There is a clunking noise in the front end of my 2008 club car precedent. Any idea what this is?
This happens when exiting the garage where the floor is uneven, and when turning
voodoomox
  • 1689 Answers
SOURCE: wiring diagram
dave, the link below contains electric golf carts wiring diagram, one here is almost the same with your 08 Precedent like the one below.
good luck
Wiring diagram
Posted on Jul 24, 2008
SOURCE: SHAKING AND KNOCKING NOISE
it could be tht the exhaust pipe is loose and therefor makes shaking and kinda banging noise. hope i helped! ;-)
Posted on Jul 30, 2008
  • 9 Answers
SOURCE: Noise in Susp or Steering ("clunking") Chrysler Town & Country
link arms no good need replacing,easy job,common fault
Posted on Feb 08, 2009
bunnydawg
  • 5158 Answers
SOURCE: front diff gone, car making clunking noise on acceleration
go to an empty parking lot
turn the wheel all the way to the right and drive in circle slowly
listen for a ticking noise or similar.
repeat in the left direction.
if you hear a ticking or clicking noise you likely have a bad CV joint. not a horridly expensive repair tho a necessary one
one other thing that will cause it is if the rubber boot surrounding the CV
joint is torn.
pleae take a moment to rate this solution.
robert
Posted on Sep 04, 2009
SOURCE: 06 dodge charger rt w 5.7 hemi engine has clunk in front end
The LX platform consists of the 300, charger and magnum.
They will all have front end noise. It's just a matter of time. This appears to be a poor design and should be recalled.
The front end should be replaced with energy suspension bushings and greasable ball joints.
The front end needs to be inspected, but here are the usual suspects. Most to least
1. Stabilizer bushings to frame. Rattle and bump sound. Not too expensive.
2. Tension struts - radius arm as some may say. Makes a poping noise and moans when driving and turning.
3. Stabilizer end links if loose to touch. Noise over bumps only.
4. Tie rods. Primarily outer. If you can turn them by hand they need changing. These make noise when braking and turning. Inner is more pronounced when steering. May cause road wander.
5. Upper and lower control arm bushings. Creak!
6. Ball Joints. These sound like an orchestra when going up a driveway. The most expensive fix on these cars. Up to 1800.00 dealer cost. They do not press out the old joints. They use a new knuckle.
7. Steering rack... another expensive fix. Moans and hisses.
Posted on Sep 13, 2010
Clunking noise from 09 charger front end
That sounds like a loose exhaust pipe or a metal cover plate underneath that has come loose.Check it out.
Apr 15, 2013 | 2008 Dodge Charger
1993 subaru loyale is making a horrible knocking/clunking noise
Hi the only other thing it could really be is the wheel bearing itself, usually in subarus they grind or clunk with wheel movement so if you go faster so does the noise, a garage would be able to tell you strait away as you cant really pull them apart without the right gear. Also check the strut, very unlikely but if a spring is collapesd it wll make a similar noise but wont speed up etc, its also worth noting that a cv can make the noises you describe but it would have to be completly destroyed and quite noticable hope this helps
Apr 10, 2012 | 1993 Subaru Loyale
I have a 2005 Trailblazer. I have had the stalilizer bar replaced, new ball joints, greesed the fittings on the ball joints. New calipers, rotos and branke pade. HOWEVER, I still have a clunking sound...
They are really bad for the lower control arm bushings causing a clunk noise. You can't see movement by checking on a hoist, but lubing them will help only temporarily. I did a lot of them under warranty, but being 2005 I'm sure yours has expired. I' would highly recommend changing them to eliminate the clunk noise.
Feb 01, 2011 | 2002 Chevrolet TrailBlazer
My 2008 trailblazer is making a clunking noise when I stop
2 things to look at, check your front swaybar end links, these tend to make a clunking noise when bad. Also, if you're having a feeling of beeing bumped a tad with that clunk, check your slip yoke on your driveline, needs to be greased.
Dec 17, 2010 | 2008 Chevrolet Trailblazer
Clunking front hubs
usually the noise in the front end is the u-joints or cv joints out towards the tires.
May 21, 2009 | 1997 Dodge Ram 1500 Club Cab
Clunking and grinding noise
My 2003 F150 Supercrew would not engage in 4x4, it ended up being the shifting fork in the front end, cost me $200.
Jul 16, 2008 | 2005 Ford F-150
22 people viewed this question
 Grubhead
Grubhead
