Question about Electrolux EWDW6505G Fully Integrated Dishwasher with 9 Wash Cycles Wave-Touch
Error code 1 Electrolux
We have just installed this dishwasher and are getting the Error Code 01 although it does not seem to be leaking. Now there is water in the base of the dishwasher that will not drain out. Reading some reviews this seems to be a big problem. Was wondering if anyone has found a fix or if it should just go in the dump?
I found that after 3 washes the flood well had enough water to activate the float switch thereby rendering the machine inoperable. What I done was drill a small hole in the plastic base well - the waster that drains out is minimal, not even noticed, but enough to keep the machine working.
Posted on Mar 29, 2014
4 Suggested Answers
SOURCE: error code 01 on elecrolux dishwasher EIDW6305GSI
Usually the error code 01 means you backed up water in the unit. First be sure that the drain is clear.  Run the garbage disposal and be sure your sinks are draining.
I got lucky on a EIDW6105 unit by trying this.
All the lights are flashing and it shows error code 01.
Push down on two of the buttons and hold (I pushed on the Favorite and Heavy buttons), until the flashing stops (about 8 seconds).
The machine now showed and error code 08.  Then hit the start button.  My washer then cleared and runs normally.
Hope this helps, better than a sevice call to clear the code.
Posted on Dec 28, 2008
SOURCE: electrolux dishwasher error code 01
I found the error codes in the owners manual, (01) is a leak. I called customer service (no wait time) and they said there is pan under the tub that will contain and detect water if it leaks. They said I could wait for it to dry out. They said there could be a hose that became loose or had a pin hole in it. After I hung up with customer service I did my own problem solving. The diswasher washing cycle was just started. Then then the door was opened 5 to 6 times to add more utensils and dishes while the the machine was running. Then the error code came on. this was the first time this had happened. I beleive water seeped doen through the hinges and the seal into the pan. I unpluged the dishwasher and disconnected the water line and pulled it from under the counter. Then lifted the diswasher onto 4 inch blocks of wood placed under the feet. This made it easier to access the pan. It had 2 screws inthe front and 1 in the rear with 3 clips. I removed the pan and dried it. Inspected the hoses under the unit and determined none of them had appeared to be leaking. I positioned a fan to blow under the unit to speed up the dry time, about 1/2 an hour. Put everything back together and ran a high pressure hot water cycle and found no leakes, so far.
Posted on Jan 12, 2010
tattootech2
  • 72 Answers
SOURCE: EWDW6505GS0 Model Electrolux dishwasher 10 months
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Posted on Apr 07, 2010
What does 01 error mean?
Hello Ned, thank you for your post!
I understand that your Electrolux dishwasher is displaying an error code of "01". This error code means that a leak has been detected. Have you noticed any water coming from the bottom or near the dishwasher? This could also be a miscommunication within the control of the dishwasher and a reset may help clear that out. You can reset your dishwasher by disconnecting power from it for at least ten minutes. If that does not help to resolve your issue I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful to some degree. -Matt
Jan 22, 2016 | Electrolux Dishwashers
How do i fix electrolux dishwasher when error code 1 is flashing
Hello friend, thanks for your post!
I see your Electrolux dishwasher is displaying an "E1" error code. "E1" stands for a leak detected which means your dishwasher base has detected a leak. If you can't see a leak you may want to perform a reset on your dishwasher you can do that by disconnecting the power from your appliance for roughly ten minutes.
If that does not correct the issue you may want to seek assistance from a technician. They would need to come out to diagnosis and repair your dishwasher. I hope this information has been helpful. -Matt
Oct 03, 2014 | Electrolux Dishwashers
Have an error code 01 on my electrolux dishwasher
Good Morning Friend, I am happy to assist you!
Typically error code ER01 indicates that a water leak has been detected under the tub of your Electrolux dishwasher. Your dishwasher may possibly need a hydraulic kit. Try unplugging your dishwasher or flipping the household circuit breaker off first. It is good to wait approximately ten minutes and turn on your appliance. If the error code continues to display, then I recommend contacting a professional to make a precise diagnosis. Best regards! - Z
Jul 20, 2014 | Electrolux Dishwashers
Error code 01 after problem has been fixed on electrolux dishwasher
I understand you are receiving an error code "01" on your Electrolux dishwasher, even after the problem was fixed. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why you are still receiving an error "01" on your dishwasher. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Electrolux Dishwashers
More than one error code 01 on electrolux dishwasher
I understand you are receiving more than one, error code "01" on your Electrolux dishwasher. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why you are still receiving an error "01" on your dishwasher. Hope this is helpful.
-Best Regards-
WP
Wave touch electrolux error 01
Hi - Error code E01, typically indicates that a water leak has been detected under the tub. Unit may possibly need a hydraulic kit; however I would suggest contacting a professional to move forward accurately.
Oct 13, 2012 | Electrolux 24 in. EDW5505EPS Stainless...
Electrolux dishwasher DF code after an er 01 code. how to fix at home
Hello Shirley - Typically error code ER01 indicates that a water leak is detected under the tub. Unit will possibly need a hydraulic kit. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Could the error code DF possibly be PF? If so, PF means power failure and you should be able to start a cycle. If the error code continues to display on dishwasher then I suggest contacting a professional to accurately diagnose and repair it.
Sep 30, 2012 | Electrolux EIDW6305GB 24 in. Built-in...
It says error 01
Error code 01
Leak Detected - When water is detected under washer
tub.
Dec 16, 2010 | Electrolux EWDW6505GS Fully Integrated...
EWDW6505GS0 Model Electrolux dishwasher 10 months in service has Error Code 01. Leak. What to do?
Feb 14, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Electrolux 6505GSO dishwasher. Says ERROR 01 onled panel and will not function. What is this code and how can I make the the thing work?
Dec 31, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Electrolux EWDW6505G Fully Integrated Dishwasher with 9 Wash Cycles Wave-Touch Logo
104 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
