Question about Nikon Eclipse E400 Microscope
Hemocytometer not properly held in place on Nikon Eclipse E400 short arm stage assembly
Hemocytometer is not properly held in place on the stage assembly of the Nikon Eclipse E400 microscope. Is there a longer arm stage assembly that can be purchased? please respond at Linda.N.Mackintosh@questdiagnostics.com
2 Suggested Answers
  • 5 Answers
SOURCE: service for Nikon Esclipse E400
You can locate an Authorized Nikon Repair Center for India at the following link:
http://www.nikon-asia.com/distributors.php
Posted on Jan 01, 2010
How do i change the bulb in the nikon eclipse e400 microscope?
Sure you did to switch of the power?
Look at the picture.
The change of the lamp is in the manual, but over to many pages, so difficult to make a screenshot, but with the link you can read it yourself:
dbea0ea7-624b-454c-bf25-990a60c8358a.png http://www.boycesci.com/Manuals/E400%20Instruction%20manual.pdf
Jul 15, 2014 | Nikon Science & Laboratory
How do I replace the fog housing on a 2005 Mitsubishi Eclipse Spyder?? Does the whole front need to come off?
No. You can get to the fog lamps by removing the plastic under-covers from the bottom of the bumper facia. They are held in place with a bunch of plastic clips. Once the covers are removed, you will see the back side of the fog lamp assemblies where you can access the four mounting screws.
Apr 14, 2012 | 2005 Mitsubishi Eclipse Spyder
Drivers side transaxle slides about 2 inches into the ****** causing the wheel and tire to move also. this causes the car to shift to one side drasticly. i need the cv joint assembly diagram to better...
If the whole wheel assembly slides in and out then the CV joint is most likely NOT the problem. There is supposed to be play in the axles for when you turn the steering wheel. I would be looking at the ball joints or control arms or the hub bearings. Since the wheel is mounted to the spindle and it in turn is mounted to the control arms, and the only movement allowed when it is all put together and proper is the wheels turning from side to side for a left or right turn.
Your CV axle is a shaft that has a Constant Velocity joint ( hence the name CV axle) at each end and is inserted into the transmission and held in place by a snap ring and has a spline shaft at the wheel end that is held in place by the axle nut.
Aug 15, 2011 | 1998 Buick LeSabre
We are using our Nikon Eclipse e200 for the first time and we cant get the stage handle to move the glass slide up and vertical. It moves horizontal but not vertical. Is there something we need to detach...
If this is a brand new scope then there is most likely some packaging or packaging tape that is preventing movement. Scopes are meticulously packaged because they can be rather delicate instruments. In some rare cases the scope may be damaged in shipment.
Jan 08, 2011 | Nikon Science & Laboratory
I need to adjust the wiper arm on a 1997 suburban, it hits the side of the window.
Wiper Arm & Blade (Front) Removal & Installation Wiper Blade To Remove:
  1. Turn ignition switch to ACCY position.
  2. Turn wiper switch to PULSE position and turn ignition OFF when wipers are stopped in the innerwipe position.
  3. Push the wiper blade clip button IN and remove wiper blade from wiper arm.
To Install:
  1. Insert wiper arm hook through opening in wiper blade.
  2. Place wiper blade pivot in the inside radius of wiper arm hook.
  3. Pull on wiper blade pivot into hook until it locks into place.
  4. Check wipers for proper operation.
Wiper Arm To Remove:
NOTE: Mark position of wiper blade on windshield to ensure proper position upon reassembly.
  1. Remove washer hose.
  2. Lift wiper arm from windshield and use a screwdriver to disengage retaining latch.
  3. Remove wiper arm from shaft.
To Install:
  1. Place wiper arm on shaft so that wiper arm aligns with marks placed on windshield.
  2. Press arm assembly on shaft and push retaining latch IN.
  3. Connect washer hose.
  4. Remove windshield markings and check wipers for proper operation.
Oct 26, 2010 | Chevrolet Suburban 1500 Cars & Trucks
Service for Nikon Esclipse E400
Oct 14, 2009 | Nikon Science & Laboratory
Nikon Eclipse E400 Microscope Logo
29 people viewed this question
Top Nikon Science & Laboratory Experts
matt
matt
William McMath
Are you a Nikon Science and Laboratory Expert? Answer questions, earn points and help others
