Question about Nordic Track NordicTrack C2150 Treadmill
Will come on for a second and then stop,i have to push stop then try again with same results
I have a NordicTrack c2150 that will start but only runs for a second, you can reset by pushing the stop button but again it will only run for a second an stop
  • 40 Answers
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Posted on Nov 01, 2009
  • 218 Answers
SOURCE: NordicTrack 2500 R Treadmill
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Posted on Aug 11, 2010
roadtech7
  • 293 Answers
SOURCE: nordicTrack c2255
Ok, your controller is faulty. Double check that your reed switch is connected and adjusted. It is located at the pully on the front roller. It is just outboard of the pully. It points at a magnet that is glued into the plastic pully. It should be about 1/8" away from the pully. If that is ok follow the wire back to the controller, it only has two small black wires, It has a red two place connector that pushes on the controller board. These are rarely the problem. If you are under warranty, get both the controller and the reed switch. If I would guess, It is the controller that is your problem.
Posted on Dec 01, 2011
Testimonial: "Matt, Thank you for the quick response and trouble shooting solution. I checked the reed switch and it appears to have the proper spacing. I will replace the controller. Thanks again. Telcomac"
ercupa190
  • 12223 Answers
SOURCE: My problem is that my
Now you will have 2 step:
adjust the sensor reed switch, see the diagram.
12_1_2011_5_32_07_pm.gifTight the flexible cable from keypanel vs display board and tigh the connector from display board vs lower board ( main motor controller) and clean the contacts.
http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQhttp://www.youtube.com/watch?v=hKbAqvuOBS0&feature=relatedhttp://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Qhttp://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=relatedhttp://www.youtube.com/watch?v=CuMjcPLYehw&feature=relatedhttp://www.youtube.com/watch?v=yX_0vRPdMfU&feature=relatedhttp://www.youtube.com/watch?v=zXeHMWTcLUY&feature=relatedhttp://www.youtube.com/watch?v=dxpOOPetVLoIf after you did this: the problem will be a) Main Motor b) Main Motor Board. see the block diagram.
12_1_2011_5_37_51_pm.gifgood luck, sincerely. G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
ercupa190
  • 12223 Answers
SOURCE: Treadmill stopped working. Push any button on the console and it beeps. Unplugged, Reset, Checked Reed switch - seems to be in the right position. Unplugged again and it started then stopped a few
1)lube the DECK BELT, you have a lack of maintenance schedule. mAYbe you have a deck belt worn. This produce enough friction between deck vs deck belt and shut down the machine for to protect the electronic system.
2) Lube the rollers bearing in according with the maintenance schedule.
3) Test the voltage input motor, if there are the motor need repair.
4) Test the output voltage board,for input voltage motor, if there are NOT the board is faulty.
5) Try to run the software calibration for diagnose, troubleshooting,etc
6) SEe my personal tips for help.
sincerely. God bless you
Posted on May 08, 2012
Keeps stopping. I turn off power and restart but it stops again after a few seconds. How can I reset it to quit stopping after a few seconds.
Hope the speed sensor have some problem may dust on it or the treadmill need lubrication. Most of the treadmill stop after some kilometres reading indicating that its time to lubricate it. After lubrication you have to reset the counter.
check the link bellow using the search tab find out details of NORDICTRACK A2350. and follow those instruction.
www.electro-medical.blogspot.com
Nov 01, 2015 | Nordic Track NordicTrack A2350 Pro...
Why is my nordictrack sl 728 console keep pausing every 5 seconds?
It sounds like you have one of two things happening.
The first is a small short in the wiring, in which case, you need a new one. The second is almost as bad, your unit needs adjustment, which is probably cheaper and easier to buy a new unit on e-bay or amazon.
Aug 28, 2014 | NordicTrack Cycling
Belt not working
I believe your talking about the Controller, not a computer board. This device may turn on, however; the instructions and sequence of activity will not work. Many reasons for this to happen; and usually the problem is traced back to a power surge. Major components and equipment need to be plugged into a UPS (Uninhabitable Power Supply) with special protection to avoid damage to vital electronics. If plugged into the wall (directly) there are no protection devices and current can pass through a device and damage the controll unit.
Mar 25, 2014 | Nordic Track NordicTrack C2150 Treadmill
Nordictrack c2150 panel not working
adjust the Reed SWITCH, see the diagram attached it. Clean it, test it of open or faulty. Tight the connector very well. Replace and clean the contacts batteries( if they have).
Tight the ribbon cable inside.
If the problem persist, after you did, replace control display board
God bless you099b95f6-0273-44db-b9a8-431d1bfaedf5.gif242bb3fe-383b-4bdb-aa92-fe8728465711.gif
Jul 25, 2013 | Exercise & Fitness
How to replace the walking belt on the c2150
see the video and proceed according at your common sense and logically: GOD BLESS YOU
Jul 25, 2012 | Nordic Track NordicTrack C2150 Treadmill
When I turn on the treadmill, the top console lights up, but the bottom half of the console won't work except for 2 buttons. The START button will start the treadmill at 1 mph (stop will not...
First of all you need a Surge protector, you can get one from Nordictrack.com, it is on sale. Secondly, unplug the treadmill and leave it unplugged for at least 24 hours. Before you plug it back again, make sure you already have a surge protector on your outlet. Also make sure Trreadmill is the only load on this circuit. Plug it and try again. I had the same problem, and mine works this way. Some times, with dilrty power, the bit get set and the bottons stop working. Good Luck!
Jan 02, 2011 | Nordic Track NordicTrack Treadmill, A2550
Oct 29, 2009 | Nordic Track NordicTrack Treadmill, A2550
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Nordic Track NordicTrack C2150 Treadmill Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
