Question about Acu-Rite Acurite Wireless Weather Thermometer 604
MONTH AND DAILY RAIN TOTAL ARE ALWAYS THE SAME EVEN AFTER A MONTH
THE MONTH TOTAL OF RAIN FALL IS THE SAME AS DAILY TOTAL EVEN AFTER A MONTH hOW DO I RESET THEM AND WHEN SHOULD I DO THAT?
  • Brad Brown Mar 28, 2014
    Hi Jim Osborne, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? That model Acu-Rite Acurite Wireless Weather Thermometer 604
    MONTH AND DAILY RAIN TOTAL ARE not an option
  • Jim Osborne Mar 30, 2014
    Add a Commenttotal
    New Friend:
  • 4 Answers
Try going to the rain section, push the + BUTTON 5 times, and then on the 5th push, hold the button for 3-5 seconds and the guage will reset to 0.
Posted on Mar 30, 2014
What was the total rain fall amounts for Tarpon Springs November 2016
https://daily-weather.weatherdb.com/d/a/Tarpon-Springs%2C-FL
Mar 07, 2017 | The Computers & Internet
Tip
How to measure rain fall when your rain gauge overflows
Most rain gauges that you will make at home will only measure up to one inch of rain fall. The problem with this is that if you live in a place where you will get more than one inch of rain your measurement if taken incorrectly will be very skewed. If your rain gauge has been constructed correctly you should have a fail safe in place.
When you construct a rain gauge you should have a measuring tube inside of an over flow tube. The meausuring tube will hold about one inch of rain fall, but when more rain falls the inside tube will overflow into the outer tube. To measure the excess rain fall you will follow a few simple steps.
Start by reading the inner tube of the rain gauge and then carefully empty the tube. Make sure that you don't pour out the water that has overflowed into the outer tube.
Once all the water for the measuring tube has been emptied carefully pour the excess rain water into the measuring tube. To get the most accurate reading try your best to not spill any water out, you can pour the water over a bucket to make sure that if you do spill any out you will catch it and be able to measure accurately.
If there is a lot of overflow you might want to measure a little bit of overflow at a time to get an accurate read. As you measure, write down the measurements and when you finish add up the values to get the reading.
The readings are done in inches so you have a reading that is 1.00 and has an overflow that measures up to .50 then the total read out will 1.50 inches.
on Feb 02, 2014 | Garden
Tip
Routine care at home to prevent the hair from damage.
  • Always keep your hair clean. It will protect them from dandruff, itching and hair lice, which ultimately results in hair fall.
  • Always use the shampoo and conditioner depending on your hair type. As for oily hair, you should use a shampoo, which is meant for specifically for oily hair.
  • Give regular massages to your scalp and hair with lukewarm oil at least twice a month. You can choose coconut oil, olive oil or almond oil for your hair. You can even mix these oil and apply the solution on your hair.
  • If there is dandruff in your hair you can mix camphor cubes in coconut oil to massage on your hair and scalp. It helps in reducing the dandruff.
  • Rub a lime on your scalp if there is dandruff on your scalp, leave it for 10 minutes and shampoo the hair. You should use medicated dandruff shampoo and oil to apply on your hair when they are suffering from dandruff.
  • Never comb your hair when they are wet. The roots of the hairs are the weakest when they are wet.
  • Keep the hair wrapped in a towel for a while then let them dry in natural air as excess usage of hair dryer too damages the hair texture and makes them weak and then ultimately they fall.
  • When your hair is falling, make a mixture at home containing Amla, Shikakai and dry neem leaves. Grind them together and apply this paste on the hair before washing them off for a while.
  • Whipped eggs mixed in curd and henna powder help in preventing hair fall.
  • Eat healthy diet including green vegetables, dairy products and fruits.
  • Drinking coconut water prevents the hair fall.
  • You can make oil at home for falling hair. Boil henna and neem leaves in mustard oil till the leaves get almost dissolved in it. Let it cool and then filter. Add few camphor cubes to it and fill in a bottle. Use this oil to massage on your hair.
  • Mixture of almond oil, olive oil and castor oil is equally good to prevent and stop hair from further falling.
  • Get your hair trim every month so that there are no split ends left.
  • Include at least 2 nuts in your daily diet. They help a lot in strengthen the hair.
  • Avoid using too harsh clips or bands on the hair. Never make hair too tight.
  • Protect the hair from dust and sun. Cover your head while going in the direct sun.
  • Apply hair pack on your head at least once in a month. It can be henna paste, curd, eggs or a combination of all.
  • Wash your hair every time you apply some chemicals on your hair in form of styling gels, creams, sprays or lotions. The harmful chemicals in them damage the hair and make them to fall.
  • If you have got the bald patches on your head then apply onion on the bald patch by rubbing it and then apply honey over it. Leave it for few minutes and then wash off.
  • Boil fenugreek seeds in any of the hair oil of your choice as coconut oil or olive oil. Restrain it and fill it in a bottle. Use this oil to massage on your head. Its very helpful in reducing the hair loss.
  • Eating iron rich fruits and food helps in preventing the hair fall. Include apples, beetroots and jagary in your daily diet. They are rich in iron so help to prevent your hair fall.
  • Eating amla in any form or drinking its juice too helps in preventing hair fall.
Follow these simple hair care tips and you can protect your hair from further damage
on Jun 30, 2010 | Health & Beauty
Just replaced the batteries and the daily and 9 day rain gauge flashes continually and does not calculate the total. The date and temperature and correct. The is approximately 3 years old.
Those stations are a royal PIA - not easy to find one that works completely as designed. Either you have not set it up correctly with new batteries or the electronics of unit have gone South.
Oct 05, 2016 | Measuring Tools & Sensors
What is the rail fall amount for may in Ellenbrook Perth W.A
I finally found some form of daily records for perth
http://www.bom.gov.au/climate/current/month/wa/perth.shtml#daily
Jun 09, 2016 | Measuring Tools & Sensors
How to get grand total of the month on sharp cash register ER-2385
I can't believe we still have a book for this one - the ER2385 began production in 1987!
Most business owners take their totals daily. You probably have, too, by turning the key to Z1 and touching
. CA/AT (I hope you can the decimal point in front of the CA/AT. It's essential.)
To take monthly totals, do exactly the same thing, but in the X2/Z2 position.
Note that these totals are monthly only because you print them monthly. If you do it every Saturday night, you'll get weekly totals. The register prints totals that have accumulated since the last time you took a Z2 reading. It's up to you to make them monthly by taking them monthly.
So, on January 31 take your usual nightly total, then the Z2 total. Taking the daily one first ensures that today is included in the month.
Skipping the decimal point before the CA/AT will give you an X2 total. The same numbers will be printed, but they won't be cleared back to zero. That's fine if you want to see your totals so far, without messing them up, but if you forget it at the end of January, then February's totals will include both months. The same rule applies to daily totals. Use the decimal point if you want the numbers cleared.
While the CA/AT key gives the familiar department totals, other readings are available.
PLU gives your PLU totals, if you use them. (X1 and Z1 only)
#/TM gives totals for each hour of the day (X1 and Z1 only)
SBTL gives a total for each day of the month (X2/Z2 only)
Dec 30, 2012 | Computers & Internet
What are the Best replacement batteries for the Jazzy Select 6 and Where is the best place (retail store or online) to buy them? I bought the U1 Gel Batteries at wholesalebatteriesonline.com and they...
ggirl why did you buy a pig in the poke they should refund your money because the batteries should have a six month warranty. Now always ask for the date code on batteries you are buying they shouldn't be any older than 4 months old. There are good batteries out there but if I offend anyone I'm sorry but MK batteries are very good also Interstate batteries and probably others that I'm not aware of. The best way to insure good batteries are buying fresh batteries, Charge them before you use the chair and always get into the habit of charging overnite if you use the chair daily. Never leave the charger plugged in more that 12 hours and if you don't use the chair daily charge at least once a week and always put up fully charged. Mk recommends charging the batteries daily for the first 20 days. Never run the batteries or let them fall below the red light on your battery level indicator. Your chair runs on about a 5 volt range (26-21 volts) after that the red light blinks like crazy. If it falls below 20 volts the charger will not charge the batteries. If you take care of them they should last you 3 years or more. Hope this helps
Oct 19, 2010 | Pride Jazzy Select 6 Indoor Power...
My Oregon remote rain guage RGR122 purchased in 2006 is driving me mad . I contacted you in July 2008 with the same problem and following your advice it did improve for a while but I am back with the same...
My Oregon Scientific Weather Station RGR122: The total rainfall and rainfall windows won't stop flashing. I have removed the new batteries several times, changed batteries in outside collector, and reset the inside unit multiple times. What can I do to solve this problem. Frustrated! Darla
Aug 26, 2010 | Oregon Scientific Lwb0997110113004...
Casio 101cr.i need a users manual.
Hi. These registers are about the most basic you can get, so they can't do a daily and monthly total.
Basically it works like this:
The machine doesn't care when you do your reports. It will just total up until it gets reset by someone. If you want a monthly, just do your reports each month. However, this means you can't do a daily.
If you turn to X mode and press CASH, you get the total so far (since you last did a Z report).
If you do the same in Z mode, it will give the report, then reset the report to zero.
If you want to see daily and monthly, you can do an X at the end of each day which will show that day and the previous days together. you will need to subtract the other days to find out what todays takings are. Then at the end of month, do a Z and that will reset you for the next month.
Otherwise, if you are interested in monthly only, then just do a Z at the end of each month.
So, what I'm saying is the machine doesn't care how many times you do an X report. It will just show you how you are doing so far, but you must do a Z report when you want it to reset everything. If you want to check if the Z report worked, just wait for the report to print, then press CASH again straight after, and you should see the figures have gone.
I hope this makes sense. If you need more advice, just ask.
Mark
Oct 08, 2008 | Casio Parts Cash Register PC Desktop
Acu-Rite Acurite Wireless Weather Thermometer 604 Logo
263 people viewed this question
Top Acu-Rite Measuring Tools & Sensors Experts
windryder
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
