Question about Building Materials
Im trying to program a liftmaster 373p to work on a genie intellicode is550/b not sure how to do so...help?
    New Friend:
  • 130 Answers
As far as I know liftmaster 373 is not compatible with genie.
Posted on May 07, 2014
My liftmaster 373P got wet and doesn't work
Open it up remove the battery and let everything dry out completely. Put it back together when dry and it should work.
Jun 30, 2014 | Chamberlain 373p Liftmaster 963d 315mhz...
Genie 1024 remote programming
On model 1024 genie garage door the carriage trolley jumping out of the chain what should i do to fix it or replace parts...
Feb 19, 2014 | Genie Company Genie Intellicode GITR-3...
How can I connect 3-button remote to my genie intellicode model IS550/A?
The button closest to the Genie logo is the one that works, I just programmed it by pressing & holding the black button underneath the light cover until the red light above the button goes solid then blinks then stops blinking. Next I pressed the same button once and the red light blinks then pressed the button on the remote once then once more and it was all set.
Apr 19, 2012 | Genie Company Genie Series III 3 Button...
GT3-R -can
This is a dual frequency transmitter. (315/390) You need to select one button to program the TYPE 1 frequency of 390 MHz. Here's how:
Backwards compatable programming instructions for GT3-R dual-band remote: This is a 3 button remote, which can be used to operate up to 3 garage doors using IntelliCode radio controls. This remote is defaulted to operate the new IntelliCode 2 Genie garage door openers, but you can also program individual buttons to operate other IntelliCode 1 (pre 2011) models of Genie garage door openers made from 1998 to present. To change a button to operate a pre 2011 IntelliCode opener, the default IntelliCode 2 setting must be changed to IntelliCode 1. An LED light on the remote displays which mode the remote button is in: Red = IntelliCode 1 / Green = IntelliCode 2 To set one of the 3 buttons to be IntelliCode 1 (red), follow the instructions below:
  1. Select a button on the remote that has not been programmed.
  2. Press and hold that button for 10 seconds. Both Red and Green LEDs come on and stay on.
  3. Press the same button twice to toggle IntelliCode selection from IntelliCode 2 to IntelliCode 1.
  4. Press the same button again to confirm toggle. the LED should be Red. The IntelliCode selection for this button is set to IntelliCode 1.
You are now ready to program the remote to your garage door. Follow accompanying instructions for "Programming to IntelliCode 1 Genie garage door opener," or see below instructions: Programming Instructions: Gently press the Receiver Learn Code button on the power head receiver of your Genie garage door opener (motor head on ceiling in garage). This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. After pressing the Learn Code Button, press your transmitter button twice for your system to grab the frequency and code it in. (Keep the transmitter you're tuning at least 2 feet away from the power head while tuning.) Press the transmitter button once more to test the system and start your door moving.
Jan 06, 2012 | Video Game Consoles & Games
Someone guessed our code and numbers were outlined with a marker.... we need to change code but lost our manual.
Hi
There is a bunch of manuals for Genie intellicode systems on genie's website just click here to go there.
Hope this helps
Mar 07, 2011 | Genie Company IntelliCode GICT390-1BL...
FOR GENIE GARAGE DOOR OPENER ICA SERIES WITH INTELLICODE REMOTE CONTROL SERIES II ELECTRONICS. PROGRAMED REMOTE FOR NEIGHBORS DOOR, WHRN NO LONGER NEEDED THE ACCESS I RE-PROGRAMED TO MY DOOR. NOW BOTH...
First you want to clear both Garage Door Openers. To clear the openers you need to locate the learn code button. This button is (usually) under the white lens cover just push it and hold it in until the red light stops flashing then do the same thing to your other opener. This clears out all remote controls that are programmed to these openers. Try the remote to make sure the units were properly cleared. Neither opener should activate if this was done correctly. After units are properly cleared push the learn code button on the opener that you want this remote to open. The learn code led will flash, then press the button on the remote once (learn code goes solid), press the remote a second time ( learn code goes out). Press the remote a 3rd time and opener should activate.
Nov 22, 2010 | Genie Company Genie Intellicode 1Button...
Genie Compact 3-Button Remote control will only open 1 door/not 2
On some of the remotes you will find a toggle switch to change frequencies, this might help. Note all new openers are operating on a different frequency than slightly older ones due to military interference. Even though both might be intellicode they might not work together on the same remote. Sometimes some openers are harder to program than others. So lets try to program the harder one. You need to find and press the learn button on the motor head. Then press the button on the remote once. The led light by the learn button should not flash. If so try it over. The light should either stay lit or go out after the first press. If it does press it again and then a third time. If it ever flashes during the program process try again. The third or fourth time the motor should operate. If not you either have a bad remote or more than likely a bed logic board. Thanks BB
May 15, 2010 | Genie Company IntelliCode GICT390-1BL...
Have a 3 Genie remote and the center button works in programming one garage door, but the side buttons will not work to program the other garage door. Can you help?
The other opener has to be a genie, compatible genie to be exact. An older one will not work with new devices. If it will not program it will be the openers fault not the remote. Thanks BB
Feb 16, 2010 | Genie Company IntelliCode GICT390-1BL...
Building Materials Logo
73 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
