Aristo washing machine dryer ARMF 125 AUS All
Aristo washing machine dryer ARMF 125 AUS All parts including the hard plastic chamber
2 Suggested Answers
venexcsd
  • 1185 Answers
SOURCE: water does not come to the washing chamber
Switch the machine on when the room is quiet
Dial up a cool wash hit the start button then listen while you remove the power you should hear water falling into the drum
If there is power to the fill valve ? then you need to put a meter across the terminals to check for resistance , no resistance means an open circuit coil and a the valve will not open
Posted on Jan 05, 2010
I have an ariston washer dryer combo. today I turned it on to do a wash cycle. the knob no longer clicks or shows the times of other cycles. I've turned it off and on a few times but nothing helps
Ariston armf 125 washer dryer combo - YouTube
? 4:14
www.youtube.com/watch?v=zPtG5Q3qQ3Q
Oct 23, 2010 - Uploaded by troykm Rinse cycle. Correction - it does do 3 rinse cycles!! :-)
[PDF]Instruction Manual - Ariston Appliances
aristonbrand.com/media/WDG-8629-User-Manual-19510586801_AU.pdf
WASHER-DRYER ! This symbol reminds you to read this instruction manual. ... from its packaging. 2. Make sure that the washer-dryer has not been damaged.
Sep 22, 2015 | Washing Machines
Parts manual for aristo craft dash-9 44cw diesel train
You might try the following link.
Aristo-Craft is no longer in business, but you might try the attached link to the Aristo-Craft forum & ask there.
Sep 29, 2014 | Crafts & Hobbies
Error code E20 on a AEG washer dryer
Ok if its only bring the E20 up on the drying side then this will be a blocked dryer condenser chamber.
To get at this you need to take the back half of the washer off and from there you will see a big plastic chamber going from the bottom up to the top.
Take this chamber off and give it a good clean out with a hose pipe.
Once this is clear refit it and the dryer should be back to normal from there.
Oct 14, 2012 | Washing Machines
F13 error code on Ariston washer dryer combo
Model ARMF 125 with same error code F13 how to fix please advise Thks
Nov 06, 2011 | Hotpoint-Ariston ARWDF129NA Washer
Washer/Dryer Heater issue
It appears your dual inlet water valve or timer/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Washing Machines
Getting to water pump
To gain access to the pump, remove lower plastic cover at front by prising down with a screwdriver, and remove same.
You will see the pump pre-chamber cover, unscrew it anticlockwise,and check for anything in there .
Refit cover and refit plastic panel.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Indesit W 123 Front Load Washer
PLASTIC SECTION BROKE-
I know this image may be hard too see. If you can give me th number on the diagram of the part , I can get you a part #. The part# 136948, isnt a valid part #, hope this helps, Dave www.washermd.com
Dec 17, 2008 | Kenmore 98702 Stacked Washer/Dryer
Soap
As you look at the despenser drawer it has 3 chambers. The left chamber is for Prewash detergent, middle for Fabric conditioner, right is for Liquid or powder detergent. Or use a plastic ball in the main drum!
May 05, 2008 | Hotpoint Ultima WD72 Front Load...
Leak during tumble cycle
more than likely that the seal for your condensing chamber has become faulty easy fix undo any screws that hold the condesing chamber on get some bath/shower sealant that is waterproof put this around the chamber and put it back on you will have to leave it for a couple of hours but this should fix the leaking problem its not totaly common but this does happen m8
Dec 27, 2006 | Bosch Classixx WVF 2402 Front Load...
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
