Question about Frigidaire 13 cu. ft. / 368 liter Chest Freezer FFC13C3A
Regular services micro fungus grows on the seal of fridgidair
  • Official Brand Answer
  • 2,267 Answers
Hello Jusuf,
I see that you are having trouble with a micro fungus growing on the seal of your Frigidaire freezer, model# FFC13C3A. First, I would suggest changing the seal. There is no real way of getting that fungus off without compromising the seal itself. Second, if you have this in a basement or very humid area, I would suggest purchasing a dehumidifier. Humidity can cause this micro fungus to appear on the rubber seal. Hope this was helpful.
-Best Regards-
WP
Posted on Mar 28, 2014
Mildew in woods refrigerator
If it is being used, it should be too cold for mold (Mildew) to be able to grow. Upright refrigerators already have a circulation fan in them. Mildew won't form in an environment that cold unless the fan is not running and there is a small air leak around the door seals. The picture above looks like a commercial box. If so, the fan is normally mounted and easy to see, mounted on the top panel, inside of the box. If its a residential model, the fan can be berried behind the back inside panel and difficult to access. If there is a switch visible around the door frame, pushing it in should start the fan. I'm guessing that the mildew is present on the door seal? Try sliding a stiff dollar bill between the door seal and the refrigerator all the way around the door. If it makes it in any where, the seal is leaking at that point. If I am way off with all of this advise, let me know in detail how this is wrong and I can go from there. Hope this is good advise for you. Let me know. Good luck.
Dec 02, 2013 | Woods Freezers
How can I replace the seal for the lid?
no need to replace unless damaged. You should be able to pull the seal off the door and place it in the dishwasher or use the solution described below in a sink to clean it. If removal is impracticable then the recommended cleaner (on the door) is a spoonful of regular dish washing liquid + 1/4 C of Lysol (the real stuff- brown smells horrible) and a quart of very warn water....add to this about 1/8 C of household bleach..clean with a sponge/ rag and rinse. This will clean and totally disinfect the door/ seal. Also, remember that unless you have a true allergy to mold there is no proof that it will harm you, its around us every day. Ever taken a walk in the woods at daybreak or sunset- look at the specs flying around- they're mold at max!
Dec 29, 2012 | Magic Chef 7 cu. ft. / 198 liter Chest...
My Fridgidaire upright Gallery freezer is freezing my food but the appliance seems to be constantly running and the temperature control on the outside is reading 29 Celsius when it obviously isn't
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Nov 22, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
My Fridgidaire freezer is flashing E9 , What does
http://www.frigidaire.com/manuals
go to this web site. It has lots of manuals. I found several for your unit. just enter you model number and it shows up with several choices.
Hope this is what you are looking for.
May 29, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Drain keeps freezing over
normally when a drain keeps freezing over it is warm food being put into freezer/an air leak in door seals/drain hole could have some moss growing in it(really)or if kept in a garage,the poor thing is too cold.
Mar 16, 2010 | Freezers
Will not quite get to freezing.
check warranty quick
Oct 09, 2009 | Freezers
I have a fridgidaire freezer that is just cooling not freezing?
some freezers will not freeze in the freezer department if you are low on freon. the motor cannot produce enough freon to keep your freezer frozen when it is to low, however, you might have the temperature up to high where it has locked up the motor and is sending out all that water underneath. i would check your pan under your refrigerator to see if it needs to be dumped and then replace it back.
Jul 13, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Chest freezer ices up quicker than it should
if the box has mold between the seal and liner the the seal isn't the main problem, the main problem is the liner is bad and by time you got both parts if you can it would cost more than to replace the freezer.
Larry
Nov 25, 2008 | GE 5 cu. ft. / 142 liter Chest Freezer...
Frigidaire 13 cu. ft. / 368 liter Chest Freezer FFC13C3A Logo
105 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
