Question about NetComm NB5PLUS4W Wireless Router
Change dns settings
I want to know how to put open dns on my NetComm NB5PLUS4W Wireless Router.
  • NetComm Master
  • 3,320 Answers
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: i want to change the
Your model NetComm may have a pinhole RESET button at the back of the router. If so power up the router and press and hold the RESET button until the LEDs flash. The router will now be returned to the factory default settings with the default password. You can now go into the router's configuration to change the password etc.
Posted on Aug 05, 2010
Testimonial: "Thanks"
puertobori
  • 7733 Answers
SOURCE: Unable to to set up
First:
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
Second:
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
For drivers go to NetComm
Posted on Jan 23, 2011
Where is the reset button on the router? NetComm NB604N?
Look on the back of your router where you plug in the ethernet ports, there should be a very small hole, the size of a paperclip. Press and hold for 30 seconds
Feb 24, 2018 | NetComm NB5PLUS4W Wireless Router
WIFI router loses security settings after reboot & continual restart AP required
As far as I know, access points support Wi-Fi wireless communication standards through i have encountered such kind of problems like you. Maybe you can reset the Access Point from the very beginning, hope it will be done... And if you think it's necessary to know WIFI and Access Point better, there is an article for you" http://goodrouterswitch.blogspot.com/2012/08/what-is-access-point-and-how-to.html"
Aug 02, 2012 | NetComm NB5PLUS4W Wireless Router
Unable to to set up wireless for second laptop using the current Netcomn router model NB5Plus4w. By the way, the original router installation disc is not available, can this be downloaded form the...
First:
Second:
Jan 23, 2011 | NetComm NB5PLUS4W Wireless Router
I want to change the existing wireless password on a netcomm nb5plus4w, can anyone help?
Aug 05, 2010 | NetComm NB5PLUS4W Wireless Router
Netcomm NP740n wireless router connection
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 08, 2010 | Computers & Internet
My Laptop and iPod can't pick up my modem
From the laptop try pinging the router IP and then try to ping 4.2.2.2 or yahoo.com or google.com if you get replies the internet connection is fine and your router is connected to internet
As the issue is with 2 different devices it seems that issue is with router's internet connections, also connect the laptop with a cable and check the internet connection if that works fine issue is with the wireless security settings of the router
The user guide of your router is in the link below
http://www.scribd.com/doc/10510222/Netcomm-NB5Plus4W-Modem-User-Guide
Let me know if this help
Regards
Regards
Nov 30, 2009 | NetComm NB5PLUS4W Wireless Router
My Netcomm wireless on my laptop wont connect to the internet but my main computer is connected it shared thing. How can i get my laptop to read and connect to the internet?
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 23, 2009 | NetComm NB5PLUS4W Wireless Router
Port Forwarding on NB7Plus4W router
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
For example ,
You have a Linksys wireless router and you want to open the ports for the X-box.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
Some of the recommended port numbers for different applications :
IMAP ==> 143 SMTP : 25
HTTPS ==> 443 HTTP : 80
DNS ==> 53 FTP : 21
SNMP ==> 161 TELNET : 23
XBOX ==> 53, 80-88, 3074
PS3 ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
WII ==> 28910, 29900, 29901, 29920, 80, 443
VPN ==> 1723, 500, 443-447, 10000-20000
World of Wars ==> 3724, 6112, 6881 - 6999
Click Here for more info
Nov 22, 2009 | NetComm NB5PLUS4W Wireless Router
Iphone to my netcomm NB7Plus4W router issues
you need to update your netcomm so that the modem router can identify your iphone's or mac's firmware.
to do this type in your browser '192.168.1.1' and press 'management>update software'
Feb 09, 2009 | NetComm NB5PLUS4W Wireless Router
NetComm NB5PLUS4W Wireless Router Logo
63 people viewed this question
Top NetComm Computers & Internet Experts
Prashant M
Prashant M
mega_mind
Are you a NetComm Computer and Internet Expert? Answer questions, earn points and help others
