Question about Yamaha Audio Players & Recorders
"ERROR! 4000" on RX-V673
I got an "Internal Error" message after attempting to update the firmware via the Internet on my RX-V673. I went to the Yamaha download page download the latest firmware to a USB stick and followed the instructions to run the upgrade from there. The firmware appears to load, but after loading the screen flashes "VERIFYING..." before it flashes "ERROR! 4000". I have tried this several times now and (eventually) get the same error message.
  • 174 Answers
SOURCE: Garmin Streetpilot i3 GPS cannot load map to memory card
The Garmin C340 comes preloaded with maps while the I3 require that the maps be installed onto a micro sd card.
You can place the micro SD card into a SD adapter and use a regular card reader to download your maps. When the software ask for 'Device' to download to use the drop down arrow and find your drive letter associated with the card reader. Using a card reader will be much faster since the it is ubs 2.0 vs ubs 1.1
You could also go to Garmin website and download and install the USB drivers, see link below.
http://www8.garmin.com/support/agree.jsp?id=591
Posted on Jan 30, 2008
  • 4 Answers
SOURCE: Zone 2 Vol Fix
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Hope it helps. It worked for us.
Posted on Aug 04, 2008
SOURCE: Route 66 Mobile 8 Windows Mobile - software update creates error
To upgrade, use the website version of Route 66 Sync rather than the version on the disk or the upgrade file from the website, both of which do not work. The website version works in conjunction with Microsoft ActiveSync.
Posted on Dec 28, 2008
  • 79 Answers
SOURCE: Problem with update install
download the update to flash drive using your pc then plug it into your ps3 and install it that way.(may take 2 or 3 trys).
Posted on Apr 09, 2009
smarthome2
  • 1114 Answers
SOURCE: I have a yamaha rx-v565,
It will not work. Your version of HDMI will not pass signal. That's the short version. The long version can be found by googling "HDMI forums" and you will find 1000's of others with the same issues. It's HDMI, not Yamaha or Sony or any other receiver manufacturer's fault. HDMI has been plagued by the recording industry to make sure "copyright's" are protected. And this has been the "nail in the forhead" of HDMI! The current version of it, which is 1.3b seems to be working "so far" And the fix for your receiver is not just software it's hardware as well. If your receiver is under warranty, Yamaha will update it for free. If it's out of warranty, Run HDMI directly from your source to your TV and digital coaxial or optical to your receiver. The fix is expensive. Hope this helps
Posted on Aug 23, 2009
How can I connect my Yamaha RX-V463 Receiver to the internet in order to install the Firmware update? Is there an adapter for this?
No there is not as to update the firmware you need to change internal boards and finding a source for them now is difficult
then connect a CD player via the optical input and put the downloaded firmware on a CD
Take a look at the following link
https://www.manualslib.com/manual/1090806/Yamaha-Rx-V463.html?page=17
Feb 03, 2017 | Yamaha Audio Players & Recorders
Internal error
Hi, is there any solution. Having same Problem here :-(
Dec 14, 2013 | Yamaha RX-V673
I connected the HDMI 1 input from my tv to the HDMI output on the Yamaha Rx-v673 but i do not get any signal going throught to the tv. when i try put my samsung input source as HDMI 1 the tv prompts me...
To connect a TV you should use the Rx-V773, not the 673.
With the 673 you can use TV only as input, not output.
However there is a firmware update for your receiver. Try it.
Nov 13, 2013 | Yamaha Audio Players & Recorders
My sub wont power off when I turn off my Yamaha RX-V673
The sub would have to be getting AC power from an outlet on the Yamaha
Jan 08, 2013 | Yamaha RX-V673
Yamaha RX V673 airplay problem
Disable IGMP filter on your router
Nov 13, 2012 | Yamaha RX-V673
My Rx-V473 won't turn on
It couldn't start after an update. I found how to fix it on the product page : http://download.yamaha.com/search/detail/?language=en&site=europe.yamaha.com&asset_id=58063&category_id=16446&product_id=1643029&1375038490
Receiver doesn't power up after the update.
Error message appeared when confirming the firmware version.
Recovery method using USB method:
1. Unplug the AC power cable from wall outlet.
2. Insert the USB thumb drive which has the firmware data stored inside, into the USB port located on the front panel.
3. Press and hold the INFO key and keep it pressed while you plug the AC power cable back into the wall outlet again.
" USB UPDATE " will appear on the front display. Then, release the INFO key.
4. The update will start automatically.
5. When " UPDATE SUCCESS " appears on the display, firmware update is completed.
Power off the receiver and remove the USB thumb drive.
6. Confirm updated firmware version.
Oct 18, 2012 | Yamaha RX-V473 A/V Receiver Black
Error 79 ...shuts off and the screen says error 79
Hi angelahender:
Here is your problem.
79 Error
PowerOff>PowerOn
The product has experienced an
internal firmware error.
Disconnect the power cable from the
product, wait at least 30 seconds, then
reconnect the power cable and wait for
the product to initialize.
If the error persists, upgrade the firmware.
Firmware update via flash executable
The configuration page lists the firmware version of the product. On
flash-memory-based products, you can update the firmware code by
downloading the latest flash executable for the product and running
the program according to the readme instructions that come with it. If
the firmware should become corrupted or fail (usually because of an
interruption when attempting to update the firmware), the product will
no longer function. In this case, a firmware recovery DIMM is
available from HP.
Hope this helps
Jul 16, 2009 | HP LaserJet 3330 All-In-One Printer
557 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
