Question about Dometic RM2652 Refrigerator
HREEZER WORKS ON PROPANE BUT FRIDGE DOES NOT
BOTH WORK FINE ON AC
  • Official Brand Answer
  • 73 Answers
You more then likely have a weak flame. Most of the time this is caused by a dirty orifice. It is located just before the burner. You must first remove the burner cover, then you will see it. It is the brass piece that the propane shoots through before entering the burner. You can unscrew the orifice from the gas valve assembly. Then soak it in rubbing alcohol for an hour or so. Blow it out with air and re install it. DO NOT POKE ANYTHING THROUGH IT! This should fix your problem. ArctiCold Refrigeration We keep it cold or Store HREEZER WORKS ON PROPANE BUT FRIDGE DOES NOT - a4efa292-1c08-40ca-a993-9395db1be4a3.jpg
Posted on Apr 07, 2014
  • 9 Answers
SOURCE: Dometic refridgerator won't stay lit on Propane
A bit more info is needed. What model #, and how old is it? In back, does it have a computer board (underneath a green or black plastic cover, appros 4" x 6")? Im guessing that it does, ('cause you get an error message,) Make sure that you have a good 12 volts going to the board at all times, and make sure that the glass fuses on the board are not blown. If that checks out, than its a real good bet the you have a defective board. For Americana models, you're going to need a Dometic board, and for other models, an aftermarket board will usually do. Althoiugh the OEM ones have a better chance of fixing your problem.
Posted on Jul 26, 2009
  • 32 Answers
SOURCE: Dometic Fridge works well on AC but when running
Sounds like the thermocouple needs replaced or the thermostat.
Posted on Sep 05, 2009
  • 10 Answers
SOURCE: i have a dometic rv fridge. it works on the 120
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Posted on Feb 16, 2010
  • 3 Answers
SOURCE: I have a Dometic 2193 3 way fridge. It works
The flue baffle was the solution that worked for me as well. Below is a response I posted to a similar post.
I had a similar problem. The flue would get hot and the cooling tubes would get "warm". The refrig would get a LITTLE cool but nothing to be of any help.
I solved it though...it turns out there is a "flue baffle" (twisty little metal thing) that is supposed to hang in the inside of the baffle. It hangs from a screw found on top of the baffle and it is supposed to hang down.
The screw that held mine was corroded and flue baffle had fallen into the baffle and landed on top of the burner.
I ended up fishing the flue baffle out of the top of the baffle with a coat hanger, then rehanging it using a new screw. That solved my problem.
Not sure if this will work for you or not but good luck.
By the way, you can find an owner's manual with a diagram showing the flue, the flue baffle, and the piece of metal holding it here:
http://www.fourwheelcampers.com/DometicRefrigerator.pdf
Look on p.9, figure 9. Item C is the flue baffle and the wire holding it. Item B is the screw that was corroded on mine, and ended up dropping the baffle down to the bottom of the flue.
Below is a link to some generic directions on solving fridge-related problems. I found it to be VERY useful.
http://rvmobile.com/Tech/Technical.htm
Posted on Jul 28, 2010
  • 2006 Answers
SOURCE: Fridge does not get cold during propane gas
According to the manual the following is the most likely items to cause that failure. But since it is only in the frigerator section and not the freezer section it could be the lower circuit board.
LP Gas
Orifice
Flue Baffle
Flue Tube
Burner
Lower Circuit Board
Posted on Sep 11, 2011
RM 2611
the relay for the ac powered heater is stuck closed. it should cycle on and off , and not be on at all with the unit off.
Apr 17, 2014 | Dometic Refrigerators
Dometic rm2611 freezer works fine on propane but fridge doesn't cool
move temp sensor to middle of coil if same replace temp sensor
Mar 28, 2014 | Dometic Refrigerators
DOMETIC RV FREEZER WORKS FINE ON PROPANE BUT THE FRIDGE DOES NOT COOL
Give Arcticold a call. We will help diagnose the problem free of charge. I would help on this site but will require a lot more info. Toll free 1-888-782-6665 I have attached a video that may help. 88bf4c61-06e7-40b5-9515-34afd5643a3d.jpg Store
Mar 28, 2014 | Dometic RM2652 Refrigerator
Freezer works fine on propane but not the fridge
You may wish to check the flue clear anything that you find. Old birds next etc. Also make sure the flame and orifice are clean free from debris or rust. Propane should burn blue not orange. Incorrect gas setting if the flame is orange. Some yellow at the tip is ok. Proper adjustments are critical. Have you tried the unit on AC?
Other tips I have read indicate possible freezing in the back.
Defrost freezer completely as some here mentioned and restart see if this helps. Here is a good RV forum I saw good tips worth investigating.
If your not comfortable cleaning the jets and adjusting the flame have a professional do this. Safety comes first!
Freezer works refrigerator doesn iRV2 Forums
Propane mode on my rm2554 dometic 3 way fridge hasnt worked in a long time now ac has stopped working, fuses and breakers all good
clean out lines to LP if ok no clicking bad board if clicking check for cobwebs and ac check heater element
Aug 12, 2013 | Dometic Refrigerators
Dometic RM2652. The fridge will not work when it is plugged into AC.
Unplug the fridge. Remove the cover from the circuit board, unplug the 2 wires going to the heat element and do an Ohms reading should be 35-45 Ohms. If the Ohms is good then you need a circuit board as long as you have checked the 110 volt fuse on the circuit board.
Apr 30, 2012 | Dometic RM2652 Refrigerator
Have dometic propane fridge in rv and works fine when flat but no
well if you find one let me know???
if it only works when upright start carrying some jacks with you then if its leaning over jack that side up a bit till its flat!
Oct 23, 2009 | Refrigerators
Dometic RM2652 Refrigerator Logo
165 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
