Question about Boating
I am looking for a diagram of a 1977 evinrude 85hp engine - so i can work out how to remove the tilt rams from the engine to check if they are working correctly
  • 285 Answers
Hi there, You can find all parts diagrams for Evinrude engines here: http://epc.brp.com Just ignore the email entry part and go straight to the database. They are listed by Brand, then year, then HP size. I checked for you and it has the 1977 85HP models listed there. Then just find the right subsection of the outboard and it will bring up exploded diagrams for your viewing!
Posted on Jun 15, 2009
Need a wiring guide for 1968 55hp Evinrude Outboard
Posted on May 22, 2011
    Problem Solver:
  • 6 Answers
You can also go to Crowley Marine Evinrude Parts & Diagrams and you can look up the diagrams for all of the OEM parts of the motor in an exploded view.
Posted on Jan 21, 2010
How do i remove trim motor on 1977 evinrude 175 hp outboaard
firstly remove the motor from the boat then you can get to the trim tilt motor to remove it .
Jul 26, 2016 | Boating
What should the compression be on a 1977 115 hp evinrude
Russ, not sure on factory compression, forums say motor should be good if running 100+, more important is to be with in 10% from highest reading to lowest compression reading. Balance is a key part for engine to run good. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.iboats.com/basics/find_engine_compression.html
Two problems with 1977 Evinrude 115HP Two Stroke Need some help The Hull...
One Cylinder down on Compression
May 06, 2016 | Boating
I HAVE A 1978 EVENRUDE 35 HP NO FIRE TO THE PLUGS GREAT COMPRESSION???
evinrude 1978 -1979 have a capacity discharge ignition unit as the control for the spark system
it runs wires to an ignition coil
so I would be suspicious of that unit
check all connections for corrosion and bad connections
I typed in electrical schematics for 1978 evinrude out board engine and found a site --www.maxrules.com which in the list of schematics has 55hp 1977-1978
press on that and you get a schematics of the wiring diagram evinrude 1978-1979 55hp
now I am aware that you state that yours is 35 hp but if it has 2 cylinders then it is a fair bet that the wiring diagram will be the same
any way there are plenty of other sites that may be of benefit
Nov 26, 2015 | Boating
Evinrude troubleshooting
Depending on age, the controls(relays) are either under the cowl or in a remote box but they are the same. Look for a fuse. Blown, you will have no action. Then check all connections especially to positive battery. but a bad ground will shut it down also.
Aug 05, 2014 | Clymer Evinrude/Johnson 5-70 Hp...
Need a diagram of how to keep ball bearing on spring in throttle body on a evinrude 85Hp outboard
LIGHT GREASE SHOULD HOLD BALL BEARING IN PLACE DURING REASSEMBLY
Jun 30, 2013 | Boating
Does a 1977 Evinrude 70 horsepower engine hav a charging system?
The 70s Johnson or Evinrude outboards of similar sizes did not have any charging system. I had an old Johnson 50HP (key injection) mounted on an 18Ft Zodiac and I needed to remove and recharge the battery once every couple of weeks. Keep the battery dry and the contacts well greased.
Apr 25, 2011 | Clymer EvinrudeJohnson Outboard Shop...
Boating Logo
2,715 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
