The power light blinks 7 times, pauses, then blinks 3 times. have sound but no picture.
I have a Hisense 50K360G, when I turn it on the power light blinks 7 times, pauses, then blinks 3 times. After this it appears the backlight comes on but there is no picture. I can hear the weather channel that is on and I can also play a DVD and hear the sound but no picture. Im sure that the power light is giving an error code but I cannot find error codes of a hisense tv anywhere on the net. I've replaced the T-con board but still no picture.
HISENSE MODEL 46K360M Question WHEN TRYING TO TURN TV ON RED POWER LIGHT BLINKS CONTINUOUSLY AND NO PICTURE OR SOUND ALTHOUGH 1-IN-20 ATTEMPTS DOES POWER UP THE SET
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 25, 2016 | Hisense Televison & Video
Hi, I have Hisense 50K23DG. It has no sound, no picture and 5 and half or as 6 red blinkings. Do you know any error code for this Hisense?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Apr 20, 2016 | Hisense Televison & Video
On my Hisense 50K23DG LED TV, I have sound but no picture.
LCD & LED TV Repair - No Image & Blank Black ... - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen CLICK HERE to BUY ... I have an LG ...
Hisense 50K360G has audio no video will not turn on logo ...
? 1:48
https://www.youtube.com/watch?v=xI3MpZukKm0
Nov 20, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http://bit.ly/ShopJimmy6 Want to ...
All comments on LCD & LED TV Repair - No Image & Blank ...
https://www.youtube.com/all_comments?v=xUzCLgoSPGM
I have sound and picture but no backlight. .... how do you replace the back lighting on a led lg tv? ... I have a 42 inch LED LCD combo DVD TV made by RCA.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - Hi, I have an RCA 32" LED 1080p TV that is less than 2 years old, and it has already lost the video. I can hear sound, and I can see lights in the ...
53 HISENSE complaints and reviews @ Pixxed Consumer
hisense.pissedconsumer.com/
Jan 13, 2016 | Hisense Refurbished 50"" 1080p LED-LCD...
I have a 50in Hisense 50K360G. The backlights come on, but no picture or sound. I replaced the main board and power supply and when that didn't work, I took it to a TV repair shop for a free
As far as the TV is now at any service center, it will be wiser to make it repaired there. Otherwise, you might have to spend more; sometimes will get it back in irreparable condition. I assume that, you will understand my words. Gopakumar Gopalan Google
Jan 20, 2015 | Hisense Televison & Video
A module means nothing but possibly 1 of all there might be. Pay the people the one possibly price they ask and save the regrets you might have for doing the wrong
The power light blinks 7 times, pauses, then blinks 3 times. Sound but no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 28, 2014 | Hisense Televison & Video
Our 40' hisense tv keeps blinking sometimes it goes for an hour or two without and sometimes it blinks continuously
Hello
You haven't given the exact model number to your Hisense TV here. Yet, i posts this solution, as this is a common problems to all TV, irrespective of Brrand and model.
Check its power supply regulator board, for any loose solder points. Resolder all the suspected solder terminals to this board, by applying a little more solder, without making any solder bridge short in between adjecent solder terminals. You have to take the board out from the TV to do this job.
Reset it and see whether it helps you. If not, power retgulator board must be replaced as card basis. OK.
Feb 15, 2012 | Hisense Televison & Video
Screen went black no sound no picture when i turn the power on power light comes on green i hear a click and then it goes blinking red
How many times red light blinks? It is error code of problem in TV.
There would be pause of 3 seconds between blinks so count from pause to pause and let me know to find out solution.
Aug 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Televison & Video Logo
168 people viewed this question
Top Televison & Video Experts
Electro Med Services...
