Question about Heil Tempstar 1172550
Aux light on - Heil Tempstar 1172550
  • Heil Tempstar Master
  • 9,587 Answers
That means the electric heat strips have come on because it's too cold outside for the heat pump to be efficient.
Posted on Mar 29, 2014
Why is jandy rs6 solar always on
assign the solar in the setup to a aux power the lights from the aux that you assigned
Jun 22, 2014 | Jandy AquaLink RS OneTouch RS6 Pool or Spa...
Pioneer keh p6025
You need an extra part to use the AUX function, part number CD-RB20 or CB-RD10. You then have to turn the function on in the settings:
1) Press FUNCTION to select AUX.
Press FUNCTION repeatedly until AUX appears
in the display.
2) Select AUX on or off with 5.
Pressing 5 will switch AUX between on and
off and that status will be displayed (e.g.,
AUX :ON).
Dec 18, 2013 | Pioneer Car Audio & Video
How to wire the Aux 1,2 & 3 relays for Blower, spa light and pool light.
which ever you have wired to each relay connect the correct relay red and black connector then go to system setup and assign the aux and name them
Oct 24, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Don't know how to use aux option in 08 s550 ME Benz
First, you should locate the aux button or touch screen display for the aux and press it. If it reads no aux available or something similar then your model has the button but not the aux input itself. If it reads not connected, look for the aux port (looks like a headphone jack) in the center console region. after plugging in your device, simply hit aux and enjoy!
May 02, 2011 | Car Audio & Video
My problem is that ,my parking lights dont go on any more i checked over the wiring and fuses,also i jis realy wunt to know how to program all the aux options,windows n trunk etc. please help
The fuse for the parking lights for the 5701 is INSIDE the command module. You have to remove the door on the module to access this fuse. If the fuse is good, check the connection. Also, do the parking lights work with the vehicle switch?
If the connections were made to release the trunk and control the windows and... the remote locks, unlocks, remote starts the vehicle, there is no programming necessary. Press and hold the aux button to release the trunk. Depending on the setup and the window control being installed, it could be level1, 2 or 3. To access these different levels: Press F then aux, Press F twice then aux, Press F three times then aux, etc.
Jan 24, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a Pioneer DEH-P5200 and i plugged the aux chords in the back to my ipod but dont know how to switch to the aux mode on radio...
OK - had the same problem and got it finally figured out. Power the unit on the ignition key. Press and hold the source button so the unit shuts off. With the unit shut off press and hold the function button (the key is to hold the function button down) The clock, aux etc will show on the screen. Press (but do not hold) the function button and it will move to each function. When you get to the AUX press the ^ button and the will switch the AUX to "on". Once you know, like everything else, it's pretty easy.
Nov 29, 2010 | Pioneer DEH-P5200 CD Player
I lost the codes for my reomote control i need to program my remote to my television
Hi! Try searching for your codes by following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device button for the device you are programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will blink once then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
4. Press and release POWER until your device turns off. Wait at least 2 seconds between each time you press POWER. Important: You may have to press POWER up to 250 times.
5. When your device turns off press the ENTER/SAVE button. The INDICATOR LIGHT will go off.
try searching for your codes by following the steps below.
I hope this helps.
Oct 12, 2010 | Universal Remote Control GE174Universal...
I cannot figure out how to change my aux settings to on. Nor the d-aux. any help? I am also unable to change the display color.
try this
Setting the AUX Mode (V-Link)
AUX IN ON / AUX IN OFF (Initial setting)
You can input TV/video sound by connecting an optional Ai-NET/
RCA Interface cable (KCA-121B) or Versatile Link Terminal (KCA-
410C) to this component.
You can change the AUX name display when AUX ON is set. Select
the AUX name by pressing g or f. Then press BAND.
If the KCA-410C is connected, it is possible to select two AUX
names.
• Via KCA-410C, up to 2 external devices with RCA output can be
connected. In this case, press SOURCE/POWER to select AUX
mode and then press BAND to select your desired device.
Jan 28, 2010 | Alpine CDA-9847 CD Player
Need a code for my Comcast Universal Remote
30176 is the code you need . Press Aux and then hold setup until Aux lights up. Enter code. If you want the remote to control the receiver all the time, press Aux and then hold setup until Aux lights up. Enter 993 then press Aux. Aux will flash, now press Cbl and Aux should light up when you use the volume.
Jun 16, 2009 | Yamaha RX-V463 Receiver
I have a Kenwood KDC MP2035, it is brand new, I try listening to somehting plugged into the AUX but when i press SRC to select AUX, AUX does not show up, only TUNER and STANDBY are in the options so far
here is some thing that will help u out. AUX Input: The KDC-MP2035 is equipped with a front panel 3.5mm minijack auxiliary input for connecting external portable audio devices such as an MP3 player or Tape walkman. The receiver allows you to select between the following AUX settings.
  • Off: the source button does not scroll through the AUX input when function is turned "off"
  • Aux 1: turns on the AUX input for use
  • Aux 2: turns on the AUX input in the attenuator mode - press the attenuator button to activate sound. pleas let me no if i can help any more and dont be afraidto rate me i dont bite lol just kidding
Apr 09, 2008 | Car Audio & Video
Heil Tempstar 1172550 Logo
67 people viewed this question
Top Heil Tempstar Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Heil Tempstar Heating and Cooling Expert? Answer questions, earn points and help others
