Question about Dometic RM2652 Refrigerator
Freezer works fine on propane but not the fridge
Dometic rv fridge, on propane, freezer works fine but fridgwe doesn't cool
  • Peter Green
    Peter Green Mar 28, 2014
    I had a similar problem with a fridge freezer ! The freezer worked but he fridge didn't !
  • Peter Green
    All fridge Freezers have one compressor which serves both fridge and freezer and as your freezer is working that proves there is nothing wrong with the compressor ! That means that behind the scenes some pipes leading to the fridge have frozen,most likely because the freezer temp is set too cold !The solution is to switch off your fridge freezer and thoroughly defrost it,Switch back on and all will be well !
    Sergeant:
  • 233 Answers
You may wish to check the flue clear anything that you find. Old birds next etc. Also make sure the flame and orifice are clean free from debris or rust. Propane should burn blue not orange. Incorrect gas setting if the flame is orange. Some yellow at the tip is ok. Proper adjustments are critical. Have you tried the unit on AC?
Other tips I have read indicate possible freezing in the back.
Defrost freezer completely as some here mentioned and restart see if this helps. Here is a good RV forum I saw good tips worth investigating.
If your not comfortable cleaning the jets and adjusting the flame have a professional do this. Safety comes first!
Freezer works refrigerator doesn iRV2 Forums
Posted on Mar 28, 2014
SOURCE: Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Posted on Jul 20, 2008
  • 62 Answers
SOURCE: Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
Posted on Jul 25, 2009
  • 10 Answers
SOURCE: i have a dometic rv fridge. it works on the 120
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Posted on Feb 16, 2010
motor1258
  • 6674 Answers
SOURCE: 3 way dometic RV fridge RM2612 won't work on propane or 12 V
Check any fuses/circuit breakers in harness from battery. That battery should supply 12 volts dc to fridge lugs/terminals at bottom of fridge on outside behind vent.
If battery is good and hooked up properly but no 12 volts to fridge, then you will have to trace back to battery for broken /bad wire. If you want to test quickly, just run 2 jumper wires from battery to those 2 lugs marked + and - Battery + to + (pos)at fridge, and - battery to -Neg at fridge. That should allow you to run it on propane or 12 volt. Remember, running it on 12 volts will kill that battery pretty quick, unless it's being charged. When you are plugged in, the converter supplies the 12 volts to your fridge, as well as should be charging your battery.
Posted on Jun 22, 2010
SOURCE: i have a dometic dm2652 rv fridge. its new and is
The DM2652 comes with an optional cooling fan to help with cooling the amonia. The fan cycles on and off as required as it has a tempeature sensor (thermistor). We turn ours off at night by removing the inline fuse (glass tube fuse 3 amp) located in your outside acces panel. The fuse is located in a black fuse holder with a re wire connecting both sides.
Posted on Aug 18, 2010
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Dometic rm2611 freezer works fine on propane but fridge doesn't cool
move temp sensor to middle of coil if same replace temp sensor
Mar 28, 2014 | Dometic Refrigerators
DOMETIC RV FREEZER WORKS FINE ON PROPANE BUT THE FRIDGE DOES NOT COOL
Give Arcticold a call. We will help diagnose the problem free of charge. I would help on this site but will require a lot more info. Toll free 1-888-782-6665 I have attached a video that may help. 88bf4c61-06e7-40b5-9515-34afd5643a3d.jpg Store
Mar 28, 2014 | Dometic RM2652 Refrigerator
Dometic Fridge Intermittent on 120V
the dometic fridge you mentioned was outsourced by Dometic and they are having problems. (unit 2652) call dometic at 18888674188 and give them your mod and serial number.
May 26, 2012 | Dometic RM2652 Refrigerator
Dometic refrigerator Model # rm2610
Well first of all solution # 1 pertains to household refridgerators..RV models have no fan inside maybe outside,But I would find out if it gets cold/freezes with 120 volt and or LP(propane) and look trrough the internet and download your model service manual.
Jul 23, 2010 | Dometic RM2652 Refrigerator
Jun 18, 2010 | Dometic RM2652 Refrigerator
Have dometic propane fridge in rv and works fine when flat but no
well if you find one let me know???
if it only works when upright start carrying some jacks with you then if its leaning over jack that side up a bit till its flat!
Oct 23, 2009 | Refrigerators
I have a dometic rv fridge. it works on the 120 v but not on propane. acutually the freezer works and the fridge is warm, when the propane is running the fridge
Jun 04, 2009 | Dometic NDR 1292 Refrigerator
Silhouette by Dometic RV fridge
Tuna, it sounds like your thermistor is bad. Once the fridge reaches 40 degrees, the thermistor is supposed to tell the board to stop cooling and maintain. You can test it with an Ohmmeter.
May 07, 2008 | Dometic RGE400 Top Freezer Refrigerator
Dometic RM2652 Refrigerator Logo
482 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
