Question about Lanzar Htg157 htg157 3000w Heritage Monoblock Mosfet Power Car Amplifier/amp
Keep popping fuses
The lanzar mosfet 3000 watt amp keep on popping fuse i thought my subs were blown but when i hooked them yp to just the radio rear speakers i got sound. i bought to lanzar 2000 watt max pro 15's and when i hooked them up they started smoking from the magnet.
  • 149 Answers
SOURCE: 2 ohm speakers wont work on a lanzar max pro 4000 watt
The 2 ohm stable rating on the amp is PER channel meaning that you could effectively hook up a 2 ohm speaker or a 2 ohm load to each channel without the amp getting f"d up-butin bridged mode it will only be 4 ohm stable. to achieve a 4 ohm load with your sub the type x wire the coils in series that will get you at 4 ohms to run in bridged mono .But you will get the exact same amount of power if you wire each coil to one channel of the amp as bridged mono sees the sum of your 2 ohm channels combined-Hope that helps.
Posted on Jun 09, 2009
  • 25 Answers
SOURCE: i paid a store to hook up my lanzar vibe 241 amp
To get rid of the buzzing sound just go to walmart and in the car stereo section buy the $10 rca ground loop isolator, this is the best way to get rid of amp noise
Posted on Oct 13, 2009
  • 21 Answers
SOURCE: My amps and subs are working, but my subs aren't hitting.
Try bypassing the remote wire staight to power instead of the stereo
Posted on Oct 27, 2009
  • 24 Answers
SOURCE: what is the rms wattage on a lanzar max pro 15"
1000watts RMS and 2000 peak
Posted on May 31, 2011
mr1967mejias
  • 636 Answers
SOURCE: 15" Lanzar 400 watt sub
Being that I do not know how tall you are. It's hard to give you the dimensions on placing a 15 behind the seat of a single cab. Being that you already have that will fer I can only suggest to build as long a box as you possibly can from one side to the other approximately 60 inches in between the seat belts. As deep as you possibly can at the bottom and place the sub as close to the bottom as possible. This will allow room for the magnet. Good luck.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Posted on Nov 22, 2014
Why does my spa 500 amp blow a fuse every time I hook up my 15" lanzar sub to it
Because it's drawing more power than the fuse can handle get a fuse with a higher rating. A 100 app fuse worked great for main power with my setup 760w amp a 15"sub 2 10"subs and a 12" sub. Also my amp had 2 30amp fuses on it one for each channel but I ran everything out of one channel.
Aug 02, 2016 | Lanzar Car Audio & Video
On a lanzar 535n 5 channel 3200 watt amp what is the best way to hook up 2 lanzar max 12 inch duel voice coil subwoofers
If your amp allows it hook the the sub's to the first two channels but bridge it and only run it on 2ohms so you don't blow your sub's
May 29, 2015 | Lanzar Car Audio & Video
My amp doesnt work
their may be a short some ware check your power line and your ground i had the same problome with mine
Apr 29, 2010 | Lanzar VIBE241 Car Audio Amplifier
Oct 26, 2009 | Lanzar VW12D Car Subwoofer
Problem with subs and amp
I would first suggest un-hooking the subs, and hooking them up to another known good radio other than the one its hooked to now. Just to make sure you didnt blow the speakers. What is the wattage of the subs? Then if the speakers do work I would hook them up bypassing the amp just to see if the problem exist before or after. Come back after doing this. Thanks
Jul 05, 2009 | Car Audio & Video
Not sure whats wrong with my LANZAR MXA242 AMPLIFER. Please help!
did you check the fuses on the side of the amp? put voltage meter on b+ should read 13v, take it to service center to have checked out, may have some prblems inside
May 03, 2009 | Lanzar MXA242 Car Audio Amplifier
Blown car amp repair (Lanzar Opti 150 stereo bridgeable car amp)
its better to change them all. than to change 1 or 2 mosfets, bcuz simetimes it affects the other mosfets. and please check your speaker or maybe there is an resistor, capacitors, or a relay malfunctioning in that area.
Jan 18, 2008 | Car Audio & Video
Audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Nov 28, 2007 | Lanzar 2H 1000W MOSFET AMP Car Audio...
Lanzar amp
If it keeps blowing fuses then #1 its internally damaged or "blown" .. Or #2 i would make sure you have the battery power hooked up to the + terminal and the ground wire running from the car body to the - terminal.. so if its hooked up correctly and keeps blowing fuses then it requires repair.. I wish i had better news but thats all it can be...
Aug 20, 2007 | Scosche Industries Scosche High...
Lanzar Htg157 htg157 3000w Heritage Monoblock Mosfet Power Car Amplifier/amp Logo
24 people viewed this question
Top Lanzar GPS Experts
Are you a Lanzar GPS Expert? Answer questions, earn points and help others
