Question about Dryers
I put up my brand new ceiling fan and the remote dont work
    Genius:
  • 1,617 Answers
Make sure the dip switches are on the same frequency. Also, make sure if you have a wall switch, that it is in the on position. If the fan has a pull chain, make sure to go to high position. And lastly, if there is a reverse switch on the fan, make sure it's not stuck in the center position.
Posted on Mar 28, 2014
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
SOURCE: Huntington Bay Ceiling Fan W/lights & Remote operated. # HD 361054
The remote for the ceiling fan has 4 switches inside the battery compartment- look there. I had the same problem, turns out that when I replaced the battery one of the switches was inverted by mistake. Now it looks like 1 and 2 on, 3 and 4 off - and everything works.
Posted on Mar 02, 2009
KMusselmann
  • 247 Answers
SOURCE: Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Posted on Mar 17, 2009
jmgldsmth
  • 2005 Answers
SOURCE: remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Posted on Apr 22, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
Turn of century ceiling fan remorte replacement parts
Hello, Larry -
It seems that the Turn of the Century brand of ceiling fans are sold (new) exclusively by Menards in the USA.
I suggest you call this Turn of the Century / Menards Customer Service phone number and ask about the availability of a replacement remote control for your ceiling fan:
800-887-6326
Note: I hope I am correct in thinking you installed a fresh battery / batteries for your ceiling fan remote control.
Best wishes.
Apr 18, 2018 | Televison & Video
Ceiling fan remote
If the fan came with a remote, you probably need a new receiver. Shouldn't by a store brand fan. Low-end fan = low-end parts
Nov 27, 2013 | Dryers
I have a ceiling fan with a remote and the remote stopped working. The light blinks on the remote when I press the buttons, but the fan doesn't work. The model number of the
The light on the remote is just a battery indicator light. I would try changing the dip switches in the receiver & transmitter first. If that doesn't work, you probably need a new receiver. Good luck since this is a cheap store brand.
Oct 01, 2013 | Hampton Bay 24002 Ceiling Fan
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
I have a brand new Kichler Ceiling Fan/Light installed in new home. This one for the M-Broom came with Remote UC7206T. The function which controls Fan and Fan speed works fine but I cannot the Light...
Something that may work (based on my experience). Shut off power to the fan (the circuit breaker). Remove the battery from the remote and push all the buttons just in case one is stuck. Reinstall the battery. Turn the CB on. Check operation using the remote.
Dec 29, 2012 | Kichler Lighting 300106OBB Ceiling Fan
Remote control replacement.
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
You can also try ebay for OEM replacement fan remotes for the various brands including Hampton Bay...
Dec 10, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Wireless ceiling fan
there are remote controlled fan out on the market.
there are also devices the make it remote, but the cord is for power so i dont think you can hide the wires to much without going thru the ceiling.
if you have no access of the cieling then the wire must be there for powering of the fan run along the wall, try stapling the wire to the cieling like around the egdes of the ceiling then perhap painting the wire the same color of the ceiling.
you do not have much option to work with.
you have to make sure you buy the right remote controll
but it still need power.
http://www.csnceilingfans.com/Ceiling-Fan-Remote-Controls-C14870.html
there a site for remote controls for fan or just buy a new fan all together. im sure they put the plug there for a reason because if you use the fan alot they do go bad.
Good luck
Aug 16, 2008 | Dryers
Dryers Logo
22 people viewed this question
Top Dryers Experts
