Question about HP Color LaserJet CM1312nfi Laser Color Multifunction Printer - 12 ppm
WIl not print correctly
It will not print correctly even with a new toner cartrage
    Problem Solver:
  • 12 Answers
Printer will not print correctly can mean many things. Does it not print at all, or does it print garbage?
My HP CM1312NFI recently had a new problem, when I wanted to print something the printer simply reset itself with the blue startup HP logo and white progress bar. I tried power cycling it, removing and putting back the toner cartridges, reinitializing the nvram.
Eventually I found 2 things helpful -
to Factory reset the HP CM1312NFI you hold Left arrow and Cancel while powering up which will eventually display that it is erasing the fixed storage. This did not solve my issue.
Then there is a secondary service menu which you enable by pressing
a. Setup.
b. Right arrow + Cancel simultaneously
c. Setup again
Now there should be a new 2nd service menu.
There is an option to clean the belt, and to reset the roller.
Resetting the roller, then power cycling it, did the trick for me. It worked since.
Posted on Aug 25, 2014
    Problem Solver:
  • 19 Answers
If it is faded, it could be the transfer roller. I've had great success with simply periodically cleaning it, then getting a good printout. See my solution for this already posted: Check out this solution to the HP Color LaserJet CM1312nfi Laser Color...
Otherwise, the other issue I had late last year was that it needed a new intermediate transfer belt (part #RM1-4436-000CN). You can find a good deal on one, and the instructions for replacement are on page 156 in the service manual: http://www.feedroller.com/Store/Service%20Manual/HP-CLJ-CM1312-MFP-Manual.pdf
It's not the hardest replacement ever, but needs 2-3 hours depending on skill, and a little patience.
Posted on Mar 28, 2014
Inserted new ink cartrage, but printer saying remove tape from the ink cartrage. I've done that but it still say error. Also the not printing correct. I've had the ink cartrage for a while could that be...
Clean the contacts of both the cartridge and the print head with some alcohol. Reinsert the cartridge.
Power off the printer and wait 1 minute. Power if back on and then make it go thru calibration cycle if it
has one.
Mar 23, 2011 | Office Equipment & Supplies
Hp laserjet 2600n printer creates 1/2" wide band that you can almost see the print...like it is not getting toner in black color.
This often happens when cartrage has run past changing point. remove cartrages starting at top and CK for ink. Run cleaning page until clear
Jul 04, 2010 | HP Color LaserJet 2600n Printer
The toner light of HL 2140 will not go off. even if i turn the printer on/ off and wait for a few minutes. i've also move the green thing back and forth a hundred times and still the same. Please help!
You need to look at the toner cartrage if it was a new or compatible cartrage bought to replace the old one the problem would not exist unless the printer is broken.
Thier is a counting gear on the left side and on new or replacement cartarages it is in the 11 oclock postion when it is new. When the toner is all used it moves to the 3 oclock postion. What you need to do if you refilled the toner from a refill kit is to manually move the gear.
I believe thier is two ways to do this one buy a reset gear tool.
The other way that I do is to remove the three screws carefully that holds all the gears in place. Dont worry as it is just the cover and you can not really break the cartarage unless you strip the screws.
Once opened manually using your hand push firmly on the counting gear until you move it back to the 11 oclock postion. Then carefully reassemble the cover.
Once you place the cartrage back in the light will go off on its own and the toner counter will be reset.
3 don'ts
Do not try to only move the counter you may get a few pages but this is bad for the printer
Do not leave any toner in the cartrage when refilling as this contaminates the toner and really shortens the refill life, try to get all the toner out as possible before refill.
Do not keep reshaking the cartrage and place it back in the printer, everytime you insert the cartarage the it can snag or be inserted a tiny bit wrong and break the gears in the printer. Do so in emergencys only, the rest of the time just refill the toner. $10 with delivery on ebay
Sep 05, 2009 | Brother HL 2140 Laser Printer
Empty Ink Cartrage message when cartrage still has a lot of ink.
I'm going to provide you a solution worth many dollars now you can use your left over half filled cartidges and in future also use the cartridges to the extreme.
1. Go to menu and select manual override for toner cartridges and then only replace toner when the print quality starts to suffer. This can save you thousands of dollars over the life of this fine printer.
2. download and read this
http://74.125.153.132/search?q=cache:9mwf_bY_x-AJ:www.refill4.com/refillinstructons/pdf_downloads/Full-RefillInstructions.pdf+brother+mfc+5840+override+cartridge+empty&cd=6&hl=en&ct=clnk&gl=in
Jul 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
Brother 2140 toner light keep flashing and i just replace it with new toner
You need to look at the toner cartrage if it was a new or compatible cartrage bought to replace the old one the problem would not exist unless the printer is broken.(Or if the replacement has a missing or broken or miss postioned counting gear.)
3 don'ts
Do not try to only move the counter without refill you may get a few pages but this is bad for the printer
Jul 09, 2009 | Brother HL 2140 Laser Printer
Hp laserjet 1320 printing blank pages
check printer door, there is a small plastic piece wich pushed down (to open) lasser scaner cover. if this piece is broken you can get blank page
Jun 30, 2009 | HP LaserJet 1320 Printer
Printed pages have a light shade of toner left on the paper. New drums and new toner.Already cleaned photosensitive roller, got a little better but needs much improvement..
If there is still some kind of residue on the paper. Take the toner cartage and shake it evenly so that the toner inside is not all lumped to one side. Run the drum cleaner on the printer again and if you are still having problems it may be something else. Inspect the drum which should be smooth and not have any blemishes or scratch marks (alot of cartages are refurbished and may not be perfect). Also check your allignment of the toner cartrage inside the printer, if its a little off you may have problems.
Jun 26, 2009 | Brother HL 5250DN Laser Printer
Blank printin on the right middle ohe paper
Toner may be low. Check the Toner level. You may have to clean the printer too if you have a new toner cartrage installed. You might also have a bad printer where its not able to fuse the toner in that area any more.
Apr 22, 2009 | HP Office Equipment & Supplies
Hp color laserjet 2600n giving "10.0000 suply error"
10.00 error is for the black cartridge. Check the cartridge locker for the black toner cartridge on the right side, is it different from the other? does it moves correctly? check properly. If the locker seems correct, try clean the contacts on toner and opposite HV pins in printer
Nov 27, 2008 | HP Color LaserJet 2600n Printer
Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
HP Color LaserJet CM1312nfi Laser Color Multifunction Printer - 12 ppm Logo
93 people viewed this question
Seeker5211
Seeker5211
