Question about Evenflo Embrace
I put the canopy on my evenflo carrier on backwards now I can't get it off help!
Canopy on backwards
3 Suggested Answers
mclough1
SOURCE: Evenflo Infant Car Seat Canopy Fastener
There Should be a 1 800 number on the Box That you can call
and they should send the peice your missing
if not try going in to a store Where they sell simlaler Products
and see if they carry the peice your missing
I hope I have been of use
Posted on Aug 26, 2008
SOURCE: How do I remove the canopy from evenflo infant carrier?
use a tiny flat-head screw driver to pull outwards on the tab (this is a blue plastic tab on mine) that holds the white plastic u-shaped (canopy part) in. I didnt think it would be this difficult but it is... the graco ones are much easier to take off to wash.
Posted on May 26, 2009
The canopy on my Graco Stylus Travelsystem Stroller has an extra flap of fabric that doesn't seem to go anywhere. It hangs over the cupholders or lays over the canopy covering the window. It...
You may have the top on backwards. The flap is usually used as a sun shade, and should probably be over the open part in front of the stroller.
Nov 19, 2017 | Graco Snugride
How do i replace a graco carseat canopy?
The canopies simply pull off of the carrier. You would have to replace both the plastic and the fabric. You can order replacement sets from Graco for about fifty bucks, but that's kind of expensive. I don't think you can replace just the canopy. I'd call/email them to confirm.
May 01, 2011 | Graco SnugRide - Giselle Infant Car Seat
Evenflo embrace
Sometimes the canopy is attached with the carrying handle. Take the screws out of carry handle and remove canopy.
May 05, 2009 | Evenflo Embrace
How to fold a beby trend expedition single
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Apr 28, 2009 | Baby Trend Expedition LE Jogger
Apr 18, 2009 | Evenflo Embrace
Aug 26, 2008 | Evenflo Embrace
Graco bassinet model 3300
http://www.babyage.com/icons/localhost/products/multimedia/10186_RocknRollBassdir_12_17_03.pdf
Dec 01, 2007 | Graco Simplicity Rock n Roll 330 Crib
The sun shade on top
1. Infant restraint comes with four identical canopy support parts. Thread one canopy support completely through one sewn tunnel.
2. Slide straight end of a second support into the straight end of the first support.
3. On models with four canopy supports, repeat steps one and two for the other canopy tunnel.
4. Attach canopy in the areas between the infant restraint and the handle base.
To remove canopy, reverse the steps.
http://www.gracobaby.com/assets/pdfs/instructions/ISPC089BA_ISPC106AA.pdf
Hope this helps!! Thanks
Nov 16, 2007 | Graco SnugRide 8646 - Fiesta
Removing Canopy
I don't know what brand you have, but if you look on the inside of the holders for the canopy, there should be a little plastic tab holding the hooked end of the canopy frame in place.  Use a small screwdriver to lift the tab up enough so you can slide the hook out.  Once you have it out, remove the canopy and wash away.
Oct 11, 2007 | Evenflo Cozy Carry 5
Infant Capsule Evenflo Discovery
You should have any problem finding that part, unless Evenflo completely discontinued your car seat. Use this link: https://plweb.evenflo.com/ModelNumberHelp.aspx To find your Model Number and Manufacture date. Then use this link: https://plweb.evenflo.com/replacement_parts.aspx To find replacement parts, if they still have any. Good luck!
Jul 11, 2007 | Evenflo Discovery - Black/Red Infant Car...
Evenflo Embrace Logo
223 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
