Question about Nikon Eclipse E400 Microscope
STAGE ASSEMBLY DOES NOT HOLD HEMOCYTOMETER IN PLACE
NEED LONG FINGER ASSEMBLY
Where can I find detailed instructions on replacing an auger?
first remove the chute. then remove the bolts holding the auger in place. then rotate shaft by hand and find the two roll pins that hold auger assembly shaft. drive these pins out and you auger will slide out the front of unit
Aug 28, 2014 | Yard Machines 26" 208cc Two Stage Snow...
Problem with Hamilton Beach Brewstation I have the water tank apart and I need to know how to put the spring and seal back in
I'll assume you have the pivoting arm with the rubber washer stopper apart. The rubber stopper pulls out of its housing. If you have that out you need to stuff it back in its hole with a small screwdriver. If not: the pivot for the arm rests in two grooves; the arm is held UP with a spring under the arm. (The top of the washer seals the dispensing hole from inside the pot.) The pot has an indentation the spring fits in, the arm also has a depression to hold the spring. It's tricky, but u can get everything lined up in order to put the holding plate (with the 2 screws) in place. (Hold the assembly in place with one finger and with the other hand put a finger thru the holding plate. Move the holding plate toward its final position and switch fingers holding the assembly in place. You're now holding the assembly with the finger that has the holding plate.) Position the holding plate and tighten the screws.
Jun 11, 2014 | Hamilton Beach Brewstation 48465
Nothing happens when I put my finger on the icon it wriggle yes but no x appears
Are you pushing and holding? You need to place your finger on the app Icon and hold there until the x appears. If that doesn't work go to cloud and select your apps menue then place your finger on it and hold after a few seconds it should then give you the option to remove from device and I cloud both.
Jan 04, 2014 | Apple iPad 32 GB WiFi Tablet PC
We tried to rekey our kwikset smart key, but couldn't and now the original key doesn't work
I had mine do the same thing right before I was leaving to the airport [re-keying for the house-sitter]. I was setting the lock and I hear a spring-type ping and the keying was lost.
The tumbler can be reset to your key. However, it involves disassembling the device and has small parts.If you are feeling lucky, you can do this yourself or take it to a qualified person.
If you are feeling lucky:
A: Disassemble the lock from the door
B: Remove the door handle from around the key side.
C: Remove the U retaining-clip from the outside of the lock that is securing it to the shaft.
D: Remove the lock from the shaft
E: Remove the U retaining-clip from the tumbler body and the case
F: You will have to press the five fingers down evenly on the length of the case to slide the cylinder out of the case. (I cut a plastic card with small wire cutters to make a tool, but you could probably use thick card-stock and some scissors.)
Be careful; you will have to watch for and secure the check ball on one side of the tumbler and the finger lock bar on the other side as you slide this out.
G: Remove and store the check ball securely as well as the finger lock bar. (careful with the plate surrounding the fingers that the finger lock bar resides in)
H: Remove the finger locking plate. Carefully, make sure the fingers are still inside and oriented correctly and the spring at the back of the finger locking plate is left in place.
I: You will notice a u channel groove in the fingers and the finger locking plate. Align the fingers in the finger locking plate evenly so that the grooves in the fingers match the groove in the finger locking plate.
J: Replace the finger locking plate with fingers aligned evenly with the u channel groove back onto the tumbler body and hold back against the spring left on the rear of the tumbler body. This puts the tumbler into re-key position.
K: Replace the finger locking bar onto the finger locking plate while holding the assembly against the spring and tumbler body. (If this is done correctly, the finger locking bar will now be flush with the side of the finger locking plate and not raised as normal.)
L: While holding the tumbler assembly together and maintaining the locking plate pressed against the spring, Insert your new key into the tumbler body.
M: While holding this assembly in this position, add the check ball to the tumbler assembly.
N: While holding the assembly in position, slightly depress the black plastic block at the back of the finger locking plate and slide this tumbler assembly back into the tumbler case taking care to rotate the case 90 degrees clockwise from normal. (Note the U channel groove inside the tumbler case that normally receives the finger lock bar and use that for orientation.)
If the tumbler does not insert cleanly, verify the finger locking bar is flush. If it is not, redo while maintaining proper pressure to keep the finger locking plate firmly against the spring in re-assembly. Also, verify the fingers are not protruding from the tumbler body. If they are, redo the procedure taking care to align the fingers properly on assembly and maintain proper force on the finger locking plate against the tumbler body during re-assembly and new key insertion
O: Rotate the key and tumbler body in the case to the normal position (counter-clockwise 90 degrees).
P: While holding the tumbler body firmly against the case, remove the key.
Q: Re-insert the key and verify smooth rotation.
R: Align the tumbler body and case back to the normal position and while holding the tumbler body firmly against the case, remove the key.
S: Replace the U retaining-clip that belongs on the back of the tumbler body to secure it within the case.
T: Replace the tumbler body in the main lock shaft and secure with the shaft U retaining clip.
Mar 24, 2010 | Kwikset Professional Door Lock...
30 gig ipod is frozen. Hard reset doesn't work.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Putting ipod into disc mode
http://support.apple.com/kb/HT1363
(Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
How to restore iPod
(ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are:
Restore Option
1: Restore - Restores with same iPod Software version already on iPod.
Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option
3: Use Newest Version - Restores with the latest iPod Software available.
Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed,
iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display.
It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to
name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Apr 21, 2009 | Apple iPod MA446LL/A MP3 Player
IPod nano is dead
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
How to restore iPod (ARTICLE NUMBER HT1339)
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Mar 11, 2009 | Apple iPod nano
How do you change the right front headlight bulb on a kia sedona
Remove the headlight assembly. Just remove the 3 bolts with a 10 mm socket and pull it out so you can disconect the wire harness. After that pull the whole assembly out and unscrew the bulb cover. The bulb is held in with a spring clip.
Dec 25, 2008 | 2003 Kia Sedona
How do i tension the cam belt on my e36 318i bmw?
to do it correctly you need a tension gauge, however it is possible without. make sure your timing marks are correct,flywheel locked and camshaft locking tool in place. slacken camshaft sprocket bolt and turn clockwise to stop. fit timing belt in an anticlockwise direction starting at the crankshaft, ensure belt is taught on the non tensioned side between sprockets. turn tensioner pully anticlockwise, untill you can turn belt 90 degrees with finger and thumb pressure. tighten tensioner. tighten camshaft sproket bolt to 63nm. Remove all locking tools. turn engine 2 revolutions from the crankshaft pulley by hand. DO NOT START AT THIS STAGE!!!!!!!! refit all locking tools, if at any stage the engine locks or the tools will not refit, you have done something wrong. Go back to stage one. Check belt tension finger and thumb method, retension as required. turn again by hand. re fit all components and start. If you have whining noises the tension is too tight. Flapping or banging noises too loose. This is not a fool proof method and you have to be aware of the failings of fitting timing belts without the correct tools etc. ENGINE DAMAGE WILL OCCUR IF FITTED INCORRECTLY. A good garage should charge no more than 2.5 hours for this work to be carried out, with a warranty. Hope this helps
Dec 23, 2008 | 1996 BMW 318
I need to change the thermostat in a 1993 Jeep Cherokee Laredo
I'm going to assume that you have a 4.0 L6 (inline 6) engine) since that's the most common one. If not, most of instructions are the same. 1. With engine cool, or, pressure out of system, radiator cap off, remove both hoses from thermostat housing (top radiator hose connects directly to housing on front of engine). 2. carefully scrape all gasket material from housing and block. Make note of how the thermostat was installed (end with spring goes into the engine block). Since installation is vertical, I usually use silicone glue on gasket, installing thermostat into housing first, then applying gasket to housing, so that it will hold the stat in place when installing to block. (let glue dry for a while). 3. Put a thin film of silicone on engine side of gasket, position assembly on block and put in the easiest to access bolt, finger tight. Be careful not to move assembly around too much or you may cause the thermostat to go out of position. Put in the second bolt, again, finger tight. When both bolts are installed, tighten each, going back and forth, taking up tension equally (don't tighten one, then the other one all at once). 4. replace both hoses, fill to replace any coolant lost (usually not very much). Start engine and run with cap off radiator and heater full "on". Watch temp gauge.When up to operating temp, add more coolant if necessary. (also monitor radiator during this stage for overflow or overheating. it is sometimes necessary to intermittently add some coolant while engine is coming up to temp. as some overflow is normal). 5. close cap and run for several more minutes. Check hoses and therm gasket for seepage. Some re-tightening may be necessary, but if excessive you may have made a mistake you should not have to "crank down" really hard on any hose clamp or fastener. PS, I usually remove and replace spring type hose clamps with screw type. They are more reliable and easier to work with!
Dec 16, 2008 | 1993 Jeep Grand Cherokee
Ipod nano gen3 (the square one)My daughter's ipod nano gen3 will all of a sudden not charge. Any thoughts?
Oct 07, 2008 | Apple iPod nano 3rd Generation
Nikon Eclipse E400 Microscope Logo
194 people viewed this question
Top Nikon Science & Laboratory Experts
matt
matt
William McMath
Are you a Nikon Science and Laboratory Expert? Answer questions, earn points and help others
