Question about Epson STYLUS CX3900 All-In-One InkJet Printer
Printer mechanical fault
When I turn my printer on, there's a white lever looking thing that drops down next to the ink cartridges and stops any printing from happening. Every single light starts flashing and I can't do anything except turn it off. Is there a way to fix this?
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
Replace printer, it's cheaper than fixing
Posted on Apr 29, 2014
techman
  • 3130 Answers
SOURCE: Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Posted on Apr 23, 2006
BinaryCode
  • 54 Answers
SOURCE: Stylus Photo R280
Ink carts being not recognized and you say its a brand new printer?
Heres what you may want to try.
1. Turn off the printer and disconnect the usb cable from the printer
2. Press and release the ink button once you see a solid green light and solid red ink light
3. Open up the printer cover and check out where is the ink cart holder positioned
4. It should stop in the middle part of the printer, you should see an arrow or a ink out marker (ink icon with a / with it( indicating which ink cart is out or not recognized or expended. (This is a usual process on all the epson stylus photo series I had)
5. Press and release the ink button again, it should stop to the next ink cart which you are having a problem and if it doesnt then your ready to reclamp the ink carts.
Just follow your manual usually theres an on screen instructions how to manually replace or reseat the ink cartridges. If the issue persist, you may want to contact epson, ask for a warranty procedure or what you can do next for this. (Either a bad set of ink cart or a bad print head) Good luck!
Posted on Jun 12, 2008
websnail
  • 419 Answers
SOURCE: MY EPSON D88 PRINTER HAS 2 FLASHING LIGHTS
This is usually caused by a problem with the chip(s) on the new cartridge.
Check that the chips are clean, and are correctly installed on the cartridge(s) (some can be knocked out of alignment and thus not connect properly).
Also check for any damage to the tiny wires in the printhead where the cartridge sits.. These can also become soiled with fluff, etc... Be VERY careful if you try to clean these as they are very delicate and if broken off you will have a broken printer.
Last thing is of course to check you have the correct cartridges... A common one with the D88 is to have C86 cartridges which are not compatible at all (different' chips!).
Hope that helps.
Posted on Feb 17, 2009
  • 11 Answers
SOURCE: both ink and paper lights are flashing, printer
the waste ink tank beneath the printer is full. it will cost more to fix this than a new printer. take a look at the Epson NX and Workforce series and get yourself a good printer with a year fedex replacement warranty.
Posted on Jul 07, 2009
  • 400 Answers
SOURCE: Epson Stylus SX200 Begins to print and then stops!
Sir,
You are suggested to Claim the warranty of your Printer if vaild till now. If not then it would need bit of a service. And sir let me inform you that With new printers the cartridges you get are just Sample and have 1/3 ink then new cartridges.
Posted on Oct 15, 2009
How let Lexmark S305 only use black cartridge to print black. Now the color cartridges getting empty by only printing black, and with "only use black ink" selected. (Besides that, the cartridge...
Please follow the steps below on how to print using black ink only on your Lexmark S305 printer:
For Windows:
  1. With your document/file open, click File.
  2. Click Print.
  3. Click Printing Preferences/ Properties.
  4. In the Lexmark S300 Series Printing Preferences window, select print using black ink only.
  5. Click OK to save the settings.
  6. Click Ok again to print your file.
For Mac operating system:
  2. Click Print.
  3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media in a drop down box and select print in black and white.
If you wish to set this as your default print setting, please follow steps below:
For Windows:
  1. Go to Control Panel.
  2. Open Printers and Faxes.
  3. Right-click on Lexmark S300 Series print object and click on Properties.
  4. In the Lexmark S300 Series Properties window, go to Advanced tab. Click on Printing Defaults.
  5. Under Ink Use, select Print using black ink only. Click OK.
  6. Click OK button in the Lexmark S300 Series Properties window to save the changes.
Your printer will print in black only the next time you send a print job to the printer.
For Mac:
  1. With the file (you wish to print) open, click File.
  2. Click Print.
  4. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Note: The 100 standard cartridges yield around 175 ISO Pages. You can also save on ink and stretch your ink investment if you use only 100XL high yield cartridges. These contain almost 3x as much ink as a standard cartridge for a small increment in price.
Aug 07, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
I need step by step instructions showing how to change an ink cartridge on and Epson NX110 printer
If the printer is out of ink in one or more cartridges (the ink light is steady), then with the printer on, lift the scanner unit and use the support to prop it up. Press the Stop button and the (first) empty cartridge will line up with the No Ink symbol on the printer. Press Stop again and the next empty cartridge will be moved to this symbol. Continue to press Stop until the cartridge carrier moves to the ink replacement position (depends on how many cartridges are empty). This is on the right side of the printer. Wait for the cartridge carrier to stop moving. Do not touch the white cable while changing the ink.
Next remove the first ink cartridge by pressing the two tabs towards the center of cartridge and pulling it straight up. (One tab is close to you and the other is closest to the printer.) Take your new cartridge for the slot and shake it four or five times. Then remove the cartridge from the package. Do not touch the green chip. Remove the yellow tape from the bottom of the cartridge. Next rotate the cartridge so that the nozzle is down and facing towards the inside of the printer. Then push it straight down into the slot until it snaps into place. Repeat these steps for the rest of the empty cartridges.
Once all of the empty cartridges have been replaced, lift the scanner unit and push the support to fold it. Close the scanner unit. Press Stop to start charging the ink system. Wait until the Power light stops flashing and remains on before turning off the printer or sending a print job to the unit.
If the Ink light continues to flash, open the scanner unit and press Stop. Press down on the cartridges to make sure that they are completely seated in the cartridge carrier.
If the ink out light is flashing or not lit, you need to use the Epson Utility to change the ink. This is part of the full software from Epson. For Windows right click on the printer icon in the taskbar (bottom right of the screen). Then select Printer Settings and click on the Maintenance tab. For a Mac, open the Applications folder and open Epson Printer Utility 3. Select your printer (if you have several Epson printers listed). Then click OK. (You will need to launch the utility before you open the scanner unit.)
The documentation for the Epson NX110 is available here: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@1663277658.1305218830@@@@&BV_EngineID=cceeadfdielfldicfngcfkmdhjidfmh.0&cookies=no&infoType=Doc&oid=128284&prodoid=63084353 .
I hope this helps.
May 12, 2011 | Epson Office Equipment & Supplies
How to remove ink from printer
Ink Cartridge Maintenance
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
Jan 20, 2011 | Dell 810 All-In-One InkJet Printer
My canon pixma mp780 does not print in color. I cleaned the printhead. It prints great in black and white, but no color comes out...and yes, their is ink in the cartridges.
CANON MP780 DOES NOT PRINT
This is what works for me. Try at your own risk. You may need to clean both areas.
CLEAN PRINTHEAD:
Perform a nozzle check using the Canon software under "maintenance." If the nozzle check prints successfully, the problem is most likely not with the printhead. Otherwise, 1) Lift up the lever above the ink cartridges. Take the ink cartridges out. Put them in a plastic zip lock bag. 2) The container in which the ink cartridges sit is removable. The container is inside the moving mechanism. The container is the printhead. Tilt it slightly and pull up. This should come out easily. 3) There are round pads under which the ink cartridges sit in the printhead you removed. The large one is black. On the underside of the printhead are small slits. The one separated from the others is black. Fill a syringe with Windex. a. Run warm water over the printhead until no more ink comes out. b. Fill the areas where the round pads are with Windex. c. Set the printhead on some paper towels. The liquid will soak through and come out the underside along with the ink. Repeat steps a-c until no more ink comes out, but at least 10 times. 4) Let the print head sit and dry for two hours. Put everything back in the printer. Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
CLEAN PURGE MECHANISM:
You will need a light. 1) Unplug the printer and move the printhead all the way to the left. On the far right are two rectangular basins. The smaller one is black. Take your fingernail or a tweezers and lift out the sponge pad (do not drop it). Soak the sponge pad in Windex until it turns white. Plug in the printer. 2) Fill a syringe with Windex. a. Fill the basin with liquid. b. Let it soak for 5 minutes. c. Turn the printer off. d. Turn the printer on. Repeat steps a-d until you see a small hole in the basin. e. Put the syringe over the hole and fill the basin, pushing the liquid into the hole. f. Let it soak for 5 minutes. g. Turn the printer off. h. Turn the printer on. Repeat steps e-h 5 to 10 times. 3) Unplug the printer. Put the sponge pad back in using your fingers (do not drop it). Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
#16
Dec 07, 2010 | Canon PIXMA MP780 All-In-One InkJet...
How to instal a new printer ink cartridge
DON'T FORGET TO RATE THE SOLUTION, THUMBS UP!
Nov 22, 2010 | Dell 810 All-In-One InkJet Printer
How do I install my new black cartridge? I mean, where does it go? jessicah@ripnet.com
Perhaps the Lexmark X1200 Series User's Guide will be able to help you. Download using this link: http://bit.ly/d2qaOa. Scroll to page 13 for instructions on how to replace the print cartridges.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thanks.
Sep 29, 2010 | Lexmark X1240 All-In-One InkJet Printer
I turn on my printer and the ink cartridge makes a loud noise. also the screen says error 5100. it look as though the clear line connected to the ink cartridge came loose.
Hi You can Try 2 things.
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 26, 2010 | Canon PIXMA MP470 All-in-One Printer
Fault Service error 5100 continually stopping print. Do you know what this means
Next try.
Solution 1:
Solution 2:
Apr 28, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Cannot tell which inkjet color cartridge needs changing
Disregard the monitor information and rely on the printer.
On the left panel of the printer are your indicator lights and buttons. Push the button immediately to the left of the 'ink drop' light [looks like a little tear drop]. Open the cover and the printhead assembly will move to the left and stop. Look very closely and find that little 'ink drop' imprinted into the plastic in the very middle of the printer where the printhead assembly stopped. That 'ink drop' will line up wih the ink cartridge that needs replacing. Push that button on the left again and the printhead assembly will either return to the 'replace' position, or move to the next ink cartridge that needs replacing. Keep pushing that button just once at a time until the printhead assembly identifies all cartridges that need replacing and moves into the 'replace' position. This 'replace' position will be on the right side of the printer where the opening occurs that allows the top cover of the printhead assembly to open.
Change the appropriate cartridges and you should be good to go.
Mar 18, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Epson STYLUS CX3900 All-In-One InkJet Printer Logo
65 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
