Question about Toshiba Satellite S75-A7270 17.3" LED Notebook - Intel Core i5 i5-3230M 2.60 GHz - Ice Silver 8 GB RAM - 750 GB HDD - DVD-Writer - Intel HD 4000 Graphics - Genuine Windows 8 64-bit - 1600 x 900 Display
No bootable device -- please restart system
Restarts and repeats no bootable devices on screen with no use of the computer
  • 39 Answers
THIS IS A BIOS CONFIGURATION ISSUE. WHEN YOU RESTART THE 'PUTER, HIT F2 OR F12 TO ENTER SYSTEM CONFIGURATION. THEN FIND THE MENU ITEM FOR HARD DRIVES AND MAKE SURE THEY ARE RECOGNIZED / PRESENT ON THIS BIOS CONFIG. SCREEN. SET THE HD TO PRIMARY. SAVE/QUIT AND RESTART. THIS IS A STARTING POINT FOR FURTHER DIAGNOSIS. YOU MAY HAVE TO 'DBAN' THE DRIVE.
Posted on Mar 28, 2014
Why is there a black screen on hp pavillion windows 7 "boot mnr missing"?
Windows 7 - black screen with blinking cursor
  1. Remove any CDs, DVDs, or memory cards from the computer.
  2. Disconnect all devices from the computer except the original mouse, monitor, and keyboard. Leave the power cord connected.
    1. Restart the computer.
    If it starts normally, start plugging devices in one at a time until you find one that may be causing the black screen
    1. Press the F10 key repeatedly during the first startup screen until the Entering setup message displays.
    2. Press the F5 key to restore the defaults. Use the arrow keys to select YES , and press Enter .
    3. Press the F10 key to save the changes and exit. Use the arrow keys to select YES , and press Enter .
      The computer restarts.
    4. If a Windows Error Recovery screen displays when the system restarts, select Start Windows Normally , and press Enter .
  • If this doesn't resolve it, follow the procedure below.
  • Aug 17, 2014 | HP 5188-7103 Compaq Motherboard Gl8e...
    No bootable divice please restart system
    this screen appears when
    hard drive has been removed, dislodged or stop working
    to rule out the 1st two options
    if your technical enough
    turn power off remove charger and battery from laptop then try to reseat the hard drive
    Apr 21, 2013 | Acer Aspire Computers & Internet
    Toshiba satellit L875d-s7332 froze during factory recovery now says no bootable device
    Step 1:
    Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
    To perform a system restore, follow these steps:
    1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
    Feb 05, 2013 | Toshiba Satellite L875ds7332 Notebook...
    "For Atheros PCIE Ethernet Controller v2.0.2.3(05/18/10) Check Cable Connection!"
    The operating system is looking for a boot device
    Make sure there are no discs in the drives cd/dvd and usb
    make sure the bios is set to boot from your hard drive or
    You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
    work your way through the problem.
    if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode.
    You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
    hope this helps
    Nov 25, 2012 | Computers & Internet
    The motehrboard bios doesnt boot from usb to install windows, how can i update the bios to boot from the usb?
    Insert your USB jump drive into a USB port on the computer containing the bootable program. Copy the information to your jump drive, then insert the drive into a USB port on the computer you wish to boot the program from.
    Power on the computer. When the computer begins displaying its startup information, hit the key indicated on screen to enter the computer's BIOS (the "F1" or "Delete" keys are commonly used to access the BIOS).
    Browse through the menu options in the BIOS to locate the computer's startup and booting options to locate the "CMOS" menu, which is where you'll have the option to set which devices will boot at startup.
    Browse though the list of bootable option---they'll be ordered as "First Boot Device," "Second Boot Device" and so on. Set the USB jump drive as the first bootable option---your BIOS may refer to the drive as a "USB Removable Floppy Disk."
    Save and exit the BIOS. When your computer restarts, your program will boot first before your operating system.
    Feb 17, 2011 | Intel QDI P2PE/800 Pro 82845PE Socket 478...
    I have formatted my system but whenever i am starting it, its asking for bootable device. After formatting it again it loads all set up file, then it reboots the system but after rebooting it again loads...
    after it loads al setup files and it will say something like the computer needs to restart press enter to restart now or it will automatically restart in (so many seconds will be displayed) So as it is restarting it will flash up something like press f2 or delete or some other key to enter setup ( if you miss what key it says just hold down ctrl-alt-delete and it will restart again. So after entering setup, you will be able to scroll through the settings and find one that will allow you to change the boot device sequence and just set your hard drive to be the first boot device. It sounds like right now the computer is set up to boot from the cd rom drive first and so when it restarts then it will load the windows setup files again like you said. I know it's stupid and nobody tells you that is what you have to do , you kinda have to figure it out on your own.
    Aug 01, 2010 | Acer Computers & Internet
    When i install an operating system to my computer it is always loading and it will back to the beginning!!
    USE THE BOOTABLE CD/DVD THAT CONTAINS THE OPERATING SYSTEM AND WHEN YOUR SYSTEM RESTARTS CHANGE THE BOOTING SEQUENCE OR THE FIRST BOOT DEVICE TO HDD PPYD
    Jun 10, 2010 | Microsoft Windows Vista Home Basic Edition
    My laptop after starting goes to the window xp intro screen then restarts again and again. it wont even recognize the boot disc that came with it
    All right, first you gotta check your BIOS settings goto to bbot tab and check the order of your drives at the top must be the CD-rom drive, then check that "boot to optical devices" and "boot to removable devices" are enabled then restart your computer with  a bootable cd and goto repair mode, and perform check disk to the drive in your windows is installed. The command is "chkdisk C: /F /R" hope that helps, please rate the answer
    Jan 21, 2009 | Toshiba Satellite P35-S609: Pentium 4-3.2...
    Hp dx2000 boot problem
    Hi Robert,
    please try these troubleshooting steps,
    Resolving the blank screen Follow the instructions below in order to fix this issue:
    1. Remove any CDs, DVDs or memory cards from the computer.
    2. Disconnect all devices from the computer leaving only the original mouse, monitor and keyboard and power cord connected.
    3. Restart the PC. NOTE: If this resolved the issue, see the Preventing the blank screen section at the end of this document.
    4. Press the F1 key repeatedly during the first startup screen until the entering setup message appears.
    5. Press the F5 key to restore the default settings. Use the arrow keys to select YES and press ENTER .
    6. Press the F10 key to save the changes and exit. Use the arrow keys to select YES and press ENTER . The PC restarts.
    7. When the system restarts select Last Known Configuration from the boot menu. The PC should now startup normally. If the blank screen persists continue with the following steps.
    8. Select Safe Mode from the Windows Advanced Options Menu .
    9. Use Microsoft's System Restore feature to restore your computer to an earlier time and correct the issue.
    Jun 23, 2008 | Computers & Internet
    Dell desktop
    3. Restart the PC.
    10. If disconnecting devices from the PC resolved the startup issue, re-attach one device and then restart the PC. If this is successful, re-attach the next device and restart the computer again. Repeat this process until you find the device that is preventing the PC from starting properly. Contact its manufacturer for advice on this issue. Please, keep your PC software updated in order to possibly prevent the error from occurring in the future:
      • update Windows.
      • update the BIOS.
      • The software for the devices may need to be updated or reinstalled. Contact their manufacturer for information on the latest updates for your devices.
    May 21, 2008 | Computers & Internet
    Toshiba Satellite S75-A7270 17.3" LED Notebook - Intel Core i5 i5-3230M 2.60 GHz - Ice Silver 8 GB RAM - 750 GB HDD - DVD-Writer - Intel HD 4000 Graphics - Genuine Windows 8 64-bit - 1600 x 900 Display Logo
    71 people viewed this question
    Top Toshiba Office Equipment & Supplies Experts
    didi2005
    jasbo
    jasbo
    Branko Djurdjevic
    Branko Djurdjevic
    Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
