Question about Health & Beauty
Unitek 1 180 02 instruction manual
Cannot display the weight measured by hook only zero value
2 Suggested Answers
chanddra2009
  • 615 Answers
SOURCE: my acer AC713 monitor's brightness value gets reduced to zero.
Dear sir,
This is common problem arises mainly due to moisture,especially in rainy season,Monitor front panel control buttons remain pressed,due to deposition of ferric oxide and moisture in between monitor botton panel and circuit board.So you can dry this moisture by hanging a bulb of 60 watt nearer a monitor about 4-5 hrs,(too near may damage the internal heat sensitive parts.).It solves your problem.....and also you may clean the inner monitor button contacting circuit by means of PCB cleaner to wipe out ferric oxide deposition.
if you had any query regarding this issue leave a feedback we glad to assist you.
good luck.
Posted on Sep 10, 2009
Goes to 88888 no matter what. How do I fix that?
Are you over 330 pounds? If not, remove the batteries and count to 10 and replace them.
Description Item # 00835165000P Model # 4GNC25302 The GNC WirelessWeight GS-7006 Digital Bathroom Scale accurately measures weight, body fat, water hydration, bone and muscle mass. This item features a removable wireless display that can be conveniently mounted on the wall, so you can see the readout clearly. Built with durability in mind, the scale is made from extra-strong tempered safety glass. The GNC bathroom scale also features an energy-saving auto on/off function and auto zero.
  • Removable wireless wall mount readout display
  • Measures weight, body fat, water hydration, bone and muscle mass
  • Energy-saving auto on/off and auto zero
  • Extra-durable tempered safety glass
  • Weight capacity: up to 330 lbs
  • Requires one 9V and 2 AAA batteries (included)
Apr 28, 2016 | GNC Digital Bathroom Scale
How do i reset my digial bathroom scale
Remove all the batteries. In ones with memory, there are two sets, a 9 volt and 2 x AA.
Jul 16, 2015 | GNC Digital Bathroom Scale
How to i replace a horn that has three wires to it when the horn I bought only has 2 connectors
I am not an expert on auto horns, but can solve most electrical problems. Do you have a multimeter? Using the ohm-meter, measure the ohm value between the two wires, and from each wire to the horn mounting bracket (you need contact with un-painted metal. The value between the wires should be low (10-100 ohms) but not zero. This represents the horn coil. The value between each wire and the bracket should be very high (10 kilohms or more). This means the horn coil is not grounded to the bracket.
Now, using the voltmeter, measure the voltage between each wire (from one wire to another). The value should be zero before pressing the horn button, and 12 vdc when the horn button is pressed. I would expect one of the wires will also be zero ohms (ohmmeter) when measured to the car frame or body.
Ok, you are ready to hook up the horn. The auto ground wire(s) are connected to a horn wire that is common with the horn bracket. Or, connected to a black horn wire if both horn wires are isolated from the bracket. Connect the auto switch wire (the one that reads 12 vdc when the horn button is pressed) to the remaining horn wire.
Nov 29, 2014 | 1996 Saturn SL
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
http://digitzscales.com/index.php?option=com_content&view=frontpage
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
warranty@digitzscales.com
Aug 20, 2014 | Office Equipment & Supplies
Need instruction manual. When weighing a container....how to set the weight so you do not have to subtract container weight
You have provided very little information and your question ended up in the vacuum cleaners category. I know your question is related to a scale so I will take a stab at a solution. If there is a "Tare" button, put your container on the scal and press the tare button, you should now see zero for the container and the scale will begin measuring the weight when you add something to the container.
Jun 27, 2011 | Vacuums
When I powered this up after having a dead battery, It flashes "P" in the right corner, cant get it to measure. Is that programing needed? or Power low? I dont have the manual/instructions for...
Preset. It is for setting the preset value, if you just want it to be zero, press the button labeled "Preset", on a 543-452 it will be the second button from left to right. Pressing it once will accept the preset value, 0. If you hold it for more than 2 seconds, it will flash to the first digit, press Preset to change this number or hold to advance to the next number. It will go through all the digits then return to flashing the "P" icon.
Feb 13, 2011 | Mitutoyo 543 452B Electronic Digital...
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Dec 09, 2009 | Berkley Twist Lock Rod Rack
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Health & Beauty Logo
73 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
