day, mistymiles;
Try this before calling a factory authorized service center:
Press " menu 2 > 4 > 7 > 0 > enter", on remote. After settings have been initialized > press the system reset button on the front, once the LED stops blinking > reprogram settings and tuner channels (if not using box). IF NOT fixed call for service (get estimate before repair) and suspect repair of DM PCB (printed circuit board).
Good Luck, big IRISH.
Jul 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My Mustex MP-100
my mp100 mustek player will not switch on or charge up also it will not switch on when the mains charger is plugged in. the light on the charger went out and will not come on anymore.
Aug 12, 2007 | Mustek MP100 Portable DVD Player
Won't turn on/red key shaped light on
just in case that happens again...you had the front panel locked out and need the remote to do anything, to lock and un-lock it you press the "lock" button on the remote
Jul 24, 2007 | Sanyo DVW-5000 DVD Player/VCR
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
125 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
