Question about Apple MacBook Pro Notebook
Macbook pro hinge crack
Hinge broken with crack on black plastic
  • Apple Master
  • 3,320 Answers
If the laptop still works you were lucky. The screen will die eventually when you open the lid too far again.
Take it to Apple and get it fixed.
Posted on Mar 28, 2014
Tip
MacBook Pro Display housing coming off
If you don't want to spend a lot fixing your old macbook, this is an easy way to do it!
I hope it can help you.
keywords
MacBook Pro Display housing coming off fix
MacBook Pro display housing partly unattached fix
Macbook pro screen separating from the case fix
MacBook Pro unibody housing fix
Macbook Pro screen separation problem fix
MacBook Pro screen glass coming off fix
Broken MacBook Pro hinge fix
on Jan 29, 2016 | Apple Macbook Pro 13 - Brushed Titanium -...
I dropped my laptop in my garden and had trouble closing it. I thought that a piece of mulch had gotten trapped in the hinges so I tried to get it out. Unfortunately, I cut what I believe is the...
isight Camera Cable:http://www.powerbookmedic.com/MacBook-Pro-17-iSight-Camera-Cable-p-19553.html
If you've lost video:
LVDS Cable
http://www.powerbookmedic.com/Macbook-Pro-Display-Cable-LVDS-17-Models-p-17115.html
Nov 09, 2012 | Apple MacBook Mac Notebook
Broken mac book pro screen
Check your user manual for a start. These models the early 2011 models of MacBook Pros work in TDM. See OS X Lion: Use another Mac as a display.
Jul 27, 2012 | Apple Mac Book Pro 13 In Laptop Computers
Paper gets jammed everytime it copies, it would not go through. There's no paper stuck either. Canon MF6530
I am assuming its jamming in the ADF when you are attempting to make a copy, if so open the top lid of the scanner and check both hinges and make sure they are not broken or cracked. The slightest crack in a hinge will offset the paper path and cause jams. If the hinges look good check for a clear plastic mylar strip under the lid, it will be on the left side. If that plastic strip is missing that will also cause jams.
Apr 11, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
My incase case for my macbook pro is causing the hinges to crack
I've had the same problem when I had first installed my case. One day, when it was on the table, my friend leaned on it and there was a loud crack, which got me scared. Due to this, the cracking stopped. Turns out, there is a long tab to attach to where the fan opening is. Just flip your mac over, and push down hardly on the edge of the case, this way, it will be fully attached. Incase makes things perfectly, so if you don't install it correctly, it wont work. Hope this helps. Also, these instructions are not found anywhere.
May 09, 2010 | Incase The Hardshell Case for the aluminum...
I have a mac book and two of the keys have popped off. Can they be put back on and How do I do that?
Placing back the keys is not possible manually except that you stick it, and thats the worst thing you would do. if you have an apple service center nearby, get it serviced by them as they need to open the lower case of the macbook to do that.
Btw is it Macbook or Macbook Pro? Because macbook pro has a unibody which can not easily get the keys back into position if they popped off.
Sep 18, 2009 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Right Hinge Broken
Here is the response that I got from Verizon customer service today via e-mail. I, too, have the broken hinge on a new LG VX8350:
"According to our records a limited number of LG VX8350 devices may exhibit a cracked hinge or stress cracks on the front housing from normal operation. LG determined hinge / stress cracking is due to a production issue with the hinge. LG has implemented corrective action to resolve issue in future production and devices repaired by LG."
They are replacing the phone with a certified LG. All in all, I am very pleased with their commitment to customer service. I would suggest contacting Verizon directly and letting them know that you are aware of the hinge problems.
Hope this helps.
Aug 03, 2009 | LG VX8350 Cellular Phone
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Jun 25, 2009 | Dometic Refrigerators
Cracked front cover at hinges
What does work is this-
Superglue the cracked lid as you WILL have one of these if you are reading this post- dont rush, I did about 10 glue applications over a few days to let it set correctly.
Next remove the offending hinges. You will see to spring/pressed steel curves in the body of the hinge, Next hack saw one (the outer is easier to get to) of these off, this frees the hinge up very well. Worked for me so give it a try
Feb 18, 2008 | Acer Aspire 3610 Notebook
Apple MacBook Pro Notebook Logo
60 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
