Formula for perimeter
Permeter =80 feet lengh = 15 base = ?
  • Computers & ... Master
  • 17,328 Answers
The base is one of the four sides, since you know that it has to have another side that is the same length you double it. So the base and the top are 30. Now you take the perimeter and subtract that so you have 80 minus 30 which leaves 50. This is split between the sides so one side is 25 and the other is the same. The dimensions are 15+15+25+25
Posted on Mar 28, 2014
Identify and calculate the area and perimeter for triangle, a=8.1mm, b= 4.5mm, c=9.27mm
simple maths
to get the perimeter simply add a + b + c
to get area the formula , 1/2 base by perpendicular height
May 04, 2017 | The Office Equipment & Supplies
The base of an isosceles triangle is 2 more than one of the equal sides. If the perimeter is 41 find each side of the triangle
41-2 = 39/3 = 13: now all three sides are equal. Add 2 inches to the base 13+2=15. Equal sides are 13 each and base is 15. 13+13+15=41
May 06, 2015 | Computers & Internet
How many feet in a half acre of land?
Since acre is a measure of area and feet is a measure of distance, you need to calculate the perimeter of a lot with an area of half an acre. Here are the formulas:
1. If the lot is a square (all 4 sides of equal length), multiply the length of one side by 4, to get the # of feet required to walk a half acre piece of land.
2. If the lot is rectangle: (heightx2)+(widthx2).
3. If the lot is a triangle, add up all three sides.
Dec 09, 2014 | Visual Land Audio Players & Recorders
What is the length of one side of an equilateral triangle that has a perimeter of 15 3/4 feet?
15 3/4 =3*S (S the length of a side)
S= (15 3/4) / 3 = =5 1/4
Please use improper fractions. It is safer.
Sep 26, 2014 | Computers & Internet
What is the surface area and volume for 14ft 12ft 3ft?
If that is a right rectangular prism
Volume =14*12*3 c.f.
For the area here is the formula.
Total area of right rectangular prism =2*A_b +P_b*h
A_b= area of base (take 14*12 feet squares)
P_b is perimeter of base (14+12)*2 =52 ft.
h is the height (3 ft)
Lateral area =P_b*h=52*3 feet square
Add all areas.
Mar 05, 2013 | SoftMath Algebrator - Algebra Homework...
Area of traingle with tree side
All triangles have three sides.
There are two main formulas that do not call on trigonometric ratios.
The classic one:
  • 1. You need the length of a base and it corresponding height (the length of the segment perpendicular to that base and passing through the vertex (summit) opposite to that base. Area=(1/2) * (measure of the base)*(measure of the height). The base and height must be expressed in the same unit.
Heron's Formula if you have the length of the three sides. Let those measures be a, b, and c.
  • Calculate the semi-perimeter p with p=(1/2)(a+b+c)
  • Area=Square root of (p*(p-a)*(p-b)*(p-c))
  • a, b, and c must be expressed in the same unit.
May 21, 2011 | Casio FX82ES Scientific Calculator
Compute the area of triangle
Hi nanaeden
Use the formula depending on what is given
If one side and vertical height from that side to the opposite vertex is given, use the formula 1/2 of basexheight
If 3 sides of the triangle are given use the formula
sq root of [ s(s-a)(s-b)(s-c)] where a,b, c are the 3 sides and s is semi- perimeter.
Familiarise with formulae to solve Maths problems.
If it is helpful, please give a rating.
Have a nice day
luciana44
Nov 25, 2009 | Cell Phones
I have a lot tha is 152.95' X 119.88' X 130.00' X 50.00'. What part of an acre is this.
  1. This lot does not have the form or a regular quadrilateral (rectangle, square, parallelogram, etc.)
  2. So you cannot calculate its area, you have to know exactly the shape it has.
  3. With polygons, one usually cuts them into triangles.
  4. You have to cut it into two triangles,
  5. measure the base and the height of each triangle,
  6. use the area formula for the triangle ( area = heightX base/2)
  7. After you calculate the areas of both triangles, you add them to get the area of the the whole lot in ft^2.
  8. Using the conversion formula between acres and ft^2 which is 1 acre=43560 ft^2, you divide the area of the lot in square feet by the number 43560 ft^2 and express the result as a percentage or a fraction .
Hope it helps.
Thanks for using FixYa.
Nov 19, 2009 | Calculated Industries Pocket Real Estate...
Cubic feet
4' = 48"
thickness" x width" x lengh" = cubic inches
2" x 8" x 48" = 768
1 cubic foot is 144 cubic inches
768 divided by 144 = 5.3333333333------
Dec 09, 2008 | Electric 1/2hp 1140RPM 56 Frame 230/460V...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
