Question about Bissell Vacuums
Bissell quickwash 1970E for carpets/hard floors won't come on
My Bissell 1870E will not work. Only used a few times. Last time burning smell and hot. Power button does nothing. It's not the plug or fuse.
    Habit-Forming:
    Scholar:
  • 60 Answers
If the burning smell was like rubber burning it is probably the belt. If you only used it a few times I suggest bringing it back to place of purchase. A belt should not go after just a few times of use. Besides if anything is burning after just a few uses I would return it.
Posted on Mar 28, 2014
  • 3 Answers
SOURCE: Bissell not removing any water from carpet
when you turn the vacuum on check to see if the brush underneath is spinning if not you have to replace the belt
Posted on Feb 17, 2009
Vac Belts
  • 701 Answers
SOURCE: Last time I used my Bissell Pet Hair Remover
When you smell burning like that it usually indicates that the belt is worn and slipping on the motor shaft. You probably need to change the belt. You can get the belts for your model here:
Bissell Pet Hair Eraser Belts
Posted on Nov 12, 2009
  • 25 Answers
SOURCE: Bissell carpet cleaner not sucking up.
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Posted on Apr 24, 2010
heatman101
  • 43501 Answers
SOURCE: my bissell proheat 2x carpet cleaner is not
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
w56y
Posted on Sep 30, 2010
SOURCE: Carpet not getting moist
Huh I had this issue. It was killing me only used it like six times then no water. I took this apart four times man. They told me it was the pump. I finally ripped it all the way down. It was the pump. But it was the black connector on the main motor. Which runs the pump it came loose. I pressed it back on problem solved. Make sure you crimp it a bit. so it does not vibrate off again. Hope this helps.
Posted on Mar 28, 2011
Reset switch location
the reset button is in the on switch what you need to do is unplug from wall socket then press the on button down hard to reset.
Aug 14, 2013 | Dyson Vacuums
Bissell lift off bagless making high pitched noise, fan seems to run for 30 seconds after shutting off, and a burning rubber smell, is it the belt, and how easy are they to change
The burning rubber smell is usually the belt. Be careful not to use it on your carpet as the rubber belt can get hot and liquify and really mess up your carpet (if you have one). Here's a link to some instructions for replacing the belt.
http://www.ehow.com/how_4550054_replace-drive-belt-bissell-powerforce.html
Mar 15, 2010 | Vacuums
Last time I used my Bissell Pet Hair Remover vacuum it smelled like something was burning and it left a black mark on the carpet. What should I do?
Nov 11, 2009 | Bissell Upright Vacuum - The Pet Hair...
Brand new Bissell Healthy Home 5770H Upright will not turn on.
If the brush attachment isn't locked into place than the vaccuum will not work make sure it is attached properly.
Jun 18, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Bissell won't start
no reset (self resetting motor) Pull the plu,g leave it off for a day, plug it in a try it again tomorrow. If it doesn't work, the motor is gone
You also need to make sur ethat you get the vacuum back together correctly, some vacums put a swithc in there so that you can't hurt yourself while performing this repair
Feb 01, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Belt is hot to touch
If the belt is hot or you smell it burning then chances are it has stretched a little and is slipping on either the motor shaft or beater bar shaft. If you are sure the beater bar is not restricted from turning then I would just replace it. Try this.. With the power cord disconnected, open the vac head to gain access to the beater brush and belt.. then remove the belt.. place the beater bar back into its holder and see if it easily turns by hand.. if it is free to turn..then plug the vac in and turn it on for a few seconds.. you will see and hear the motor come on but you should NOT smell anything burning at that time. If you do.. you may have another issue with the motor or power cord or both.. if you don't smell anything burning, then disconnect the power and just replace the belt.... Good luck.
Sep 12, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Smell
hi
check there faq page from here http://bissell.com/Search/FAQ.asp see if they can answer that ?
riz.
May 31, 2007 | Bissell 6594 PowerForce Bagless Upright...
Vacuums Logo
71 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
